skyetom
GTI engine undertray/skid tray
Hi
I've had my Lupo GTI since last December but this is my first post on here; hello! Thanks in advance for any advice you can offer.
I recently found that there's no engine undertray on my car and I'd like to fit one. I've seen different stories about whether or not Lupos had this part fitted as standard. My question is, is it a standard Lupo part or is there a difference between GTI/non-GTI models?
If anyone has one for sale then I'd be very interested. I also need to replace the lower part of the front offside wheel arch liner.
Cheers
Skyetom
If anyone has the GTI ones part number I can check it Against mine. :)
Keeps the underside of your engine clean and provides some protection if you're low from large road debris.
Ohhhhh, so acts as a sump guard basically! Sweet, didn't know if there was a major reason for having one!
New to this lupo stuff sorry!
Thanks for the replies everyone. I'm still keen to know if the tray is fitted as standard or not; anyone know?
Blister - I tried to PM you but your inbox must be full...
Mine came with one as standard, it's a 2001 Lupo gti which I've had since it was six months old.
I have taken mine off as I Run a lower strut brace
If you fit one, don't use the silly metal fastener. Try getting 3 of the nylon nuts that hold the windscreen washer bottle in place,
I have done this on mine and it works a treat.
WS
Thats a good tip, as those metal fasteners don't work very well once the undertray has been on and off more than a couple of times.
Thanks for the tips. I'm on holiday this week and plan on doing some more serious searching for parts. The most important bit for now is the wheel arch liner (mentioned above) but I might need to bite the bullet and speak to a main dealer about that.
Cheers
Skyetom
and don't drop nuts and bolts in the engine bay as they are a right c**t to get out with the engine tray fitted!
Engine tray is around 90 quid new, I priced mine as the nuts fell off at each side and it scraped along the deck for miles wearing a big hole in it!
Resurrecting this thread.
Is it fairly safe to run without a tray for a week or so? Judging by the replies here some people run without them anyway? Isn't the aluminium sump a bit exposed?
I believe this thread is about the plastic under tray - it wont protect the sump
No problem running without, they are most useful in winter - keeps engine bay cleaner and helps with engine warm up too
It's also GTi specific for future reference, the Polo avy one doesn't work as it doesn't compensate for the 02s gearbox end casing
6E0 825 235 L for anyone who's interested, £192.68 inc vat from VW!
Is the SDI version still available?
Didn't you get the one off Danno?
Positive it’s lying in my garden.
Joe had one, then didn't... Same happened for me with a good FFV box in Letchworth or Bedford or somewhere around there... Not having much luck with bits at the mo. And now I'm looking for 085311247B
In the warm sun, covered in oil...
The oil will nourish it.
Keeping it supple.
Frank if you need one I’ll get it cleaned up and take some photos for you.
