Adzer's black and orange lupo - project 1.8t
Adzer
well guys i'm new to this forum and thot i would share my latest project with you guys, i bought this car from a member off here 3 weeks ago with only one intention for it...........1.8t track slag
this car is just gonna be a toy car and a sideline project along side my other project car (4wd leon cupra r 425bhp+)
anyway ill copy and paste my progress so far from the local forum i use, hope you guys enjoy
Drove down to Bradford to pick it up.
Bought it for 500 which I think was cheap for what i got.
Debaged grill
Flushed bonnet
Bonnet bra
Tsw alloys
Gti rear bumper
Cat back exhaust
Coilovers
Clifford alarm and immob
Orange roof and mirrors
Orange interior panels
Jvc headunit
Engine is rough, gearbox is shagged and had no seats or door cards as they was retrimmed orange leather and was worth a pretty penny alone.
Any way some pics
9ude9usu.jpgga2urenu.jpg3ara7usu.jpgubehy4u6.jpgy4udy8e2.jpg3yvuzaha.jpguhu3yby9.jpgzumuru3e.jpgy2utereg.jpgtyqemyru.jpgsadeby7e.jpg
The wheels are just awful and are going once I find a better set.
Well since I got home from england all I've done is sleep as I was shattered, woke up today feeling a bit more refreshed, as I'm still unsure exactly what my plans for the car are there isn't much I can do
But I'm not the kinda guy that can just sit and do nothing.......as the cars soooo small and I'm a lanky **** there was no point buying rear seats so I'll just put in bucket seats in the front which means I don't need the rear trim ;-)
Before I start fabricating engine mounts I need to sort out the pedals as the lupo was clutch cable and the 1.8t Is hydraulic!
To do this the dash needed to come out :-(
While dash was out I removed the airbag and these are also for gays
Originally the 3 pedals went thru the pedal box with one bolt but the new clutch pedal is completely different so I had to mod the lupo pedal box and chop some brackets off
This is the new clutch pedal
Next problem was I was left with a hole in the bulkhead where the original clutch cable came thru. Most ppl would say just leave it but problem being one of the pedal mounting holes sits right where the hole is lol
So out with the welder to fill the hole
Once that was welded up I just needed to mount the pedal, I had to fabricate a bolt to come thru the bulkhead. Its a but long so will get the grinder on it tomorrow
So at the end of the day engines out, and pedal box is finished
Tomorrow remove 1.8t from donor car ;-)
Well thot I'd post a update while I eat my lunch, to finish off the pedal box I had to try make the throttle cable from the donor car fit the lupo. Turned out to work out pretty well. All I had to do was remove a plastic clip and it fitted straight on :-)
Next job was the gear linkage, lupo has linkages where as donor engine uses cables, once I removed both and compared side by side there was a fair difference in size and the way they mount to the car, after a bit of thinking a found the solution I had to cut of some brackets on the chassis
Once that was removed I offered up the
New linkage box to see where I'd need to drill holes to mount it, once I had the holes drilled I tried to fit the shifter to find that the bolts was too short, so I had to cut the original bolts off as the was captive bolts, and weld some longer ones in place so it was long enuf to come they the floor on the inside, some pics of this
Once that was done u could put the dash back in place
Also started removing the sound deadening, what a cock of a job
Bit more progress was made
Yesterday, started to cut back the loom of the wires I wouldn't need
Then started to work on mounting the engine, the driver Side mount needed to be cut out and replaced with the one from the a3, but the a3 mount needed cut to fit
Original mount
Engine lifted into place to measure up for the passenger side mount
straight in with the work then fella! your right those wheels were f***ing awful, but those bucket seats look quality and fit in nice with the colour scheme. Can't wait to see the end product, weird to see something i used to own stripped apart :thumbsup:
Well spent about 4 hours tryin to get this engine mounted and was ready to loose the plot, eventually got a mount made up for the passenger side but still having some Clearance issues with gearbox/subframe, nowt my hammer won't solve ;-)
Anyway here's some pics
Had to chop chassis leg :-/
Engine mounted without hoist ;-)
Bonnet closes.....JUST
Latest edition for the car ;-)
New edition to my BUILD
Was hoping to have the engine mounted for good today but didn't happen, got a few bits done none the less.
Got the bay painted
Got my home made mounts painted too
Before the engine goes in I wanted to change the clutch, so I bought a solid flywheel conversion kit to get rid of the dual mass flywheel
Box off
Old clutch
New clutch
Aircon is for gays
Wow, you learn something every day......... - I never realised gay people were so safety conscious (or maybe they're just bad drivers?!)! :lol:
Edited by Joti
I'd like to think this thread will help ppl do this conversion :)
This is what i'm thinking.
