Nathan_S Posted November 14, 2008 Report Share Posted November 14, 2008 hey guys,i had a letter yesterday from SEAT saying i need to take my car in to be checked for a common fault involving the material the brake vacuum pipe is made out of and that it needs to be checked and replaced if necessary! im surprised no one else has mentioned this...i'll put up more details when i get home.i'd call your local dealer and ask then about a recall concerning the brake vacuum hose! so now when the engine is working the brakes need fixing.... will this car ever be problem free!?! cheersNathan 3 Quote Link to comment Share on other sites More sharing options...
Paul R Posted November 14, 2008 Report Share Posted November 14, 2008 Mechanic noticed mines was cracked when i was getting the pedal box replaced, £25 for the part and bout 0.5-1 hour labour Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted November 14, 2008 Report Share Posted November 14, 2008 Mechanic noticed mines was cracked when i was getting the pedal box replaced, £25 for the part and bout 0.5-1 hour labour It only takes 5 minutes to replace! Quote Link to comment Share on other sites More sharing options...
Nathan_S Posted November 14, 2008 Author Report Share Posted November 14, 2008 on the letter it said the repair should take no longer than an hour! but its free so i dont care! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 14, 2008 Report Share Posted November 14, 2008 What othe models share the part? Quote Link to comment Share on other sites More sharing options...
Unheard Posted November 14, 2008 Report Share Posted November 14, 2008 The hose on my Lupo split in the summer. I cut it shorter put the end in some hot water to refit the connector and then put a jubilee clip around it.It splits at the end from the connector thats forced into the pipe so adding a jubilee clip to a new hose should help prevent it from splitting in the future. Quote Link to comment Share on other sites More sharing options...
Niche Posted November 14, 2008 Report Share Posted November 14, 2008 According to VOSA it only affects the Polo and Lupo built from 97-99. Obviously the Seat Arosa would be involved too.VOSA (clicky)But what strikes me is that you only just got the letter. This has been a known fault for some time. Quote Link to comment Share on other sites More sharing options...
Mitchell Posted November 16, 2008 Report Share Posted November 16, 2008 03/03/2005 R/2004/211 VW LUPO,POLO,GOLF,BORA, TOURAN,NEW BEETLE,PASSAT AND SHARAN (WITH 2 PUMP INJECTOR ENGINE) bolts of the tandem fuel pump cover may break 01/03/2004 31/08/2004 Quote Link to comment Share on other sites More sharing options...
lunalupi Posted November 17, 2008 Report Share Posted November 17, 2008 (edited) I got one too - but for the donor Arosa, not the Midget......Did make me wonder that it's taken them 10 years to catch up with it, but maybe they are having another round of letters to get the ones in that weren't done the first time?But I rang SEAT and they're going to have mine in and take a look - and if it does need replacing it should be free anyway Edited November 17, 2008 by lunalupi Quote Link to comment Share on other sites More sharing options...
Jonny Posted November 17, 2008 Report Share Posted November 17, 2008 Both my lupos had this, the material becomes brittle. Scared me to death on my GTi. Easy to fix though if you survive. Quote Link to comment Share on other sites More sharing options...
andys101 Posted November 17, 2008 Report Share Posted November 17, 2008 when i worked at VW in 2000 ish i was always changing these.The pipe splits at both engs where is it fitted onto the one way valve and the servo union.Takes 5 mins to change. Quote Link to comment Share on other sites More sharing options...
Percy2&Daffyd Posted December 30, 2008 Report Share Posted December 30, 2008 this happened to my girlfriends car (engine idling fast and brakes lose their sharpness) i remembered the symptoms from my old Vauxhall viva, ha ha. Anyway it can be fixed with some 3/8" braided hose used for air conditioning drain pumps and 2 jubilee clips. Although it's a braking component it isn't a critical part, the brakes still work as good, you just have to apply more pressure to the pedal without servo assit working. Cars never used to have servo assisted brakes... how times change Quote Link to comment Share on other sites More sharing options...
TomLS Posted April 16, 2009 Report Share Posted April 16, 2009 Cars never used to have servo assisted brakes... how times change But they were designed not to have servo assist - these aren't!Somehow I spotted this thread laaaate! Any way, I just checked mine and it seems to be fine. What were the perished hoses made of? Mine appears to be a hard plastic hose, not a rubberised one.I assume this is the hose under scrutiny? Quote Link to comment Share on other sites More sharing options...
Percy2&Daffyd Posted June 8, 2009 Report Share Posted June 8, 2009 That's it, made of plastic i think, horrid stuffGet some of this on it:http://cgi.ebay.co.uk/3-8-10mm-Clear-Braid...%3A1%7C294%3A50 Quote Link to comment Share on other sites More sharing options...
Bikerz Posted September 22, 2009 Report Share Posted September 22, 2009 Audi TT also had this recall Quote Link to comment Share on other sites More sharing options...
M7R Posted October 23, 2009 Report Share Posted October 23, 2009 But they were designed not to have servo assist - these aren't! I know this is an old thread but I thought Id clear this up, by law any vehicle with a braking approval - so anything on the road basically - will have to have been checked with the servo failed to make sure it can still be stopped quick enough with an adaquate pedal pressure, ie not some big bloke stamping on it and pulling on the steering wheel too! yes it will take longer to stop than with the servo but not miles and miles longer so dont worry folks, just push that pedal harder if it goes. Quote Link to comment Share on other sites More sharing options...
Unheard Posted October 23, 2009 Report Share Posted October 23, 2009 The problem is more to do with the engine than braking, If it splits you will still be gatting vacume there will not be total loss unless the pipe falls off and the brake will only be slightly more heavy if anything you just feel a pulsating on the brake pedal. The engine will be sucking in more air than the ECU is accounting for so the engine will almost die when you come to a stop and hunt when your at a stop until the ECU can compensate. What seems to happen is you brake the engine almost stalls and then the revs shoot up as the ECU tries to compensate then once you are stopped the rev counter will be pulsating up and down morethan normal that corresponds with the pedal pulsating. Its not unique to the lupo it happens on many cars. My dad was driving a fleet car as it had the same symptoms. I don't know where they take the cars but they could not pick up on what it was so my dad was having a go at working it out. As soon as i heard the engine i could tell whatit was straight away as there was a little hiss where the air was being sucked in through the vacuum pipe and the engine was hunting. The same symptoms happen when the vapour canister purge valve is stuck open as again the engine gets more air than the sensors/ECU are accounting for at such low RPM. Quote Link to comment Share on other sites More sharing options...
si_leeds Posted March 19, 2010 Report Share Posted March 19, 2010 Could this of affected my 2000 mk1 arosa sport? Quote Link to comment Share on other sites More sharing options...
lunalupi Posted March 19, 2010 Report Share Posted March 19, 2010 It may have - the easiest thing to do is call up your local SEAT dealer and ask, they should be able to check for you and if it is affected (and hasn't already been done) they can book you in for it Quote Link to comment Share on other sites More sharing options...
si_leeds Posted March 21, 2010 Report Share Posted March 21, 2010 Sound cheers I'll ring them tomorrow Quote Link to comment Share on other sites More sharing options...
jamesb16 Posted August 28, 2010 Report Share Posted August 28, 2010 this may seem stupid but where should i look to check the condition of the hose? where abouts in the engine bay?thanksJames b 1 Quote Link to comment Share on other sites More sharing options...
99hjhm Posted September 29, 2010 Report Share Posted September 29, 2010 this may seem stupid but where should i look to check the condition of the hose? where abouts in the engine bay?thanksJames bThe hose runs from the servo(Where the brake fluid pot is attached on top of) on the drivers side, then behind the engine to the throttle body. Quote Link to comment Share on other sites More sharing options...
170bhp Posted January 7, 2011 Report Share Posted January 7, 2011 Has anyone had any luck getting the pipe replaced free of charge, if the car is not built between 98 and 99? Seems silly considering my 2000 model has the same brittle plastic pipe that the recall cars have..Dealer quoted me £86 for a servo repair kit is this correct?Thanks170BHP Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 7, 2011 Report Share Posted January 7, 2011 Has anyone had any luck getting the pipe replaced free of charge, if the car is not built between 98 and 99? Seems silly considering my 2000 model has the same brittle plastic pipe that the recall cars have..Dealer quoted me £86 for a servo repair kit is this correct?Thanks170BHP£86 lol, Unless you have full VW service history, they won't even look at the car. Or they will tell you they know nothing about the fault! (Even though VW has recalls on nearly every model at the time for the same fault)What model Lupo do you have, I will give you the part number. Quote Link to comment Share on other sites More sharing options...
170bhp Posted January 7, 2011 Report Share Posted January 7, 2011 £86 lol, Unless you have full VW service history, they won't even look at the car. Or they will tell you they know nothing about the fault! (Even though VW has recalls on nearly every model at the time for the same fault)What model Lupo do you have, I will give you the part number.Should the cost be nowhere near £86? They quoted for a servo repair kit?-is this anything more than the basic pipe which needs to be replaced? Its a 2000 1.4 Sport.thanks170 Quote Link to comment Share on other sites More sharing options...
