lupo pd 150 Posted May 12, 2008 Author Report Share Posted May 12, 2008 soz but no pics of it getting built was just trying to get it done asap.Mick, here you have been busy with a polo! looking forward to see it, should look good Quote Link to comment Share on other sites More sharing options...
lilmicky Posted May 12, 2008 Report Share Posted May 12, 2008 should pop down sum time mate its lookin awesomeill av to keep my eye out for your lupo mind, dont wanna be left in a puff of soot though Quote Link to comment Share on other sites More sharing options...
lupo pd 150 Posted May 13, 2008 Author Report Share Posted May 13, 2008 (edited) I have fitted a plug in tuning box today, going to use this until i put the modified turbo on and get it mapped properly.Going off the results of this tuning box i think i am going to be happy with the end result as it is now goes like stink for a tdi just with the box fittedAlso thanks for all the positive comments on the conversion Edited May 13, 2008 by lupo pd 150 Quote Link to comment Share on other sites More sharing options...
orla Posted May 15, 2008 Report Share Posted May 15, 2008 What did the engine come out of a mk4 golf or a seat ibiza?did you not find it a tight squeeze trying to get everything to fit, i no a guy who did a pd130 conversion into a mk3 golf and had to relocate the battery to the boot, oh and what clocks you using? Quote Link to comment Share on other sites More sharing options...
chris260 Posted May 15, 2008 Report Share Posted May 15, 2008 Awesome conversion! Looking forward to seeing this at a north east meet, might persuade me to keep my lupo!! Quote Link to comment Share on other sites More sharing options...
willcrook Posted May 15, 2008 Report Share Posted May 15, 2008 would love to see the 530d engine in a lupo Quote Link to comment Share on other sites More sharing options...
Adam Posted May 15, 2008 Report Share Posted May 15, 2008 I mirror everybodies words, this is such a good conversion and i'm pleased its pretty local, so i can get a good look at it at a meet in the near future. Quote Link to comment Share on other sites More sharing options...
lupo pd 150 Posted May 15, 2008 Author Report Share Posted May 15, 2008 some parts of the engine are from a golf, others are from a passat (cylinder head) It was a bit of a tight fit, Had to notch the leg on the ns to clear the 6 speed box,going to remake the lower gearbox dogmount as i am not happy itAlso finding the powerflex insert is very harsh.I am using lupo gti clocks Quote Link to comment Share on other sites More sharing options...
karl Posted May 20, 2008 Report Share Posted May 20, 2008 Hello Mr PD150 when you get a chance would you mind posting up the VW part numbers for the mounts you used , i would also would be interested in knowing what you done for drive shafts did you have to get custom made ones or have you made up a VW hybrids using the lupo shaft and the inner cv from the Golf .Thanks KarlPs have you timed the car for 0- 60 50 - 70 and so on although i am guessing that it will be seriously quick accelerating once above 30 mph ! 1 Quote Link to comment Share on other sites More sharing options...
willcrook Posted May 20, 2008 Report Share Posted May 20, 2008 how about pics so we know you arent telling lies Quote Link to comment Share on other sites More sharing options...
simpo Posted May 20, 2008 Report Share Posted May 20, 2008 Page 2, mate Quote Link to comment Share on other sites More sharing options...
lupo pd 150 Posted May 20, 2008 Author Report Share Posted May 20, 2008 Hello Mr PD150 when you get a chance would you mind posting up the VW part numbers for the mounts you used , i would also would be interested in knowing what you done for drive shafts did you have to get custom made ones or have you made up a VW hybrids using the lupo shaft and the inner cv from the Golf .Thanks KarlPs have you timed the car for 0- 60 50 - 70 and so on although i am guessing that it will be seriously quick accelerating once above 30 mph ! Hi, I will dig out the part numbers when i get into work tomorrow, I used a mk3 golf tdi shaft for the drivers side (100mm inner joints to match the 02S gearbox that i used) with the lupo outer joint fitted,perfect length.I had to shorten a passenger side shaft by a couple of inches and again used lupo outer joint and 100mm inner.Not sure what kind of times this thing would pull,but they should be reasonable Quote Link to comment Share on other sites More sharing options...
karl Posted May 20, 2008 Report Share Posted May 20, 2008 I thought that the PD150 lump had the bigger ( vnt 17 ) turbo that was good for 220 ish coulnt tell you how long it would last though , as i have a PD130 lump in my garage with two ECUs one which has been de coded and mapped for about 215 Bhp but i need to change the turbo from the 130 ( vnt 15 ? ) to the 150 ( vnt 17 ) which i have also got stashed away .So Mr PD150 what turbo will you be going for and how much Bhp are you going to run with it ?I also ment to ask why you ditched the EGR buisness ?Did you think about getting a re map to 180 standard turbo should be reliable at that level . ( for the meantime )http://www.superchips.co.uk/curves/vag150pd.pdf Quote Link to comment Share on other sites More sharing options...
lupo pd 150 Posted May 21, 2008 Author Report Share Posted May 21, 2008 I thought that the PD150 lump had the bigger ( vnt 17 ) turbo that was good for 220 ish coulnt tell you how long it would last though , as i have a PD130 lump in my garage with two ECUs one which has been de coded and mapped for about 215 Bhp but i need to change the turbo from the 130 ( vnt 15 ? ) to the 150 ( vnt 17 ) which i have also got stashed away .So Mr PD150 what turbo will you be going for and how much Bhp are you going to run with it ?I also ment to ask why you ditched the EGR buisness ?Did you think about getting a re map to 180 standard turbo should be reliable at that level . ( for the meantime )http://www.superchips.co.uk/curves/vag150pd.pdfBoth the 130 ASZ ans the 150 ARL have vnt 17's just different versions thats all.Just trying to do a deal on a hybrid turbo at the moment, would like around 350lbft.220 bhp out of a ARL turbocharger, thats a bit optimistic Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 27, 2008 Report Share Posted May 27, 2008 Did you think about getting a re map to 180 standard turbo should be reliable at that level . ( for the meantime )Should be able to get around 195bhp from the 150pd engines. Also - The 150 and 130 both use the same turbo charger. Quote Link to comment Share on other sites More sharing options...
lupo pd 150 Posted July 11, 2008 Author Report Share Posted July 11, 2008 Allards Hybrid turbo has now turned up!! The one on the left is same size as whats fitted now Quote Link to comment Share on other sites More sharing options...
cardaft Posted July 11, 2008 Report Share Posted July 11, 2008 Thats a bit turbo!How much will that add, roughly? Quote Link to comment Share on other sites More sharing options...
lupo pd 150 Posted July 11, 2008 Author Report Share Posted July 11, 2008 Its a vnt 17/20 hybrid from allard, Should be good for 200+hp and 340+lbs/ftI will get this fitted soon with a different gearbox with a taller diff as i am finding the gearing touran unit far too low Quote Link to comment Share on other sites More sharing options...
nfbr Posted July 11, 2008 Report Share Posted July 11, 2008 Its a vnt 17/20 hybrid from allard, Should be good for 200+hp and 340+lbs/ftI will get this fitted soon with a different gearbox with a taller diff as i am finding the gearing touran unit far too lowNice... Thats pretty much what I'm after for the bora I'm guessing the compressor housing is off the VNT20, and the exhaust side of the 17? Quote Link to comment Share on other sites More sharing options...
Boy'dup Posted July 11, 2008 Report Share Posted July 11, 2008 Lag much Quote Link to comment Share on other sites More sharing options...
lupo pd 150 Posted July 11, 2008 Author Report Share Posted July 11, 2008 yes mate,spot on. Quote Link to comment Share on other sites More sharing options...
jon_273 Posted July 11, 2008 Report Share Posted July 11, 2008 Ahh nice, I bet you've been dying to fit this!It definitely needs some taller gearing though, first was pretty much pointless wasn't it Quote Link to comment Share on other sites More sharing options...
Boy'dup Posted July 11, 2008 Report Share Posted July 11, 2008 although i bet its gonna kick like buggery when it does spool up Quote Link to comment Share on other sites More sharing options...
lupo pd 150 Posted July 11, 2008 Author Report Share Posted July 11, 2008 Lag much We will see but it starts making boost at around 1100rpm now with a standard turbo,there has been alot of people drive it since the conversion and none of them can believe how responsive it is at the moment Quote Link to comment Share on other sites More sharing options...
Boy'dup Posted July 11, 2008 Report Share Posted July 11, 2008 We will see but it starts making boost at around 1100rpm now with a standard turbo,there has been alot of people drive it since the conversion and none of them can believe how responsive it is at the momenttbh thats impressive, very nice, overall a cracking motor.whats the handling like with the weight? Quote Link to comment Share on other sites More sharing options...
