scotty_82 Posted March 4, 2011 Report Share Posted March 4, 2011 Will do when I get home tonight mate. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted March 4, 2011 Report Share Posted March 4, 2011 There are two lines to the rear and one to each front all off the ABS blcok, so I would redo the whole issue, T it off at the rear. Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted March 5, 2011 Author Report Share Posted March 5, 2011 As i thought. New pipes it is, need to find my pipe bender..... Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted March 8, 2011 Author Report Share Posted March 8, 2011 So ive been doing a little bit here and there.....Currently trawling through wiring diagrams working out which of the ECU, ABS, airbag and aircon wires i can delete completely. Looks a little bit like this Quote Link to comment Share on other sites More sharing options...
NOCK Posted March 8, 2011 Report Share Posted March 8, 2011 So ive been doing a little bit here and there.....Currently trawling through wiring diagrams working out which of the ECU, ABS, airbag and aircon wires i can delete completely. Looks a little bit like this My stomach would turn if I got to that point, that is going to take some putting back together!Why are you trying to delete cabling, to save weight...or....? Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted March 8, 2011 Report Share Posted March 8, 2011 good luck john! Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted March 8, 2011 Report Share Posted March 8, 2011 And I thought swaping a headunit was hard.This is gonna be awesome when its done, again lol. Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted March 8, 2011 Author Report Share Posted March 8, 2011 Wait till you see what ive done with the engine bay.... Quote Link to comment Share on other sites More sharing options...
Bradley Posted March 22, 2011 Report Share Posted March 22, 2011 Plans sound superb,look foward to following the thread in the future and seeing the great standard of work finished.You could become an Openreach engineer after rewiring your loom haha. Quote Link to comment Share on other sites More sharing options...
treblet Posted March 22, 2011 Report Share Posted March 22, 2011 Any more new pictures of it in a million pieces across the inside of the tent? Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted March 22, 2011 Author Report Share Posted March 22, 2011 Any more new pictures of it in a million pieces across the inside of the tent?Ummmmm got pictures of some wires......So i took out the heater and aircon unit so i could get to he loom, got to trace some more A/C wires back, it think they go to the fan module that im pretty much going to be loosing anyhow and using a simple fan relay setup with motor sport fans (dunno what makes them motor sport ones ) Need to do the front of the engine loom which has all the injector wiring that i don't use, various sensors that i have my own wires to and the lambada sensor. So that should be fairly easy, Going to have a good day on it on thursday. Then ive got to get the steering column out and take the peddle box out, and get to the back of the relay board and fuse box, to remove what i don't need from there (4-5 fuses). Quote Link to comment Share on other sites More sharing options...
treblet Posted March 22, 2011 Report Share Posted March 22, 2011 I fancy some spaghetti now! Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted March 22, 2011 Report Share Posted March 22, 2011 Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted March 22, 2011 Report Share Posted March 22, 2011 :confused: I have no idea what is going on in any of those pics lol Quote Link to comment Share on other sites More sharing options...
fatttty Posted March 23, 2011 Report Share Posted March 23, 2011 Jeez John, you have gigantic balls. Im sweating about taking my dash board out. I'd die if i had to do that!Great to see it moving along though. Keep it up mate Quote Link to comment Share on other sites More sharing options...
treblet Posted March 23, 2011 Report Share Posted March 23, 2011 Jeez John, you have gigantic balls.Hey Arnold! Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted March 26, 2011 Author Report Share Posted March 26, 2011 So I was taking more wires out and then I'm thinking of a cool little idea..... John Quote Link to comment Share on other sites More sharing options...
Pete Posted March 26, 2011 Report Share Posted March 26, 2011 2 x Co2 shots out the front grille?? Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted March 29, 2011 Author Report Share Posted March 29, 2011 Cough....This is one trick bit of gear. And its going to be easier to get that to work than my clocks, so the decision has been made, im going digital!!John Quote Link to comment Share on other sites More sharing options...
marcusgrant Posted March 29, 2011 Report Share Posted March 29, 2011 that will be very cool will it be able to show everything that your current dials display? like fuel level, outside temperature? Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted March 29, 2011 Author Report Share Posted March 29, 2011 Yeah it will be good, gotta chop the dash about though to make it look right, then obviously have ti all trimmed after. But i think i can pull it off.It really does make sense to do it, the wiring job has become a lot easier now the clocks and ecu are going. Canbus can be totally removed now and i don't need to worry about it, saying that i do need to have a look in to the immobiliser and central locking modules, as they still need power. But ive had them working with the clocks and ecu unplugged before.Just gonna take my time with it.I am setting it up to do:Rpm, speed, gear selection, Oil pressure/temp, water temp, boost pressure, air temperature, AFR, EGT.Thats all i should need in front of me, it has loads more you can connect up. Plus data logging if you want it.John Quote Link to comment Share on other sites More sharing options...
fatttty Posted March 29, 2011 Report Share Posted March 29, 2011 sounds great John Quote Link to comment Share on other sites More sharing options...
99hjhm Posted March 30, 2011 Report Share Posted March 30, 2011 Thats a good idea that is John.....Dunno why you didn't think of it before. lol Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted March 30, 2011 Author Report Share Posted March 30, 2011 Must have forgotten about it lol Quote Link to comment Share on other sites More sharing options...
dj_lupz Posted March 30, 2011 Report Share Posted March 30, 2011 I Like Quote Link to comment Share on other sites More sharing options...
