CLAYTONJONES
Clayton's Tornado Red GTI..
1 minute ago, tttttada said:
In the video he mentions you have a lightweight flywheel? Mind sharing which brand flywheel it is?
It’s made by a company called Epytec in Germany
Awesome setup you got there, nice little track weapon. I followed it closely and i like what you did, nice build. Keep it like that. On the track it looks like the car is moving really nice, with neutral behavior and very little understeer. How many laps could you squeeze out of the AD08R's until overheating them?
Cheers appreciate the nice words👍🏼
The rear anti roll bar really helps with understeer, the car rotates nicely when you need it to as well.
When i was really pushing them i find around 6-7 laps of Snetterton then you can feel them stary to over heat. I tend to about 5 at a time, seems to be the sweet spot.
The latest little mod, fitted a 7 row oil cooler Saturday. The car has never struglled with heat but with two Nürburgring trips coming up in the summer I thought why not, better to be safe than sorry! I’m going to paint it Black as i’m not keen on the way it stands out behind the bumper.
Its a great upgrade, looks like a Mocal? thermostatic oil filter plate?
Do you already have oil temperature gauge set up? I am interested in what temperature the AVY oil runs at - suspect its little hot head! I have some genuine VAG VDO gauges I need to fit in the space next the radio.
Mine is 13 row, a hand-me-down from my old Mk3 Gti. Sized for 2 litre 150 bhp ABF engine, the standard dash could be set to show oil temp, before cooler on motorway it would spike to over 120c after cooler it was a rock steady 90c.
I'm sure painting it will assist with heat dissipation.
MCM did a back to back air temperature test with an intercooler, they tested raw aluminium and then painted the same one black - in fact:
- the result was cooler when black
Of course it is.
Pc world now.
id recommend a thermostat in your oil cooler system, otherwise it'll take ages to get up to temperature and could cause more harm than good. Mocal do one in their sandwhich plate, or mishimoto do a serpate unit
Looking good though,
What was the reason behind the R32 wishbone bushes over powerflex ones?
A mate of mine had this and said I could have it, so i thought i’d try it without first. The car will only get driven properly once I know the oil is up to temperature.
The reason for the R32 bushes is purely because they are softer than Powerflex but stiffer than standard. The whole idea with this car is to make it a really good road and decent on the track. So I don’t want it too stiff 👍🏼
No real big updates lately,
I fitted some Ferodo DS1.11's a week ago, after using the DS2500's with the standard calipers and always being pleased with them I thought i'd try the next step up and go for the 1.11's. First impressions are really good, even on the road. The initial bite is something i've never felt before in any car. The car weighing only 920kg obviously helps but they really do stop the car well now. I go to the Nurburgring on Easter weekend so only a few weeks away, they will get a proper test there!
Other than that i've just been enjoying the car in the nice weather recently. I'll leave some pictures below.
Edited by CLAYTONJONES
Did you keep the 60V injectors on your R36 conversion?
If you fire them on the in stroke (lean), then fire again about 20 degrees after TDC (once ignited), you get a double kick. It was the original concept behind FSI. Lots more torque... The hardest thing to manage is the common rail high pressure fuel pump.
Yeah with a supercharger you can get about 550. Trouble is at high revs you run out of injector time.
Learn something new every day!
It’s currently turbo’d at around 400bhp, only around 9psi of boost. Needs a 4” MAF then the boost can be turned up.
So, another set of wheels. I have been wanting these for a very long time. Enkei RPF1. They are currently grey but i will be changing them to Silver in the future. They came with new near Toyo T1R’s which I hate but i will run them for a few weeks before they come off. Well happy with how they look though!
Also, i go to the Nürburgring tomorrow! So i’ll update this after the trip!
4 minutes ago, imaparana said:
Agreed on the Toyo's, any awful tyre, maybe try and swap out while your out there
They really are! I’m taking my OZ’s with AD08R’s on them with me so will swap them over when i’m there👍🏼
Good plan, do you get any rubbing with the 195/50/15's ?
