mukilupo Posted February 14, 2008 Report Share Posted February 14, 2008 LUPO GTI 02 ,22.000 miles,have had the car 9 months FVWSH,problem is every morning when engine cold the car jerks for 1-3 minutes than ok for rest of the day.I normally warm the car up before i drive,but not very practical.Someone suggested changing coolant temperature sensor £26.00 from VW which i did, but no difference.Please help. Quote Link to comment Share on other sites More sharing options...
cardaft Posted February 14, 2008 Report Share Posted February 14, 2008 Plugs and leads maybe?Although that should effect it all the time not just when the car is cold. Quote Link to comment Share on other sites More sharing options...
Philplop Posted February 14, 2008 Report Share Posted February 14, 2008 Kangarooing when the engine is cold is a GTI trait. Just have to live with it I think.Does my tits in though. Quote Link to comment Share on other sites More sharing options...
mukilupo Posted February 14, 2008 Author Report Share Posted February 14, 2008 Thanks for your replies,but i have had plugleads checked all ok plus new NGK plugs.HELP............... Quote Link to comment Share on other sites More sharing options...
MattTDI Posted February 14, 2008 Report Share Posted February 14, 2008 Kangarooing when the engine is cold is a GTI trait. Just have to live with it I think.Does my tits in though.thats a bit crap really lol Quote Link to comment Share on other sites More sharing options...
mukilupo Posted February 14, 2008 Author Report Share Posted February 14, 2008 Surely if you spent £13.700 on a new GTI one would not expect this from the father land.It must be something or fault as the car gets older maybe beyond 3-4 years.Has anyone bought GTI from NEW had this problem? Many thanks again. Quote Link to comment Share on other sites More sharing options...
Silver! Posted February 14, 2008 Report Share Posted February 14, 2008 My '54 plate does it also. Got worse in the colder weather.I'm going for new plugs, leads etc at the next service, but from what I read on here its a characteristic of the cheeky little chimp! Quote Link to comment Share on other sites More sharing options...
Dark Posted February 14, 2008 Report Share Posted February 14, 2008 its accepted as normal for gti. Quote Link to comment Share on other sites More sharing options...
Joe Posted February 14, 2008 Report Share Posted February 14, 2008 Normal GTi behaviourAdds to character You justhave to learn to be gentle and smooth with clutch for the first few minutes. Quote Link to comment Share on other sites More sharing options...
mukilupo Posted February 14, 2008 Author Report Share Posted February 14, 2008 Thanks again,i am not convinced.More feedback please. Quote Link to comment Share on other sites More sharing options...
Joe Posted February 14, 2008 Report Share Posted February 14, 2008 You might not be convinced, but I don't think I've ever met a GTi owner that doesn't get it.As soon as its even mildly warm it won't happen. Quote Link to comment Share on other sites More sharing options...
mukilupo Posted February 14, 2008 Author Report Share Posted February 14, 2008 As mentioned had the car 9 months summer/winter no difference.My friend has a GTI - 01 plate 5 speed with no problems.Many thanks. Quote Link to comment Share on other sites More sharing options...
Clairey Fairy Posted February 14, 2008 Report Share Posted February 14, 2008 Trust us, its a characteristic of the GTi, they all do it.Doesnt happen all the time, you just have to be a fairy with the clutch until the kangaroo juice has worked its way out.Ive had it really bad a couple of times and thaught i was on a one way ticket through the windscreen You'll learn to live with it Quote Link to comment Share on other sites More sharing options...
mukilupo Posted February 14, 2008 Author Report Share Posted February 14, 2008 Thanks for all your replies,to convince me can someone whos owned the GTI from new please let me know.Thanks again. Quote Link to comment Share on other sites More sharing options...
Adam Posted February 14, 2008 Report Share Posted February 14, 2008 Well i've owned mine from 3,500 miles and it was a year old when i bought it. It is a common problem i'm afraid, although mine isn't as bad as it used to be, infact it doesn't do it that much and when it does i just open the clutch for a second then engage it again and all is fine. Quote Link to comment Share on other sites More sharing options...
Philplop Posted February 14, 2008 Report Share Posted February 14, 2008 Mine seems to have been worse than usual just recently, maybe its this 'in-between' weather that's causing it, as it's been ok most of the winter. Quote Link to comment Share on other sites More sharing options...
mukilupo Posted February 14, 2008 Author Report Share Posted February 14, 2008 Had a quick chat to someone VW garage,possible causes air-mass meter,throttle body,coolant temperature sensor which we changed which made no difference.I was then told by the garage there are two coolant sensors.The search goes on.Thanks. Quote Link to comment Share on other sites More sharing options...
Adam Posted February 14, 2008 Report Share Posted February 14, 2008 (edited) I really don't think you will cure it, i have had a couple of sensors changed under warrenty when my engine check light came on when i first bought, i also had the throttle body cleaned and it still does the kangarooing, not as often as it used to i may add, but every now and again. Edited February 14, 2008 by Adam Quote Link to comment Share on other sites More sharing options...
matt~black Posted February 14, 2008 Report Share Posted February 14, 2008 it's a gti just learn to drive smoothly i've got it down to an art but i know it still does it because every garage i go to the kangaroo the buggery out of it Quote Link to comment Share on other sites More sharing options...
MattTDI Posted February 14, 2008 Report Share Posted February 14, 2008 that my friend is what you call an avatar Quote Link to comment Share on other sites More sharing options...
vworks41 Posted February 14, 2008 Report Share Posted February 14, 2008 I've had three GTi's one from new and they've all been the same. Although the 5speed which was my first one wasnt as bad.I've been told its to do with the fly by wire throttle and how theyre maped when cold.It's a real pain some times! but as already said just keep it smooth Quote Link to comment Share on other sites More sharing options...
bossjohnc Posted February 14, 2008 Report Share Posted February 14, 2008 Another for the 'mine does it too' box. Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted February 14, 2008 Report Share Posted February 14, 2008 My Polo GTI does the same. Quote Link to comment Share on other sites More sharing options...
Dark Posted February 14, 2008 Report Share Posted February 14, 2008 my gti does it, just to add. Quote Link to comment Share on other sites More sharing options...
mukilupo Posted February 14, 2008 Author Report Share Posted February 14, 2008 Well i am amazed,so many gti /polo drivers have the same prolem.My Vw garage in Watford are kindly going to find out what the answer is, may check with old school mechanics.Keep you posted. Quote Link to comment Share on other sites More sharing options...
