littlekev
GTi rear axle removal
Hi all, planning removing my rear axle to refurb it and will change bushes at the same time. The retaining nuts and bolts look pretty corroded. Im thinking i should just cut the bolts with a grinder/hacksaw or has anyone any better ideas? The cars in my garage so dont have the luxury of a ramp..
Ok, forget the above. Thought I would try and loosen it with a spanner and surprise surprise it worked. Back to work tommorrow for a few days then I'll remove it and send it for shotblasting.
Nice one, the main thing is find a well fitting spanner or socket (try and find 6 sided for rusty stuff) right off the bat so as not to round it off and then make it 10x harder to remove.
I have to do mine soon as well.
Edited by Sausage
Those look very close to the limit, good job undoing them -Another shout for plusgas
brake flex’s can be tough to remove, easy to snap off the line -  you need to look at undoing them too, mine were looking old so I just cut them
I used wurth rost off and left it for a few hours. Was amazed it came off. Got new brake lines anyway so I'll just cut them off if they dont come off. Was going to coat mounts with hammerite then silver paint before rebuilding or any other suggestions?
I trust new nuts and bolts is a given?
Source new clips for ABS cables, brake lines -  it is very likely the current ones will shatter when you try to remove them.
I sourced some really cheap mk4 brake lines for the run down the beam, they do work, but need a bend to reduce the length - they turned up and were cunifer line with stainless connections -complete bargain.   Seem to recall I posted a link a link to them in my build, but that was 18 months ago...ish!
I would go with rust converter then paint.
What bushes are you planning to use?
Getting the old bush out is fun - drill out the rubber around centre bush, hammer out centre and then carefully saw into the metal outer  - the width of the blade will release the tension.
if you chop the hoses plan how you are going to block them off, I didn’t do that and had a bit of bother bleeding mine after they had bled out completely
bearings can be troublesome to come off - if your lucky they will come off in one go and not need replacement, I was unlucky and one split, last attempt at MOT it came out as an advisory. May be good to budget for new bearings
Yeah new bolts etc, had read about the mk 4 brake lines but wasnt too sure. If theres a big saving I'll probably go for them. Thanks for the advice, I'll update in a few weeks when I get time to get it removed and stripped. Not sure about bushes yet, standard or poly?? Cars going to be pretty much standard apart from coilovers as they are cheaper than standard setup.
Edited by littlekev
If you go for mk4 lines - the only other thing is the banjo block needs filling down to fit the Lupo brake caliper.
just looked in my eBay history, these look similar 401258918527 £30 for a pair
Primed and first coat of paint, need to wait til shops open before I get more paint. Need to rub down and paint axle mounts on car before fitting it.
