FormerCarVirgin Posted September 9, 2017 Report Share Posted September 9, 2017 Hi first post. I got my first car a few months back. Bought it cheap to learn to drive in. One problem is the exterior locks on both doors are falling out. As you can see i can bang them back in but someone could easily pull them out and walk off with them at the moment ? Anyone know a quick cheap fix that will get them more secure? Quote Link to comment Share on other sites More sharing options...
Rich Posted September 9, 2017 Report Share Posted September 9, 2017 there is a screw inside the door which turns a metal ring which locks the lock in place. 1 Quote Link to comment Share on other sites More sharing options...
weslangdon Posted September 10, 2017 Report Share Posted September 10, 2017 13 hours ago, Rich said: there is a screw inside the door which turns a metal ring which locks the lock in place. but its easily damaged and often doesn't work, when that happens use an epoxy glue Quote Link to comment Share on other sites More sharing options...
Rich Posted September 10, 2017 Report Share Posted September 10, 2017 2 hours ago, weslangdon said: but its easily damaged and often doesn't work, when that happens use an epoxy glue no wonder you are having lock issues. if it doesn't work then you fish the rings out the door and rebuild the mechanism. Quote Link to comment Share on other sites More sharing options...
weslangdon Posted September 10, 2017 Report Share Posted September 10, 2017 6 hours ago, Rich said: no wonder you are having lock issues. if it doesn't work then you fish the rings out the door and rebuild the mechanism. Quote Link to comment Share on other sites More sharing options...
Skezza Posted September 11, 2017 Report Share Posted September 11, 2017 18 hours ago, Rich said: no wonder you are having lock issues. if it doesn't work then you fish the rings out the door and rebuild the mechanism. This. It's a pain but not hard hard. It's a torx and is different to the others holding the mechanism. Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted September 11, 2017 Report Share Posted September 11, 2017 (edited) And as the famous Haynes manual says, fitting is the opposite of removing. Edited September 11, 2017 by lupogtiboy 1 Quote Link to comment Share on other sites More sharing options...
FormerCarVirgin Posted September 26, 2017 Author Report Share Posted September 26, 2017 On 9/11/2017 at 0:19 PM, lupogtiboy said: And as the famous Haynes manual says, fitting is the opposite of removing. Thanks but even when I tighten that screw the lock is still loose and can be pulled straight out so guessing it's more complicated The guy i bought it from mentioned the lock and gave me the replacement he hadn't yet fitted. It looks complicated to fit. Any ideas if a decent mechanic could fit it cheaply or is it doable for a novice like me? ? Quote Link to comment Share on other sites More sharing options...
cj1 Posted September 26, 2017 Report Share Posted September 26, 2017 The issue isn't with the part in your photo. It's the "lock carrier" that you require. Find one in a breakers or even VW they're not too bad. Easier to just get a new one if you're not technically/mechanically minded. There's a guide on here for how to change it, or if you're struggling I'm sure one of us can write it out step by step for you. Essentially the barrel is keyed and will only slide in one way. Once it's in, you tighten that screw up and it turns a ring inside that blocks the extruded parts of the barrel, thus meaning it can't be removed. Have you tightened the screw as far as it will go without utilizing gorilla strength? 2 Quote Link to comment Share on other sites More sharing options...
cj1 Posted September 26, 2017 Report Share Posted September 26, 2017 And "is it doable for a novice?" Anything is possible depending on how much effort you're willing to put in. It isn't a particularly hard job by any means. 1 Quote Link to comment Share on other sites More sharing options...
Rich Posted September 26, 2017 Report Share Posted September 26, 2017 step one, remove lower door card.and go fishing inside the bottom of the door for a semi circle. 1 Quote Link to comment Share on other sites More sharing options...
FormerCarVirgin Posted September 28, 2017 Author Report Share Posted September 28, 2017 I removed the door card and found that (attached) assuming it's the semi-circle. Proving difficult to fit, assuming the window needs to be up to give me space and does the screw need to be loosened? Quote Link to comment Share on other sites More sharing options...
Rich Posted September 28, 2017 Report Share Posted September 28, 2017 take the whole handle/lock assembly off and do it off the car. it will all explain itself when it is off. Quote Link to comment Share on other sites More sharing options...
Andrew1971 Posted September 29, 2017 Report Share Posted September 29, 2017 If you have electric windows disconnect the battery. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 29, 2017 Report Share Posted September 29, 2017 13 minutes ago, Andrew1971 said: If you have electric windows disconnect the battery. why? Quote Link to comment Share on other sites More sharing options...
Andrew1971 Posted September 30, 2017 Report Share Posted September 30, 2017 When my lock broke not knowing how to get it out. I took top door card off started fiddling with lock when window went down on my hand and trapped it. It hurt well apparently it's a safety feature !! if it is a real one and my window work's fine. Andrew Quote Link to comment Share on other sites More sharing options...
FormerCarVirgin Posted September 30, 2017 Author Report Share Posted September 30, 2017 (edited) On 9/28/2017 at 11:31 PM, Rich said: take the whole handle/lock assembly off and do it off the car. it will all explain itself when it is off. It has manual windows. I took the external handle off after unclipping the black connector and then took the lock barrel out. Do I need to take the whole lock mechanism out (like the replacement lock i posted before) or is it just the barrel part? When I clip the semi circular thing to the lock barel when it's not in the door it fits perfect and secure. When I try and do the same when fitting it to the door it just comes loose again. Not much room to work with inside the door. Very annoying Edited September 30, 2017 by FormerCarVirgin Quote Link to comment Share on other sites More sharing options...
Rich Posted September 30, 2017 Report Share Posted September 30, 2017 the barrel/handle mech is all removable for repair. i would give you a step by step but it has been so long since i have done it i cant remember it all. Quote Link to comment Share on other sites More sharing options...
cj1 Posted October 2, 2017 Report Share Posted October 2, 2017 (edited) Remove lock barrel (Shouldn't be an issue here lol) In the side of the handle closest to where the barrel would be is a cable clipped in - note where it is set and remove it with a small screwdriver Remove handle, pull it towards the rear of the car and outwards simultaneously, if it doesn't come freely you can peep inside the door and see how the end closest to the rear of the car attaches. There's a small torx screw now visible, remove this and the carrier will come out. Fitting is the opposite to removing. Remember to tighten the t20 bolt that holds the barrel in place. Not the most descriptive but again, it's been a while and it makes sense to me! Edited October 2, 2017 by cj1 1 Quote Link to comment Share on other sites More sharing options...
Rich Posted October 2, 2017 Report Share Posted October 2, 2017 makes sense to me. Quote Link to comment Share on other sites More sharing options...
FormerCarVirgin Posted October 2, 2017 Author Report Share Posted October 2, 2017 7 hours ago, cj1 said: Remove lock barrel (Shouldn't be an issue here lol) In the side of the handle closest to where the barrel would be is a cable clipped in - note where it is set and remove it with a small screwdriver Remove handle, pull it towards the rear of the car and outwards simultaneously, if it doesn't come freely you can peep inside the door and see how the end closest to the rear of the car attaches. There's a small torx screw now visible, remove this and the carrier will come out. Fitting is the opposite to removing. Remember to tighten the t20 bolt that holds the barrel in place. Not the most descriptive but again, it's been a while and it makes sense to me! Thanks guys. I removed the whole thing. I'm assuming the attached images is how it should be. Problem is would it be possible to fit the completed lock and handle back through the door without deassembling it? or do I have to blindly do it (fiddle my hands through the door until the gold cap moves perfectly into place) Strange that none of the diagrams I found online seem to have the gold semi circle thingy Quote Link to comment Share on other sites More sharing options...
Rich Posted October 2, 2017 Report Share Posted October 2, 2017 put the mech in with gold thing, attach handle, slide barrel in, lock barrel in place Quote Link to comment Share on other sites More sharing options...
FormerCarVirgin Posted October 3, 2017 Author Report Share Posted October 3, 2017 (edited) 19 hours ago, Rich said: put the mech in with gold thing, attach handle, slide barrel in, lock barrel in place Thanks Rich and everyone who helped. finally got it in and fixed. It's secure although the lock barrel pops out slightly when I pull the handle but it's not going anywhere. Maybe because the flimsy plastic paint protecter/frame thingy fell off when I was doing it and I never put it back. Anyway job done When doing it I noticed a disconnected cable in the door. Probably a dumb question but does anyone know what's it's off? The side speaker is already connected (see attached) Now the only major issue I have is that the oil sensor light randomly comes on when I'm driving even though the oil level is fine. When I do the ignition/button trick the light temporarily comes off for a while but comes back. Guessing the oil sensor needs replacing Edited October 3, 2017 by FormerCarVirgin Quote Link to comment Share on other sites More sharing options...
Rich Posted October 3, 2017 Report Share Posted October 3, 2017 single wire in it? flashy door pin? yes, you do need that flimsy thing (gasket) Quote Link to comment Share on other sites More sharing options...
DeirdreGill Posted July 24, 2021 Report Share Posted July 24, 2021 (edited) This is my process. Remove car lock - one hex socket behind blank indoor. Dissemble lock assembly by depressing the central paddle and allowing the retaining ring to slide out. (careful it's spring-loaded). Purchase Polo replacement lock part and file off central lug until flush. I also trimmed down the other two lugs as they were a millimeter or so longer than the broken part. I also replaced the spring. To assemble tension spring around the central post and engage ends around lugs on replaced lock part. Replace top retaining ring and push locking ring into position, ensuring small lugs from paddle slot into it to retain in position. Edited July 26, 2021 by DeirdreGill Quote Link to comment Share on other sites More sharing options...
