James_VW
James's Lupo - Ketty
Hey Everyone, I'm James, bought a 1.4 Jazz Blue Lupo (75BHP) as my first car last year, somehow the car got the name ketty :innocent:
Been lurking around club Lupo for a while, so thought I would share :wave:
First Pictures of the car when purchased.
Found some very cheap BBS RX2's locally (Cheap for a reason... previous owner did a rubbish home DIY)
Next was to service it with oil, oil filter, spark plugs, fuel filter and coolant.
Oil Sensor switch failed so this was changed.
The rusty drum brakes were now showing due to the alloys, so they got a lick of paint as well as the wheel bolts.
As the car was getting cleaned regularly, I decided to purchase a snow foam lance. Bodywork isn't in the greatest of conditions, but look at improving this later on.
All was good until the gearbox started to make a whining noise, Gearbox oil was changed, hoping to prolong the life of the box. (gearbox oil reeks)
Whining noise had subsided a little, but a month or so later it failed, sounded like a bag of spanners, then all drive was lost. Managed to find a new gearbox with 59K miles on it. Had this replaced along with a new clutch. Got back the old gearbox, drained the oil to find 1cm chunks of metal , This is stored for a possible rebuild later on.
Wanted to improve the breaking so picked up some HEL braided brake lines. (These were fitted a long time later)
Looked at a few threads were people cleaned behind the arch liners, so decided to give it a clean, quite shocked as to what I found :surprised: All was cleaned and liner screws were replaced.
Behind the rear lights was also cleaned.
Next failure which I had was the thermostat housing had broke, Luckily it was a quick and easy fix.
Not much had happened to the car around this time, until a local VW breaker got hold of a Laser Blue Lupo Sport! Unfortunately it was a complete write off.
On the bright side, I picked up a few parts.
Interior seats, full rear disc beam, front brake set-up, fog valance, coilovers, rear sport bumper, exhaust system and boot floor.
The seats look same as the GTI model, are 05 Lupo Sport seats the same?
The first job was fitting in the lower fog lights. Followed a few guides on here and the fogs went in easy enough :clap:
Next up was cleaning up the front hubs, they was shot blasted, primed, painted and had new bearings pressed in. When the bearings was pressed out, one of the hubs had scarring from previous bearing changes, this got swapped to a cleaner one.
Callipers and carriers was cleaned up and painted.
Then came the time to fit it... (bearing in mind I'm no mechanic) I got to this point and thought, Oh :censored: what have I done :tongueout:
Carried on going, and eventually finished.
Was just about to pack down and the great English weather kicked in :rant:
Couple of weeks later got round to fitting coilovers, gave them a very quick clean up.
Again all was good :thumbup: untill I had a meeting with a curb :swerve: outcome? Bent left rear alloy, bent rear beam, Track rods and track rod ends destroyed, front right and left rear arch liner cut in half and the front right arch has a nice pattern of the wheel...
Thankfully I had got the rear beam from the Lupo sport :clap: Rear callipers and carriers was painted and the rear beam had a quick coat of paint. Rear Disc beam was fitted with braided Lines, new inner track rods, track rod ends and ball joints.
Currently this is how the car sits, but still have a lot that I would like to do.
I still have the boot floor and exhaust from the Sport so may get this welded in, not to sure on this idea yet...
Managed to find some VW starlites, but will need a refurb, (not sure on what colour to go for, possibly a dark greyish?)
Well that's everything so far, below is some issues that im having engine wise if anybody could help :thumbsup:
So, recently been having issues with the enigne drinking lots of oil. i've been reading that the AUA engines have common issues with piston rings, hopefully it isn't the case. I've been thinking that it could be the sump gasket as it looks very oily around that area, but i never see any oil drips?? Possibly the valve stem seals??
Also removed spark plugs to find that that there is a lot of oil around the threads?
Any help is appreciated,
Cheers for looking
James
Decent progress! :) those starlites! :shades: I owned a set on my first lupo!
Edited by Vwlup0
Lovely choice of wheels! Just bought a set myself, gunmetal grey/anthracite would look great against thenblue paintwork
Regarding seats.
On later sports they are the same GTi seats. Most sports pre 2003 have a different interior. But all lupo interior is interchangeable between models.
Thanks for your comments :thumbup:
Took a while for some starlites to pop up, ending up doing a 4 hour trek for them! I think your right, anthracite may be the one.
Regarding seats.
Thanks for letting me know about the seats! :thumbsup:
So jealous of your starlites :angry2: Really really want a set haha! Good thread!
They do pop up now and again, just keep stalking eBay :tongueout: Thanks!
Just seen this thread, looks really tidy. :thumbsup:
Have you any recent updates? :)
Thanks :thumbup:
Actually yes! Quite a big update really, Just need to find the time to do it!
Lets just say there's another car on the drive :shades:
Owww sounds intriguing! Get some pics up when you can ;)
*where abouts in Sheffield are you mate?
Edited by T3LLIOTT
Did you get the starlites done then?
Unfortunately not, gathering dust at the minute :angry2:
Should be an update soon :thumbup:
I have a set too just sitting in the garage, need ro get them refurbed this month or it'll never happen lol
OK, so finally got my ass in gear, here is an update :thumbup:
Still haven't done anything with the starlites but did a trial fit.
The tyres on them are 185/55/14, once refurbed will probably run this size, unless any other recommendations?
Next up, did a cheep mod with indicator bulbs. In my opinion it looks a lot cleaner and more modern?
MOT was due, only issue was the ARB Bush at the front which had deteriorated. New one fitted, can definitely tell the difference in handling!
Recently decided to remove the bump strips and debadge the rear. I was a little cautious with this as I knew that it could end in tears :tongueout:
I started at the tailgate, used fishing wire to cut between the badge, then a caramel wheel to remove the sticky stuff and finally a bit of polish. seemed to work well so attacked the bump strips.
All went well, only issue is a little bit of paint has turned green, but is hardly noticeable.
Need to source a new tailgate handle, also considering painting the badge black?
That's all that has happened so far with this car. The plan for the car was to drop a 1.6 ARC engine from a polo 6n2 GTI into it. So I managed to get hold of the engine, gearbox, engine loom, interior loom, etc.
By getting the looms for free the catch was for me to remove them... This picture pretty much sums up the day.
Managed to get it all out pretty easy actually! Especially whilst still drunk from the night before! :twisted: Lets just say the bending down wasn't so fun :tongueout:
Currently the engine is stored elsewhere so no photo's of that.
But onto the bigger more exciting update :clap:
Bought a Lupo Project, it being a Candy White Lupo Sport.
On its way to its new home
The car will be having a full refurb including a whole new interior (as there isn't one :tongueout:) and a full body repair and respray.
Annoyingly there's a hole in the dash :rant: (not really sure how that is possible)
momo steering wheel, may put into ketty for time being.
Borbet A alloys
Infinity Exhaust system, stainless system from cat.
Luckily able to fit pop out rears
But unfortunately no rear speaker holes
Weathers been a cold recently so haven't done much to it, all I've really done is steam cleaned the interior and repaired bit of surface rust in the boot. The plan was to put the GTI engine into this but I'm now thinking to run it till the engine dies then put the GTI in, hopefully I will have better insurance prices at that point! :thumbsup:
So the future plan, getting hold of a donor lupo soonish for the interior. Will be getting all black interior and the newer style dash as Prefer this style and I believe it looks more modern. Hoping the dash will be a direct fit, but I will have to reroute a few cables. Then it will have a full body repair/respray, staying the same colour but thinking of having the roof gloss black for the extra scene points?
Think that's all so far,
Will try to keep this updated regularly.
Cheers
James
nice work.
Bin off the white shell, focus on the blue, far better colour/name.
On 1/17/2015 at 10:39 PM, Rich said:
nice work.
Cheers! It's a learning curve but a fun one :thumbsup:
Nah I like the colour, Ketty will still get some attention.
Wont cost too much to get the sport on the road, as can get all interior pretty cheap and the body repairer hopefully will sort me out. :thumbsup:
Questions if you could help :thumbup:
Will a 1.4 later dash fit straight in? Just have to reroute rear heater and hazard switches.
Something else I'm looking into is fitting electric mirrors, Just thinking how it is done.
I already have later sport door looms with electric mirrors and switch and can get hold of mirrors later on.
How could I then set this up? Does it have to be run to the comfort control module? Could I splice the mirror loom from the Polo gti and use its CCM? Not really sure how it's done but wouldn't mind giving it a go.
great if you could help
Cheers
Edited by James_VW
Dash, any lupo dash will fit any lupo.
loom wise, if you want to do this the easiest way, get hold of a Lupo gti wiring loom and just run that inside of the car and use the polo gti engine/box.
You'll get all the electrical upgrades of the gti plus all of the ease of using the polo gti engine which just drops in.
And yeah, I guessed the ket reference in the first post, I don't get why people just want to mong about doing jack when there's so much **** which always needs doing.
Good to know any dash will fit
Is that using both lupo gti bay loom and interior loom? Or can I use lupo gti interior loom and polo gti bay loom? Polo engine is ARC.
Haha, when stuff needs doing that's when amphetamine is useful. :shades:
jk, your right there is always too much **** to do :thumbsup:
just roll one and crack on.
Use the whole loom for the whole car.
You'll have rcl and electric everything, if you get it all then you'll have the alarm too. ]
definately the easiest way to go about it.
Does sound easier, more my style.
Is it all plug and play then? Any connections need changing? Apparently ARC has few more connections than the later GTI engine? Will this have problems?
Use ECU from polo and get it programmed to current key.
The throttle will need changing from cable to electric, is this straight forward?
Lights will also have to be modified with lupo gti bay loom
Edited by James_VW
Use a normal lupo pedalbox with a potentiometer.
the only differences, the polo engine has an oil temp sender on the head, the lupo doesn't so it doesn't plug in, job done.
The speedo drive is different, just change the plug.
ARC and AVY are basically the same thing.
Use the ecu from the lupo, use the gti key/convenience module/steering column and then you'll have the rcl and immob without ****ing about.
That's great!
Will be a lot less hassle that way, only issue is getting the looms and required parts being as rare Lupo GTI's go up for breaking. :angry2:
So everything for the conversion:
Polo engine
polo gearbox
Lupo GTI both looms
Lupo GTI ECU
Convenience module
steering column with key reader and immobiliser
standard Lupo pedalbox
Larger Radiator?
Lupo GTI fuel pump?
fuel pump will be fine,
as for the rad find a mk3 golf vr6 one or a polo gti one, they're all the same cheap thing.
Edited by Rich
