fattasss Posted August 31, 2012 Report Share Posted August 31, 2012 Any 1 know if its possible to convert a lupo 3L to RIGHT HAND DRIVE,Thought i get some ideas before i start. Quote Link to comment Share on other sites More sharing options...
James827 Posted August 31, 2012 Report Share Posted August 31, 2012 Re shell in a 1.4 auto? Quote Link to comment Share on other sites More sharing options...
Owen33 Posted September 1, 2012 Report Share Posted September 1, 2012 rather than swaping all 3l parts into another car could just swap dash, steering racks and peddle boxs over? i've never done any dash work on mine let alone a lefty so just guessing Quote Link to comment Share on other sites More sharing options...
Piers Posted September 1, 2012 Report Share Posted September 1, 2012 More trouble than it's worth? Plus If it doesn't go to plan and you f*** a 3L you wont be able to just fetch another Quote Link to comment Share on other sites More sharing options...
Pete Posted September 1, 2012 Report Share Posted September 1, 2012 I'd just leave it lhd, be a bitch over here for overtaking but if you're in a 3l you won't be doing a lot of that anyway! Quote Link to comment Share on other sites More sharing options...
Hazy Posted September 1, 2012 Report Share Posted September 1, 2012 (edited) I've seen it done quite a few times and helped a couple times with Landrovers -which are obviously a lot less complicated -but I would go with the above that you would probably need at least a donor right-hand side Dash. Everything else I would guess, could just be moved over to the opposite side -clocks and all, would just be the case of moving the looms about.But yeah, apart from swapping over the pedal box and all the goes with it, the main headache would be the steering rack i would think. I've never looked down there to be honest, but i don't think a left-hand enters the cabin the same place as a right-hand steering column does, I can also see the steering box on the lefty being the other way on too, so a donor right one of those would be needed. I would do quite a bit of homework and work out all the complications first, but the running gear is going to be the fiddly bit.Would be nice to see if it could be done. Edited September 1, 2012 by Hazy Quote Link to comment Share on other sites More sharing options...
fattasss Posted September 3, 2012 Author Report Share Posted September 3, 2012 (edited) ahh anyone know if the right hand drive lupo came without power steering as this is the rack i wil need to u, i've already got the right hand dashboard and a full wiring loom from a tdi u.k spec. Edited September 3, 2012 by fattasss Quote Link to comment Share on other sites More sharing options...
fattasss Posted September 3, 2012 Author Report Share Posted September 3, 2012 Re shell in a 1.4 auto?Definetly not the 3L body shell is different jus like the GTI Quote Link to comment Share on other sites More sharing options...
fattasss Posted September 3, 2012 Author Report Share Posted September 3, 2012 More trouble than it's worth?Plus If it doesn't go to plan and you f*** a 3L you wont be able to just fetch anotheralways wanted a 3L, right hand drive will be a BONUS. Quote Link to comment Share on other sites More sharing options...
JoeA Posted September 3, 2012 Report Share Posted September 3, 2012 Yeah the early 1.0Es came without power steering, and will a tdi loom work on a 3l Quote Link to comment Share on other sites More sharing options...
Rich Posted September 3, 2012 Report Share Posted September 3, 2012 I could answer but you're a penis so I'm not. 1 Quote Link to comment Share on other sites More sharing options...
James827 Posted September 3, 2012 Report Share Posted September 3, 2012 but, there wont be a space for the Steering Column? or the Mounting points for the Pedal box? lol I remember how stressed my mum used to get in car parks with her old LHD Opel Kadett. Quote Link to comment Share on other sites More sharing options...
fattasss Posted September 4, 2012 Author Report Share Posted September 4, 2012 i believe i need to use the bulkhead panel from a uk lupo that will have all holes for bolting in the padel box and brake servo,anyone know if the heater box will need to be changed? Quote Link to comment Share on other sites More sharing options...
Gruntilla Posted September 12, 2012 Report Share Posted September 12, 2012 Embrace the lhd it doesn't bother me in my splitscreen camper! Quote Link to comment Share on other sites More sharing options...
fattasss Posted September 14, 2012 Author Report Share Posted September 14, 2012 anyone else know if its possible to convert... Quote Link to comment Share on other sites More sharing options...
Fountain Posted September 17, 2012 Report Share Posted September 17, 2012 LHDs cooler anyway, Talk about Euro style (its how the Europeans have it) Quote Link to comment Share on other sites More sharing options...
GTIChris Posted September 17, 2012 Report Share Posted September 17, 2012 Don't know about the lupo specifically but I'm working in a car factory at the moment and seeing the bare shells of the cars,the differences between LHD and RHD is massive.The bulk heads are obviously completely different,there is alot of strengthening around the hole for the steering column for instance.If you were to swap bulkheads I'd say you'd want it jigging before welding back together. Quote Link to comment Share on other sites More sharing options...
fattasss Posted September 18, 2012 Author Report Share Posted September 18, 2012 yes i thought so, the bulkheads are different, obviously i need to get the bulk plate from a rhd car together with the dashboard, anuone got any thoughts on the wiring i.e moving fusebox to the opposite side, Quote Link to comment Share on other sites More sharing options...
Fob163 Posted September 28, 2012 Report Share Posted September 28, 2012 do an engine swap with a uk lupo, then just change all the interior stylings seats, steering wheel, doorcards etc, then swap the front and rear body panels over? obvs not that easy but doesnt sound impossible. Quote Link to comment Share on other sites More sharing options...
fattasss Posted September 30, 2012 Author Report Share Posted September 30, 2012 guys i'm looking to make a start on it this weekend hopefully, will post pics soon.right handed 3L:) Quote Link to comment Share on other sites More sharing options...
Rich Posted September 30, 2012 Report Share Posted September 30, 2012 What's the point?May as well just get a TDI. Quote Link to comment Share on other sites More sharing options...
Skezza Posted September 30, 2012 Report Share Posted September 30, 2012 man, I wish I had a Lupo 3L Quote Link to comment Share on other sites More sharing options...
fattasss Posted October 2, 2012 Author Report Share Posted October 2, 2012 What's the point?May as well just get a TDI.already have a tdi, wanted one of these for ages, PERFECT CAR but steering on the wrong side:) Quote Link to comment Share on other sites More sharing options...
Rich Posted October 2, 2012 Report Share Posted October 2, 2012 already have a tdi, wanted one of these for ages, PERFECT CAR but steering on the wrong side:)I've wanted Digifiz, I have Digifiz, it reads in KPH.Do I want to change this ?No, because I'm perfectly okay with retaining a feature of it's original charm. Quote Link to comment Share on other sites More sharing options...
