bowers155 Posted November 22, 2011 Report Share Posted November 22, 2011 was going 45 in a 40 and they have for some reason turned the speed camera around to catch people out , is there anything i can do ? what's the chances of me actually getting a letter and can i not do anything about it because they changed the camera around ? but ive checked insurance when it comes to re insure and its about 200 spondollies more so inst to bad :/ just rather not have them ! Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted November 22, 2011 Report Share Posted November 22, 2011 Find a country with no extradition treaty, book tickets and run Quote Link to comment Share on other sites More sharing options...
Koop Posted November 22, 2011 Report Share Posted November 22, 2011 Did it flash? Most cameras in a 40 shouldn't trip at 45, I understand it's usually +10% +5mph. Might be out of film anyway, you could be lucky. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted November 22, 2011 Report Share Posted November 22, 2011 (edited) 10 % of 40 is 4, so it would go off at 45. Then take into account that your speedo will be marginally out you are never actually doing the speed on your speedo. All that aside there is **** all you can do but wait Edited November 22, 2011 by scotty_82 Quote Link to comment Share on other sites More sharing options...
Koop Posted November 22, 2011 Report Share Posted November 22, 2011 10 % of 40 is 4, so it would go off at 45.40+10%=44, +5=49. They're not all set the same though, your best bet is to keep to the speed limit Then take into account that your speedo will be marginally out you are never actually doing the speed on your speedo.Speedo generally shows a slightly higher speed than you are actually travelling (they're set up in the factory with margin for error), unless of course your tyre diameter is larger than standardAll that aside there is **** all you can do but waitPretty much. May the Force be with you. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted November 22, 2011 Report Share Posted November 22, 2011 (edited) I'll disagree with you there , not one of my cars above 30 has been reading over compared to my sat nav, everyone has read under and that margin has increased with speed And i don't think the plus 5 theory works either but your right , stick to the limit an you don't have to worry Edited November 22, 2011 by scotty_82 Quote Link to comment Share on other sites More sharing options...
MrDerek Posted November 22, 2011 Report Share Posted November 22, 2011 I thought I got caught doing almost 40 in a 30, (mobile camera) and it turns out I was only doing 35ish, ended up only doing a speed awareness course instead of taking the points.Good luck. Cant appeal against the camera being turned around, there used to be one around here which changed every other day. Quote Link to comment Share on other sites More sharing options...
Koop Posted November 22, 2011 Report Share Posted November 22, 2011 not one of my cars above 30 has been reading over compared to my sat nav, everyone has read under and that margin has increased with speedThat's weird, mine have always read over compared to sat nav & them signs that tell you how fast you're going. That's with standard wheels though. Need to find one of those signs when I get back on 15s to test it! Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted November 22, 2011 Report Share Posted November 22, 2011 Sorry Koop I read your first reply wrong , what I meant to say is my speedo always reads over compared to my sat nav when going above 30. So at 40 on my clocks is probably 37 on my sat nav Quote Link to comment Share on other sites More sharing options...
Silver! Posted November 22, 2011 Report Share Posted November 22, 2011 Sit tight and hope the postie doesn't deliver a brown envelope.Couple of years ago, Foxy and I blasted through a mobile speed camera on Rannoch Moor, Foxy got a ticket I never. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted November 22, 2011 Report Share Posted November 22, 2011 Sage advice from and old and wise man. Quote Link to comment Share on other sites More sharing options...
Jambro Posted November 22, 2011 Report Share Posted November 22, 2011 I'm guessing this was on Eastern Avenue? I bet they've caught out loads of people.. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 22, 2011 Report Share Posted November 22, 2011 What do you mean they turned the camera round? What type of camera - a gatso or truvelo? Was it still at the other side of the road?ACPO guidlines state you shouldnt get prosecuted unless you are doing 10% + 2 over the posted limit, most fixed cameras will be at this (or possibly more dependant on Force) Quote Link to comment Share on other sites More sharing options...
Koop Posted November 22, 2011 Report Share Posted November 22, 2011 I bow to your superior knowledge having actually checked the guidelines Quote Link to comment Share on other sites More sharing options...
IDGM Posted November 22, 2011 Report Share Posted November 22, 2011 ACPO guidlinesThey are only guidelines, so the Police can do what they want. Cameras and operators are 'supposed' to be highly visible. They rarely are. Unmarked vans parked in a line of cars are common place. Given a speedo cannot read below the actual speed, setting cameras at 1mph above the limit is legitimate. Quote Link to comment Share on other sites More sharing options...
Jambro Posted November 22, 2011 Report Share Posted November 22, 2011 (edited) What do you mean they turned the camera round? What type of camera - a gatso or truvelo? Was it still at the other side of the road?ACPO guidlines state you shouldnt get prosecuted unless you are doing 10% + 2 over the posted limit, most fixed cameras will be at this (or possibly more dependant on Force)If its the one I think it is, its a gatso. 3 lanes each way with a speed camera in the central reservation. It used to face one way and now its been turned around so it faces the other way.. Edited November 22, 2011 by Jambro Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted November 22, 2011 Report Share Posted November 22, 2011 A good sign is that they put the markings on both sides of the road , I they hasn't then you my have a case Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 22, 2011 Report Share Posted November 22, 2011 They are only guidelines, so the Police can do what they want. Cameras and operators are 'supposed' to be highly visible. They rarely are. Unmarked vans parked in a line of cars are common place. Given a speedo cannot read below the actual speed, setting cameras at 1mph above the limit is legitimate.Whilst you are correct, this rarely happens in practice. Of course plenty of people post on forums about how they got pulled by a lone Officer with no hat on for doing 31 in a 30 whilst the Officer was coming the other way with no headlights on but they are often bending the truth somewhat.If its the one I think it is, its a gatso. 3 lanes each way with a speed camera in the central reservation. It used to face one way and now its been turned around so it faces the other way..So its facing you as you are driving towards it?A Gatso isnt approved for oncoming traffic, so isnt admissable.If it gets you as you drive away from it, you must have seen the flash if it went off - they are rather bright Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted November 22, 2011 Report Share Posted November 22, 2011 I'll second that on the brightness. I've seen a few go off on the roads with changing speed limits Quote Link to comment Share on other sites More sharing options...
Koop Posted November 22, 2011 Report Share Posted November 22, 2011 I got flashed a few times in my younger sillier motorcycling days, clearly never had any film in though as my licence remains clean as a whistle lol Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 22, 2011 Report Share Posted November 22, 2011 I got flashed a few times in my younger sillier motorcycling days, clearly never had any film in though as my licence remains clean as a whistle lolhttp://www.youtube.com/watch?v=yEGJyQHzLNI&feature=relatedNever had film in eh? Hmmm Quote Link to comment Share on other sites More sharing options...
Jambro Posted November 22, 2011 Report Share Posted November 22, 2011 So its facing you as you are driving towards it?A Gatso isnt approved for oncoming traffic, so isnt admissable.If it gets you as you drive away from it, you must have seen the flash if it went off - they are rather brightEveryone used to speed one way (when it faced you as you're driving towards it). But now its swapped the other way, I'm guessing bowers155 didn't know it had, so potentially got flashed as it would've been facing the rear of his car as he drove away from it.. Quote Link to comment Share on other sites More sharing options...
puggled Posted November 22, 2011 Report Share Posted November 22, 2011 I got caught speeding once (in my Skoda Felicia of all things) and don't see why everyone tries to get out of it. I was speeding, I took my punishment and learned my lesson. Quote Link to comment Share on other sites More sharing options...
Kent Posted November 22, 2011 Report Share Posted November 22, 2011 go back and accidentally drive into the speed camera Quote Link to comment Share on other sites More sharing options...
bowers155 Posted November 23, 2011 Author Report Share Posted November 23, 2011 yeah was estern avenue by maccys :/ well the points when i renew insurance still drops 700 quid so im happy either way Quote Link to comment Share on other sites More sharing options...
