tshirt2k Posted October 10, 2005 Report Share Posted October 10, 2005 It's easy. Just make sur the first one to be secured are the ones under the screen in the scuttle area. then it will stay. Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 10, 2005 Author Report Share Posted October 10, 2005 Thanks for the tip style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
LINCOLNSHIRESLUPOGTI Posted October 11, 2005 Report Share Posted October 11, 2005 So do you not think the drive by wire can be removed without taking the dash out?No way of chopping it out or anything?This might be enough for me to cancel my conversion to be honest, no chance am I removing all my interior as it will never bee the same again and you know how fussy I am. Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 11, 2005 Author Report Share Posted October 11, 2005 I dont know Darren.It may be possable, I dont know if VW have a special tool they can get into the space to remove the allan key bolt.I just know we couldn't style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" />There may be another option though.Take a read of this thread below.A new member has fitted bike boddies to his 1.0, ad being a little creative with the flyby wire.I for one, am not so precice so taking the dash out was the best option.You may have the skill to do this though.See here Quote Link to comment Share on other sites More sharing options...
Mitchell Posted October 14, 2005 Report Share Posted October 14, 2005 (edited) i for one can see no way of ever getting the fly by wire unit out without removing the dash as it sits inbetween the top of the pedal box and is tight up against the top of the bulk head, andi if i was you i would put the dash back in once its in and running, just incase you need to get into anything, when i done mine i connected the clocks up and cable tied them to the steering coloum {SP} ,this is how i drove for 2 weeks until i was happy it was all working., any way you got my number if needed. Edited October 14, 2005 by mitch unit 21 Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 15, 2005 Author Report Share Posted October 15, 2005 if i was you i would put the dash back in once its in and running, just incase you need to get into anything<{POST_SNAPBACK}>Yes I can see the logic in that.Starting to get there though.Just made up a couple of brackets to mount the catch tank.Used cable ties to hold the tank to the two L shape brackets.Not happy with them, but they are solid, so will do untill I can think of another way to hold it.Didn't want to mount the tank directly to the chassis.The L brackets have done the job great, pulled the tank out slightly, so when looking diretly over the tank, you can see it all the way around.Just waiting for Emma to get back with the car so I can go and pick up a drill to counter sink the head bolt holes on the spacer plate.Hopeing the table top drill will be good enough to recess these holes, and drill and tap another four for the vacume feed pick ups. border="0" class="linked-image" /> border="0" alt="" /> Quote Link to comment Share on other sites More sharing options...
payna Posted October 15, 2005 Report Share Posted October 15, 2005 (edited) looks neat, bet you cant wait to get her back on the road! style="vertical-align:middle" emoid=":rolleyes:" border="0" alt="rolleyes.gif" />how long has it been off the road now? Edited October 15, 2005 by payna Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 15, 2005 Author Report Share Posted October 15, 2005 how long has it been off the road now?<{POST_SNAPBACK}>Got started today.<{POST_SNAPBACK}>Seven months on Monday style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" />So long as its done for the start of summer next year I'll be pleased with it.Only got a little bit of work to do now, before I fit the engine.Hoping I remember how it was removed as Ive got to fit it myself.Think Ive decided against a budget ECU.Ive been playing wit Emerald Mapping software, and although its pretty straight forward, theres so much to building a fresh map I dont think Id be up to it.If I can find an ECU that will work with VW sensors I will go with that.Xmas and birthday within the next 5 months, so you know what will be on my list style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 17, 2005 Author Report Share Posted October 17, 2005 Had a bad day yesterday.Picked up my Dads vice and table drill and decided to counter sink the holes and add the holes for the vacuum feed myself.All was going well, drilled out the 6 holes to allow the head bolts to sit flush.Removed the inlet manifold and attempted to fit it.The engine lift brackets had to be removed to allow the plate to sit in, 4 of the 6 bolts lined up, but the two to the left didn't, noticed the plate was catching.There is a few cut outs, to allow for this, but this one side was catching.Got the grinder out, and started to take off the 2mm needed.First time I've not put on my welding gloves and the grinder slipped and sliced into my hand.Hurt like hell.Tried to fit it again, was no longer catching, so attempted to tighten the torque bolt up, and the wrachet slipped, rounding the bolt head!Dont know how I'm going to remove it, still got the vacuum pick up holes to drill, so it has to come off. Quote Link to comment Share on other sites More sharing options...
noddy Posted October 17, 2005 Report Share Posted October 17, 2005 bad luck buddy hope you get sorted soon Quote Link to comment Share on other sites More sharing options...
LINCOLNSHIRESLUPOGTI Posted October 18, 2005 Report Share Posted October 18, 2005 Bloody hell Andi, you were lucky with the grinder, could easily have lost a finger or even your hand!!! You should start a post of all your Lupo related incidents...lolIf I can find an ECU that will work with VW sensors I will go with that.This is what I am working on currently, initial ideas have included Motec but not sure on their prices aas some of their ECU's are £4000 - £6000 which will not be going on my car I can assure you. As soon as I have got an ECU I will post the details for you too look over. Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 18, 2005 Author Report Share Posted October 18, 2005 The most annoying thing was, Id travelled down for the vice and then I didnt use it! lol£4-6k! Bloody hell, do they control the ambient temp as well!Hopeing to have the car ready for April (my birthday style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> ) Emma says I can have up to £500 for xmas + birthday so Im looking a no more than that.I had a play with Emeralds mapping program, looks pretty straight forward.Still think I may pay someone to do it though, although I want to watch how to do it.Wouldn't mind two maps beinng built.One for use, and one to get it through MOT in July next year. Quote Link to comment Share on other sites More sharing options...
paulbin Posted October 19, 2005 Report Share Posted October 19, 2005 come on post pics of the hand! Quote Link to comment Share on other sites More sharing options...
noddy Posted October 25, 2005 Report Share Posted October 25, 2005 hey buddy you get any thing done this weekend just seems quite in camp tigz get some pic's of your hand up bud i love looking at war wounds style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> Quote Link to comment Share on other sites More sharing options...
Loopy Lupo Posted October 25, 2005 Report Share Posted October 25, 2005 christ andi - fire, angle grinders, rhinos - is there nothing you're frightened of taking on? style="vertical-align:middle" emoid=":lol:" border="0" alt="laugh.gif" /> the oil catch tank - i just cable tied mine on top of a flatish bit where the original air feed used to be rock solid and filling up nicely! style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> keep up the good work buddy - but without the injuries! style="vertical-align:middle" emoid=":blush:" border="0" alt="blush.gif" /> Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted October 25, 2005 Author Report Share Posted October 25, 2005 (edited) Not got any more done this weekend.Was nice to took Emma and chloe out for the weekend.Work mate is coming round this week to try and get the head bolt out for me.I dont want to make it any worse.Hands clearing up now, pulled the scab off on Frday, so now I just have a smaller scab, and a red patchLooks like it will leave a cool little scar style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Edited October 26, 2005 by Tigz Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted October 26, 2005 Report Share Posted October 26, 2005 style="vertical-align:middle" emoid=":P" border="0" alt="tongue.gif" /> glad its still moving on andi, even if had a few problems style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
nfbr Posted October 29, 2005 Report Share Posted October 29, 2005 scars are cool... Quote Link to comment Share on other sites More sharing options...
Marqs_Loopy Posted November 13, 2005 Report Share Posted November 13, 2005 Andi any updates... Quote Link to comment Share on other sites More sharing options...
KidDub Posted November 13, 2005 Report Share Posted November 13, 2005 WOW andi well impressed with the progress fella just read all the dramas if anything you should right a book on the car and you lolwell done mate is there any pics on current progress style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted November 13, 2005 Author Report Share Posted November 13, 2005 No progress due to about 2 litres of Vodca I really should have left alone this weekend.Im on earlys this week though, so I should have the car back on wheels by the weekend.Just stripped down the hubs I picked up last weekend, wish I didnt through away by old brake lines so I could have used these Lupo calipers Ive ended up with.Did manage to finally get the wing mirrors off though! Quote Link to comment Share on other sites More sharing options...
Marqs_Loopy Posted November 28, 2005 Report Share Posted November 28, 2005 No progress due to about 2 litres of Vodca I really should have left alone this weekend.Im on earlys this week though, so I should have the car back on wheels by the weekend.Just stripped down the hubs I picked up last weekend, wish I didnt through away by old brake lines so I could have used these Lupo calipers Ive ended up with.Did manage to finally get the wing mirrors off though!Andi you've had time bro to get over you 2 litres of vodka now any changes mate.. i'm stillinterested in this bit of history style="vertical-align:middle" emoid=":lol:" border="0" alt="laugh.gif" /> even if every one else has fallen asleep style="vertical-align:middle" emoid=":rolleyes:" border="0" alt="rolleyes.gif" /> style="vertical-align:middle" emoid=":coffee:" border="0" alt="coffee.gif" /> Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted November 28, 2005 Author Report Share Posted November 28, 2005 Only update I have is one of another excuse.Had to spend Saturday fixing the bike.Really am going to spend some time on the car this weekend.. no Im not, going to work do on Saturday night and I'll be holding the baby while emma goes for hair done.. Quote Link to comment Share on other sites More sharing options...
stevewp Posted November 29, 2005 Report Share Posted November 29, 2005 What happened to the bike mate? Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted November 29, 2005 Author Report Share Posted November 29, 2005 I lost all power from the battery.Only power I had was from the dyno when the engine was running.Using the kick start wasn't too much of an issue untill I developed a starting problem.thought it was the mixture as Id been messing with the carb but it turned out to be the shitty loom.So made up a new loom, and the bikes working fantastic again style="vertical-align:middle" emoid=":D" border="0" alt="biggrin.gif" />Full days job though style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" /> Quote Link to comment Share on other sites More sharing options...
