CLAYTONJONES
Clayton's Tornado Red GTI..
6 minutes ago, LR5V said:
Thanks - will check the brakes and discs out - didn't realise euros did Brembo discs
Yeah if you go under the performance section they are there. Also, if you copy the product code and search it on Carparts4less, they are normally cheaper as wellšŸ‘šŸ¼
On 7/25/2018 at 3:27 PM, CLAYTONJONES said:
Well iā€™m back from a long weekend at the NĆ¼rburgring, if you have never been I highly advise you to go. The most incredible place iā€™ve ever been, a petrol heads dream! The Lupo performed faultlessly and not a single issue! Oh and the tyre writing didnā€™t last, a permanent solution is being worked on.
Iā€™ll leave a few pictures below??
ESXWysO.jpgp
Ā
Look of the car and these pics are just great!
FinallyĀ gotĀ theĀ freshlyĀ powderĀ costedĀ rearĀ beamĀ back,Ā soĀ iĀ gotĀ itĀ allĀ builtĀ backĀ upĀ today.Ā WentĀ andĀ hadĀ theĀ alignmentĀ done,Ā cameĀ outĀ spotĀ on.Ā carĀ drivesĀ incredibleĀ now!Ā JustĀ waitingĀ forĀ theĀ RARBĀ bracketsĀ toĀ turnĀ upĀ thenĀ thatĀ canĀ goĀ backĀ on.Ā
Ā
Looking great -
what bushes did you go for? and those discs alsoĀ look tasty
Cant remember what rear ARB you run - if its a WhitelineĀ the drop links go on the outside of the beam like on mine:
I wish my shocks were more like yours being not so crusty!
Just now, LR5V said:
Looking great -
I went for OEM. Purely because i donā€™t want the ride being any stiffer than it is.
Yeah it is a whiteline, glad you posted that as I couldnā€™t remember haha!Ā
Really loving the attention to detail on this. looking good.
What did you get the front alignment set to? :)
Thanks! Sorry i thought i added the alignment sheet, iā€™ll put it in now!
Front subframe needs to be moved a tiny amount if the caster is out. Right side needs to go forward. No idea how to easily work out by how much. I'd try about 2Ā mm to start. I s'pose you could measure everything then do the geometry maths.... :)
Ā
Ā
I didnā€™t know the castor could be adjusted on these, handy to know for next timešŸ‘šŸ¼
