anthony's lupo 1.4 turbo on air ride
my lupo 1.4s with a ko3 turbo air ride....
Lupo by anthony.gaulter, on Flickr
so she is rolling on bbs ra's air ride and uprated brakes
the engine: has a ko3 turbo, front mount intercooler, 5 bar manual fuel pressure regulator, race oil cooler, manual boost controller, k&n air filter, atmospheric waste gate, spaced out spark plugs, silicone and braded pipes.....
turbo
Turbo bits by anthony.gaulter, on Flickr
race oil cooler
intercooler
Untitled by anthony.gaulter, on Flickr
up rated brakes
air ride
all together
Lupine by anthony.gaulter, on Flickr
rake!
that's her so far but more to come :thumbsup:
Well not had her mapped yet but would like 160bhp, but befor i get it mapped need to lower the comppretion and fit gti injectors,I would like some new cams to, get the body work sorted out and get my Porsche seats in :)
Are you 'uprated' brakes just 239's.
Coming soon to a hedge near you . . . . . . . . .
  • Like 4
160hp on those front brakes inst the best idea.
they are from the stone ages!
and they weren't the best then!
also i dont see the internals of that engine lasting long, what PSI boost is it running?
The best pads are oem ones.
The best discs are oem ones.
You have fallen foul of the brembo/mintex propaganda.
220px-Bundesarchiv_Bild_146-1968-101-20A
makes me sound like an Arse, But its the difference between stopping where you plan too, and stopping in that persons front garden
Not had her mapped yet but once I have lowed the compretion ratio want to run 1bar about 15psi but at the moment running about 5psi lol
Nice mixed units of measurement there!
Bar or Psi... not both
Put it in both as 1bar is about 15psi make it simple for people
In fairness, i think many people on here were struggling to decipher your posts, but not because of the complexity of your language and terminology.
Edited by JoeA
  • 3 weeks later...
the most boost you will get on those standard internals is 8psi at the very most mate. 1 bar on standard internals will get you around ten miles before your picking pieces of your pistons out of your turbo. meltdown. and those brakes are not good for 160 bhp.
Ill reiterate for you, been there and done this with the 1.6 engine.
You wont even make it on to the road with an standard internal set with 1 Bar boost. It will blow up on the rollers, it will take an edge off the standard piston in no time and wipe out the rest of the engine.
With a CR of 8.5:1 and 15psi of boost you will be looking at on boost CR of about 17:1 which is too high for standard pistons. On forged you will be ok but you will need EGT monitoring to get the correct advance to aviod melting anything.
I saw this happen on a gti engine with 7psi and 9:1 CR. French guy on here tried it with a supercharger conversion. Didnt last very long before it gave up.
Also, what angle is the turbo sitting at? Will that not cause oil starvation issues to the front bearing?
Ow well you have give me something to think about there, and the oil is not a problem at the start I had to much going in and it was a mess squirting oil out of any where it could get out of the turbo but reduced the size of my oil feed pip and there is a good flow now :)
