rosol88 Posted December 15, 2012 Report Share Posted December 15, 2012 I had check engine light i changed lambda sensor and fuel consumption went a bit down but still takes around 15 liters per 100 miles any advice ? i heard i need to change both sensors in same time because sometimes it might cause problem as well but check engine light didnt pops up ;/ i really need to get rid of that problem because i cant afford to put 40 quid a week petrol Quote Link to comment Share on other sites More sharing options...
Pete91 Posted December 15, 2012 Report Share Posted December 15, 2012 Have you scanned the codes? What engine is in it? You're getting 30.4mpg so it's not ridiculous if it's a gti/sport. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 15, 2012 Report Share Posted December 15, 2012 As above. Did the fault light go out once you changed the lambda? Did you use a genuine sensor?Has it been recently serviced, does your temp gauge work ok?Cold weather will reduce mpg too Quote Link to comment Share on other sites More sharing options...
rosol88 Posted December 15, 2012 Author Report Share Posted December 15, 2012 temp wrks its ngk sensor ordered in lvw shop after changing the lambda codes were cleared and there is no code anymore its 1.0 not gti Quote Link to comment Share on other sites More sharing options...
Pete91 Posted December 15, 2012 Report Share Posted December 15, 2012 Last service? Booting the arse out it? Quote Link to comment Share on other sites More sharing options...
rosol88 Posted December 18, 2012 Author Report Share Posted December 18, 2012 The check engine light is on again so defo its the o2 sensor because i have changed the one in cat. Quote Link to comment Share on other sites More sharing options...
rosol88 Posted December 18, 2012 Author Report Share Posted December 18, 2012 (edited) 12 liters per 100 miles its the lambda sensor the one by the engine because i changed the one by cat. Edited December 18, 2012 by rosol88 Quote Link to comment Share on other sites More sharing options...
lupomadness Posted December 22, 2012 Report Share Posted December 22, 2012 could be a small hole in the exhaust Quote Link to comment Share on other sites More sharing options...
DENTOUT Posted December 22, 2012 Report Share Posted December 22, 2012 Its none of the above, change your coolant temp sensor, if its faulty it will give a reading of -40'c to the ecu and massively overfuel the engine, and only 12 quid for the sensor, guaranty its that! Quote Link to comment Share on other sites More sharing options...
jay1408 Posted December 23, 2012 Report Share Posted December 23, 2012 Its none of the above, change your coolant temp sensor, if its faulty it will give a reading of -40'c to the ecu and massively overfuel the engine, and only 12 quid for the sensor, guaranty its that!If this sensor is his problem then surely temp gauge wouldnt move on the dash ? I have similar problem with high consumption but want to try rule out things before it gets too expensive .. my temp gauge still works. Quote Link to comment Share on other sites More sharing options...
electricracer Posted December 23, 2012 Report Share Posted December 23, 2012 most vws have 2 temp sensors (in some the same sensor gives two outputs) one for the gauge one for the ecu, its quite common for the gauge to still work fine but the ecu thinks its -40, you need to plug it in a check what the ecu is actually reading.think yourself lucky, recently heard of a garage that had to change a temp sensor on a w12 audi, part was £25 labour was £1200!!!! its engine out job. Quote Link to comment Share on other sites More sharing options...
jay1408 Posted December 24, 2012 Report Share Posted December 24, 2012 Just changed this temp sensor.. lets see if that makes a difference Quote Link to comment Share on other sites More sharing options...
rosol88 Posted December 28, 2012 Author Report Share Posted December 28, 2012 coudl you give me any website i can order this sensor from ? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 28, 2012 Report Share Posted December 28, 2012 Get a genuine one from lupoboz Quote Link to comment Share on other sites More sharing options...
rosol88 Posted December 29, 2012 Author Report Share Posted December 29, 2012 Just changed this temp sensor.. lets see if that makes a difference is it hard to change it ? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 29, 2012 Report Share Posted December 29, 2012 No, remove clip/remove sensor/plug in new sensor/replace clp/top up coolant Quote Link to comment Share on other sites More sharing options...
jay1408 Posted December 30, 2012 Report Share Posted December 30, 2012 is it hard to change it ?No mate, so easy but just don't lose the clip like I did when it popped off !!!No, remove clip/remove sensor/plug in new sensor/replace clp/top up coolant Quote Link to comment Share on other sites More sharing options...
DENTOUT Posted January 3, 2013 Report Share Posted January 3, 2013 Any joy? Fixed it? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 3, 2013 Report Share Posted January 3, 2013 Doubt we'll hear from him again till it goes wrong again, which it will. 1 Quote Link to comment Share on other sites More sharing options...
jay1408 Posted January 5, 2013 Report Share Posted January 5, 2013 Not really done much driving in mine since changing the sensor , it seems to have made a little bit of a difference although not the difference I was hoping for .. Looks like its gonna be the lambda on mine. Quote Link to comment Share on other sites More sharing options...
DENTOUT Posted January 6, 2013 Report Share Posted January 6, 2013 Remember the lambda fault is usually a dirty or failed throttle body or egr valve... Its usually a red herringleading u in the wrong direction Quote Link to comment Share on other sites More sharing options...
rosol88 Posted January 15, 2013 Author Report Share Posted January 15, 2013 Thanks dude i changed both of the sensors and cat still got same faults but now the egr valve came up so i think i need to clean that right ? Quote Link to comment Share on other sites More sharing options...
rosol88 Posted January 17, 2013 Author Report Share Posted January 17, 2013 Hey guys What i did was bought a 25 pound used o2 sensor and bought new cat changed it and after 2 days exacluy today check engine light went of by it self why is that ? xD it could be because of cold weather or something ? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 18, 2013 Report Share Posted January 18, 2013 If you fitted the new parts and didn't clear the fault codes they will go off of their own accord after so many miles/engine starts. Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 18, 2013 Report Share Posted January 18, 2013 Its none of the above, change your coolant temp sensor, if its faulty it will give a reading of -40'c to the ecu and massively overfuel the engine, and only 12 quid for the sensor, guaranty its that!I had the opposite of this. Mine gave the correct reading to the ecu but -40 to the needle on the dashboard. Was irritating but not a big deal. Had it fixed eventually when my coolant level sensor packed in. Quote Link to comment Share on other sites More sharing options...
