JoeA Posted February 5, 2013 Author Report Share Posted February 5, 2013 Thanks for the votes guys, much appreciated, much love Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 6, 2013 Author Report Share Posted February 6, 2013 (edited) The past 2 weeks work have been sourcing parts and rebuilding the induction. Wanted a CDA as well as to sort out the dirty oil that was spewing everywhere. Took a fair bit of maths but i'm happy now its all connected sounds better, works better and goes better Mounted the catch tank at the front of the bay.Ran piping to the PCV, EGR and Rocker cover breathers, as is on the standard air box.Piped that in nice and close to the TB.Then got the BMC mounted at a different angle from the last, also removed the cold air feed i put in.Everything piped in and fitted.Engine cover back on.Just need to clean the bay and apply my new CDA sticker now! Oh and finally get round to ordering the bolts caps for the cover from Dale.Thanks for looking, as usual, more to come Edited February 6, 2013 by JoeA Quote Link to comment Share on other sites More sharing options...
MAD ROADSTER Posted February 6, 2013 Report Share Posted February 6, 2013 Looking smart joe nice and tidy keep it up bud see you soon Alex. Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 6, 2013 Author Report Share Posted February 6, 2013 Thanks buddy! Yeah man, not seen you in too long! Quote Link to comment Share on other sites More sharing options...
Adam R4 Posted February 7, 2013 Report Share Posted February 7, 2013 Looking good as always Joe! Looking forward to seeing what you do for Ultimate Dubs see you there I suppose Quote Link to comment Share on other sites More sharing options...
Dj Xaler Posted February 7, 2013 Report Share Posted February 7, 2013 Nice car!!! Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 7, 2013 Author Report Share Posted February 7, 2013 Looking good as always Joe! Looking forward to seeing what you do for Ultimate Dubs see you there I suppose Nice car!!!Thanks guys Yeah wheels should be on for UD, few other bits planned but they'll probably happen halfway through show season as per usual! Quote Link to comment Share on other sites More sharing options...
Piers Posted February 8, 2013 Report Share Posted February 8, 2013 Bring one Sunday for me to see in the flesh Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 8, 2013 Author Report Share Posted February 8, 2013 Lol it's a state atm, if you're lucky ill clean it Quote Link to comment Share on other sites More sharing options...
Pete91 Posted February 9, 2013 Report Share Posted February 9, 2013 Good effort as always Joe! Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 9, 2013 Author Report Share Posted February 9, 2013 Thanks pete Quote Link to comment Share on other sites More sharing options...
Chrisbee Posted February 10, 2013 Report Share Posted February 10, 2013 goot work on the catch tank, i had to cut off all the supporting parts for the original air box to get all my piping to clear on mine did you do the same? Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 10, 2013 Author Report Share Posted February 10, 2013 I just took off the bottom sections, my airbox could technically be assembled no issues I just took off the bottom sections, my airbox could technically be assembled no issues Quote Link to comment Share on other sites More sharing options...
Chrisbee Posted February 10, 2013 Report Share Posted February 10, 2013 i had loads of clearence issues with the backets under the cover that airbox sits in so had to chop them out but then i was left with a cover that would flap about unsupport at the back which the tuner that looks after the car said will set off the knock sensor in the tb. I went about cutting up the airbox itself so it would accomidate all the tubing and the catch tank and keep the rear supports.I'll post up pictures in my thread as it took some fiddling but its all hidden and very solid. Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 10, 2013 Author Report Share Posted February 10, 2013 My airbox is bolted in at the front and sits firm at the back as the piping pushes up on it, got about 15mm until the bonnet but it doesn't ever touch. Quote Link to comment Share on other sites More sharing options...
Piers Posted February 10, 2013 Report Share Posted February 10, 2013 2 Quote Link to comment Share on other sites More sharing options...
Chrisbee Posted February 10, 2013 Report Share Posted February 10, 2013 (edited) Oh you must have used a bigger pipe, (51mm -71mm?) See I found the bigger the pipe was, the less induction sound I got so went smaller to create a better vacuum plus the ECU doesn't like it when it gets to much air. Edited February 10, 2013 by Chrisbee Quote Link to comment Share on other sites More sharing options...
Lupo-Joe Posted February 10, 2013 Report Share Posted February 10, 2013 Cool car Joe Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 11, 2013 Author Report Share Posted February 11, 2013 Oh you must have used a bigger pipe, (51mm -71mm?) See I found the bigger the pipe was, the less induction sound I got so went smaller to create a better vacuum plus the ECU doesn't like it when it gets to much air.That's the one, 70mm throughout now found it runs fine for me and the noise is top! Cool car JoeThanks Joe appreciated ! Quote Link to comment Share on other sites More sharing options...
12yan Posted February 12, 2013 Report Share Posted February 12, 2013 Great work on the Engine bay Looking forward to seeing this at some shows Ryan Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 12, 2013 Author Report Share Posted February 12, 2013 Thanks Ryan I'm sure we will catch up at some shows again this season Quote Link to comment Share on other sites More sharing options...
12yan Posted February 12, 2013 Report Share Posted February 12, 2013 Thanks Ryan I'm sure we will catch up at some shows again this season Yessss we will 1 Quote Link to comment Share on other sites More sharing options...
JoeA Posted February 12, 2013 Author Report Share Posted February 12, 2013 Sorted! 1 Quote Link to comment Share on other sites More sharing options...
vpolo Posted February 22, 2013 Report Share Posted February 22, 2013 wair a second this looks familia !!! Quote Link to comment Share on other sites More sharing options...
JoeA Posted April 4, 2013 Author Report Share Posted April 4, 2013 (edited) Progress is starting to begin again, got an oil change to do.Then, my pals pitched in and bought me some team hekos, so need to fit them at some point.Wheels are getting picked up on friday, only need dishes, rubber, bolts and valves May have found a new indicator panel too, will have to have it sprayed.Then, just a mighty good clean and a full machine polish and ill be halfway there.... Edited April 4, 2013 by JoeA Quote Link to comment Share on other sites More sharing options...
