Chris Dunderdale
Lupo GTI Engine Details...
Hi there guys,
Was just wondering if you could tell me a little bit more about the history of the the 1.6 GTI engine. I know it came from the Polo GTI, but thats all! Any interesting facts?!
Looking to buy a GTI in the next year or so... I need to pass my test first though... (and yes, I'm 26... and lazy!)
Chris
the 1.6 or the vr6 which was later used in 3lr form to make the lupo 3l?
Edited by Crusoe
the design was initially for the super 1600 rally car class where it was tuned for the polo cup rally car. The only noticable trace is the quick release bolts on the sump guard that were added for quick access on the rally car.
when they changed the engine for production use they had to lower the idle revs to meet emissions regulations so there is a bit of a stutter when the engine is cold. The rally car idle was 2000rpm so it does warm up a lot faster if you give it some revs from cold but you only notice on really icy days.
The sump is different, and the engine top is not red but other than that its the same engine.
The gearbox is different, the Clutch on the Polo is cable operated and the linkages have also been changed.
Unfurtunatly yes.
Although Most Polo GTIs were also flyby also.
The Polo GTI lump I fitted came with a cable throttle body, Id always thought before that they all were flyby wire.
i was going to make a separate post about this but i have recently seen a product called the "sprint booster" that is a replacement module that connects to the throttle, it has altered electrics that make the throttle much more faster and responsive. cost about £160 though.
Edited by Dark
Quick release sump guard sounds very interesting
is that a bad thing? Does it make it less responsive?
For normal use no, i just prefere the feel of a cable pedal.
There is a slight delay when you rev the engine, but nothing too bad.
have you not seen the allen key nuts underneath instead of the usual bolts, worth a look :)
My Polo GTI is like that! lol
I think they just use what ever they have avalable at the time!
It was also the first vw engine to make use of Vermiculargraphit in the block casting. They only added it for 600 engines built between 1999 and 2001 to qualify the block for rally use. the strengthened blocks were NDT tested and x-rayed at the factory for defects and should resist bore wear better than the standard softer block. This also assisted these engine to cope with pressures & heat generated when RPM reaches 9800, which is safe to hit when you remove the rev limiter when reprogramming the ECU.
there was never official chassis numbers releases for those engines though so the only way to tell is to compare the colour of the block. If it's slightly darker grey then it has the added graphite.
this should maybe be stickied for newbies to see
It's also worth noting that the models with the removable sumpguard were made in the Wolfsburg factory, while the later ones without were made alongside the Arosa when production was moved to Spain.
I think you will find that all GTi's were, like the 3L, built at Wolfsburg. As they largely shared the same body (thinner steel but stronger), when Lupo (and Arosa) production switched to Brussels (not Spain), production of the 3L and Gti continued at Wolfsburg. Production of the 3L and GTi also continued for six months after other Lupo and Arosa models.
RAB
who told you that? Check your chassis number, it will either be the wolfsburg or spanish build code.
RAB
yep, brussels is right, as that is what the B in the chassis number shows. If it were spain, it would be a Y for pamplona.
Edited by lupogtiboy
None GTIs were built in Brussels rather than Spain or do you meen GTIs?
i have seen GTI's with a B in the chassis number
Blumming heck, learn something new every day!
my gti has W chassis code. the engine has poland embossed on it, but wolfsburg is not in poland. what does this mean?
I would be doubtful that they were genuine GTI's.
RAB
