mike-turbo Posted November 1, 2011 Report Share Posted November 1, 2011 Hi i have a 1.0l vw lupo and i need the torque setting for the subframe and wishbones?anyone have these to hand. Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted November 3, 2011 Report Share Posted November 3, 2011 FT is what i always use for critical things like this. Quote Link to comment Share on other sites More sharing options...
treblet Posted November 3, 2011 Report Share Posted November 3, 2011 I went with FT too! Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted November 3, 2011 Report Share Posted November 3, 2011 Yep I'll third a setting of FT Quote Link to comment Share on other sites More sharing options...
99hjhm Posted November 3, 2011 Report Share Posted November 3, 2011 Hope you are all using new bolts like VW recommend. Quote Link to comment Share on other sites More sharing options...
Bad Dog Posted September 21, 2012 Report Share Posted September 21, 2012 Ok, what's FT ? Quote Link to comment Share on other sites More sharing options...
GTIChris Posted September 21, 2012 Report Share Posted September 21, 2012 Fluffy towels Quote Link to comment Share on other sites More sharing options...
Ashh Posted September 21, 2012 Report Share Posted September 21, 2012 ****ing tight Quote Link to comment Share on other sites More sharing options...
Blaine Posted September 22, 2012 Report Share Posted September 22, 2012 (edited) Subframe mounting bolt (M12)Stage one...................50 Nm / 37 lbf ftStage two...................Angle-tighten a further 90 degreesWishbone pivot bolt ........70 Nm / 52 lbf ftWishbone rear mount (M12)Stage one...................50 Nm / 37 lbf ftStage two...................Angle tighten a further 90 DegAlso use new bolts as that further 90 degs is stretching the bolts so only ment to be done to a bolt once Edited September 22, 2012 by Blaine Quote Link to comment Share on other sites More sharing options...
Pete91 Posted September 22, 2012 Report Share Posted September 22, 2012 (edited) FT is just another measurement as oppose to NM Edited September 22, 2012 by Pete91 1 Quote Link to comment Share on other sites More sharing options...
JoeA Posted September 22, 2012 Report Share Posted September 22, 2012 100000FTs Quote Link to comment Share on other sites More sharing options...
Pete91 Posted September 22, 2012 Report Share Posted September 22, 2012 (edited) FT is what i always use for critical things like this.Does it make a difference? I always use NM purely because the first time i looked at a torque setting it happened to be measured in NM. Edited September 22, 2012 by Pete91 Quote Link to comment Share on other sites More sharing options...
Ashh Posted September 22, 2012 Report Share Posted September 22, 2012 I'm not sure if that's a genuine comment or in on the joke... Ft lbs? Quote Link to comment Share on other sites More sharing options...
JoeA Posted September 22, 2012 Report Share Posted September 22, 2012 There's a difference between FT and ft/lbs. Quote Link to comment Share on other sites More sharing options...
Pete91 Posted September 22, 2012 Report Share Posted September 22, 2012 There's a difference between FT and ft/lbs.Just different measurements for the same thing... Quote Link to comment Share on other sites More sharing options...
JoeA Posted September 22, 2012 Report Share Posted September 22, 2012 FT is not a measurement as such, it's either ft or not. Quote Link to comment Share on other sites More sharing options...
Ashh Posted September 22, 2012 Report Share Posted September 22, 2012 I was referring to Pete's comment... Ft Is the setting for everything Quote Link to comment Share on other sites More sharing options...
Pete91 Posted September 22, 2012 Report Share Posted September 22, 2012 Ah i was just reading it as an abreviation of ft lbs Quote Link to comment Share on other sites More sharing options...
Pete91 Posted September 22, 2012 Report Share Posted September 22, 2012 Just read back through this thread and realised i originally read it like a retard. What happens when dealing with customers and slyly fannying about on forums... Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted September 22, 2012 Report Share Posted September 22, 2012 FT is a universal tightening standard, it even covers things like bottle tops and jar lids 2 Quote Link to comment Share on other sites More sharing options...
