mccrindle Posted September 26, 2011 Report Share Posted September 26, 2011 Just wondering what alternatives to HID'd people recommend. Quote Link to comment Share on other sites More sharing options...
adamsanders Posted September 26, 2011 Report Share Posted September 26, 2011 'super bright bulbs' if you have to there still nothing on hids best 65 quid i have ever spend worth every penny get the 50w kit from hidsdirect awesome bit of kit Quote Link to comment Share on other sites More sharing options...
treblet Posted September 26, 2011 Report Share Posted September 26, 2011 Sadly aftermarket HID kits will be made illegal after next year unless fired with headlamp washers and self levelling head lamps...However they are far superior to any halogen bulb. Quote Link to comment Share on other sites More sharing options...
mccrindle Posted September 26, 2011 Author Report Share Posted September 26, 2011 that's a shame! i've seen quite a lot of threads on the web about them being made illegal and thats why i thought it'd be worth asking if there was alternatives. Hopefully something will be created to as good a standard as hid's to overcome the problem (: Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted September 26, 2011 Report Share Posted September 26, 2011 Alternative to HID's are normal lights I believe. Quote Link to comment Share on other sites More sharing options...
mccrindle Posted September 26, 2011 Author Report Share Posted September 26, 2011 Haha! Very good, I meant an alternative that is similar to hid's Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted September 27, 2011 Report Share Posted September 27, 2011 could try osram night breakers which is a standard bulb. Quote Link to comment Share on other sites More sharing options...
puggled Posted September 27, 2011 Report Share Posted September 27, 2011 Do you want them for appearance or for being able to see?Osram Nightbreakers are great in dry weather, light up signs from miles away, etc. I'm not so keen on them in the rain though. Quote Link to comment Share on other sites More sharing options...
mccrindle Posted September 27, 2011 Author Report Share Posted September 27, 2011 i'll have a look at these osram nightbreakers just after something that offers a similar product to hid's Quote Link to comment Share on other sites More sharing options...
puggled Posted September 27, 2011 Report Share Posted September 27, 2011 The only thing similar to HIDs are HIDs. No 55w bulb will give you the same output as a 35w HID. You can get bulbs that are similar colour. Thats why I was asking if it was the output or the style you were after. Quote Link to comment Share on other sites More sharing options...
mccrindle Posted September 27, 2011 Author Report Share Posted September 27, 2011 not sure to be honest, i just guessed if the style was similar so would the output. Quote Link to comment Share on other sites More sharing options...
Bickerton Posted September 28, 2011 Report Share Posted September 28, 2011 I used to use 100watt rally bulbs, not meant to but aslong as they are alligned properly its not an issue Quote Link to comment Share on other sites More sharing options...
buxton Posted September 28, 2011 Report Share Posted September 28, 2011 if you want 8k colour of hids search led h4 headlights Quote Link to comment Share on other sites More sharing options...
treblet Posted September 28, 2011 Report Share Posted September 28, 2011 not sure to be honest, i just guessed if the style was similar so would the output. The light is generated in a totally different way, halogen bulbs work essentially by passing a voltage through a wire which glows white hot. High Intensity Discharge (HID) bulbs on the other hand work by passing a super high voltage (approx 23,000V to start them) through a gas which in turn fluoresces. This is the reason that HID's need a ballast unit to start them and why when turning them on the flash brightly at first, then dim slightly and then get brighter as the gas warms up and the voltage output by the ballast turns down. Quote Link to comment Share on other sites More sharing options...
mccrindle Posted September 28, 2011 Author Report Share Posted September 28, 2011 ok, cheers for the info treblet. Think i'll have a good look at those osram nightbreakers and also the other type of bulbs mentioned Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted September 28, 2011 Report Share Posted September 28, 2011 I ahve Osram bulbs in my Lupo, not sure what model they are though.The are sooo much better than the standard bulb, not just brighter, but give a much more even output. Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted September 28, 2011 Report Share Posted September 28, 2011 i did dabble with the phillips extreme bulbs but one went pop after 2 months and at £27 a set i wasnt pleased to say the least.... Quote Link to comment Share on other sites More sharing options...
mccrindle Posted September 28, 2011 Author Report Share Posted September 28, 2011 Seems like nightbreakers it is then. Thanks for helped and opinions guys!! Quote Link to comment Share on other sites More sharing options...
puggled Posted September 29, 2011 Report Share Posted September 29, 2011 I got them from ebay at £11 a pair not £18 each at some retailers! Quote Link to comment Share on other sites More sharing options...
puggled Posted September 29, 2011 Report Share Posted September 29, 2011 +90 have a short enough life, but +120? Must be pushing the filaments awfy far.Also I'm sure there is a reason Philips and Osram don't quote such high ratings. Like you don't get that in reality. Quote Link to comment Share on other sites More sharing options...
mccrindle Posted September 29, 2011 Author Report Share Posted September 29, 2011 think i'll go for nightbreakers Quote Link to comment Share on other sites More sharing options...
3lward Posted September 30, 2011 Report Share Posted September 30, 2011 Nightbreakers are pretty good, i had Halford own bluevision in my old mk3 fiesta a little bit bluey for my liking but also good.Btw im pretty sure HID's have always failed mot's if no self-levellers or washers its nothing new. Quote Link to comment Share on other sites More sharing options...
