olliejones Posted September 11, 2011 Report Share Posted September 11, 2011 (edited) Hi Guys,I was driving my lupo the other day when it died - as if Id stalled it. When I turn the key it sounds like somethings spinning? It doesnt turn over?Any suggestions - I'm guessing its not good Ollie Edited September 12, 2011 by olliejones Quote Link to comment Share on other sites More sharing options...
Pete Posted September 11, 2011 Report Share Posted September 11, 2011 Starter motor I'd say, if you can hear something spinning but the engine isn't turning over. Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 11, 2011 Author Report Share Posted September 11, 2011 Hey loopete,That sounds promising, but would that be the reason why it cutted out - because the starter motors gone? Quote Link to comment Share on other sites More sharing options...
Rich Posted September 11, 2011 Report Share Posted September 11, 2011 my half arsed assumption is, check the timing belt. Quote Link to comment Share on other sites More sharing options...
Pete Posted September 11, 2011 Report Share Posted September 11, 2011 No, was just thinking that. Could be flywheel related, as the starter meshes with the flywheel to help kick start your engine. But your flywheel also bolts to your clutch which obviously gives you your drive. How did it stall? Did it just die while stationary or were you taking up drive when it died? Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 11, 2011 Author Report Share Posted September 11, 2011 I was driving steady at about 50mph. It was sounding alittle 'rattlely' before it happened - Just hope its not anything massive like cambelt or gearbox. Quote Link to comment Share on other sites More sharing options...
Pete Posted September 11, 2011 Report Share Posted September 11, 2011 my half arsed assumption is, check the timing belt.It should still crank over though if it's jumped a tooth, but yeah, stalling your car can sometimes cause it to lose timing. Quote Link to comment Share on other sites More sharing options...
Pete Posted September 11, 2011 Report Share Posted September 11, 2011 So you were driving steadily at 50, the engine cut out at that speed, did you pull to a stop and try to start it again or try it while it was still on the move? Quote Link to comment Share on other sites More sharing options...
Rich Posted September 11, 2011 Report Share Posted September 11, 2011 I'm not saying it's lost timing, I'm saying pop the cover off and check the belts are still intact. Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 11, 2011 Author Report Share Posted September 11, 2011 Yep. I was driving back from work in a 50, doing 50mph and it just died, dash lights came on and all power steering etc cut out (just as if Id stalled). I coasted into a side road and tried to get it going again but it just sounds like somethings spinning. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted September 11, 2011 Report Share Posted September 11, 2011 If you try and start it in 1st does it jump? Quote Link to comment Share on other sites More sharing options...
Pete Posted September 11, 2011 Report Share Posted September 11, 2011 Alright Rich calm down buddy! I'm just saying that even without the belt it should still crank, although if it does crank with no belt then you're in trouble! Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 11, 2011 Author Report Share Posted September 11, 2011 If you try and start it in 1st does it jump? Hello mate, just went out and checked and yes it does. Quote Link to comment Share on other sites More sharing options...
Pete Posted September 11, 2011 Report Share Posted September 11, 2011 So it does crank then? Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 11, 2011 Author Report Share Posted September 11, 2011 So it does crank then? Well, I must be honest I didnt try starting it in 1st gear without the clutch down - that does seem to jump. But if you try start it normally in neutral it doesnt crank. Quote Link to comment Share on other sites More sharing options...
Pete Posted September 11, 2011 Report Share Posted September 11, 2011 How bizarre, I'll sleep on it! Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 11, 2011 Author Report Share Posted September 11, 2011 How bizarre, I'll sleep on it! Nooooooooooo, I wont be able to sleep now, haha! Only messing, look forward to hearing some more ideas Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted September 11, 2011 Report Share Posted September 11, 2011 I think we may need a video Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 12, 2011 Author Report Share Posted September 12, 2011 I think we may need a videoWill do tonight fella Quote Link to comment Share on other sites More sharing options...
Slow&low Posted September 12, 2011 Report Share Posted September 12, 2011 just got de -ja vous mate my car did this a couple of years ago.... cambelt had gone. i'd brace for bad news and hope for the best. Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 12, 2011 Author Report Share Posted September 12, 2011 just got de -ja vous mate my car did this a couple of years ago.... cambelt had gone. i'd brace for bad news and hope for the best. Not good. Any rough idea of cost? Quote Link to comment Share on other sites More sharing options...
Dogbot Posted September 12, 2011 Report Share Posted September 12, 2011 If the belt has snapped mate, its more, a how longs a piece of string, you'll be looking at possibly bent valves, damaged pistons, it could be a nightmare, however that said, i snapped a tensioner on a my old car & managed to turn her off quick enuff an save all damage.... Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 12, 2011 Author Report Share Posted September 12, 2011 If the belt has snapped mate, its more, a how longs a piece of string, you'll be looking at possibly bent valves, damaged pistons, it could be a nightmare, however that said, i snapped a tensioner on a my old car & managed to turn her off quick enuff an save all damage....Cheers buddy. I'm going to unclip the cover an see if the belts still on - fingers crossed :s Quote Link to comment Share on other sites More sharing options...
olliejones Posted September 12, 2011 Author Report Share Posted September 12, 2011 Just took off the cover and this is what I found..... Quote Link to comment Share on other sites More sharing options...
Newnesie Posted September 12, 2011 Report Share Posted September 12, 2011 Belts snapped? Quote Link to comment Share on other sites More sharing options...
