lupolouie Posted January 20, 2010 Report Share Posted January 20, 2010 right im unsure what to do here i have changed my mind on what i want my car for.ive decided to go for fast road car/track car but im unsure what size wheels to go for ,ie 15" or 16",7j or 8j?im looking at geting some compomotive mo,s but i still want it to look good aswell for the odd shows i go to can anyone help? Quote Link to comment Share on other sites More sharing options...
loopzmatt Posted January 20, 2010 Report Share Posted January 20, 2010 compomotive th monos look swish there 15x8 Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 20, 2010 Report Share Posted January 20, 2010 right im unsure what to do here i have changed my mind on what i want my car for.ive decided to go for fast road car/track car but im unsure what size wheels to go for ,ie 15" or 16",7j or 8j?im looking at geting some compomotive mo,s but i still want it to look good aswell for the odd shows i go to can anyone help?I'm a fan of 16's on a GTI, they dont seem to look any bigger with 195/40 tyres. Width depends on the offsets, think 7 is a safer bet, but people have had 8's on here in 15" 'GTi T' has 7x16" Quote Link to comment Share on other sites More sharing options...
liam_c Posted January 20, 2010 Report Share Posted January 20, 2010 I got 15x8 not sure on offset but tyres still rub quite bad in the arches with 45 profile tyres. Quote Link to comment Share on other sites More sharing options...
melonman Posted January 20, 2010 Report Share Posted January 20, 2010 Ive got 15x8s running 195/45s, scrubbingggg a little bit Quote Link to comment Share on other sites More sharing options...
PaperWeight1 Posted January 20, 2010 Report Share Posted January 20, 2010 If it's for performance then 15x6.5" or 15x7". Close to standard size butlighter.You can probably drop the offset a bit for a wider track, not sure how far you can go - depends how low you are and how hard you're going to drive.I know Rota's aren't popular on here but slipstreams are fairly light or superleggeras, ultraleggeras, rota GT3's etc. Quote Link to comment Share on other sites More sharing options...
Naif Posted January 20, 2010 Report Share Posted January 20, 2010 I nearly posted something along these lines up earlier.I'm guessing 16x7 should fit fine in GTi arches? ET 49 I think.Considering buying alloys for my current car that I could carry over to my GTi when I finally purchase one. Quote Link to comment Share on other sites More sharing options...
PaperWeight1 Posted January 20, 2010 Report Share Posted January 20, 2010 Standard GTi wheels are 6.5" aren't they?So adding 0.5" by going to 7" you'll want to drop the ET by 0.25" compared with standard (since ET is from centre line).ET43 is standard - 6mm (0.25") = ET37. So you'd want to be around there... Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 20, 2010 Report Share Posted January 20, 2010 (edited) I nearly posted something along these lines up earlier.I'm guessing 16x7 should fit fine in GTi arches? ET 49 I think.Considering buying alloys for my current car that I could carry over to my GTi when I finally purchase one.They will fit fine, sit the same as a Bathurst, just bigger. Really need 195/40 tyres to work on a GTIEdit.. You would have 12mm less clearence to the strut. Edited January 20, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
Naif Posted January 20, 2010 Report Share Posted January 20, 2010 I'd get them on 40's for the GTi definitely. It's needed to keep the speedo reading accurately too iirc?What's "clearance to the strut" related to? Noob question probably Quote Link to comment Share on other sites More sharing options...
Philplop Posted January 20, 2010 Report Share Posted January 20, 2010 Means the gap between the back of the wheel and the suspension. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 20, 2010 Report Share Posted January 20, 2010 I'd get them on 40's for the GTi definitely. It's needed to keep the speedo reading accurately too iirc?What's "clearance to the strut" related to? Noob question probablyYes, speedo readings, and to avoid scrubbing. Quote Link to comment Share on other sites More sharing options...
Naif Posted January 21, 2010 Report Share Posted January 21, 2010 It's half 12 and I've already learnt something worthwhile. Cheers Quote Link to comment Share on other sites More sharing options...
Mike_M Posted January 21, 2010 Report Share Posted January 21, 2010 I have 7.5 x 16 ET 35 with 195/40/16 and they are a perfect fit and are the same rolling radius as the original 15's so the speedo is accurate. Quote Link to comment Share on other sites More sharing options...
Mike_M Posted January 21, 2010 Report Share Posted January 21, 2010 Here is a pic of my first 16" rims..........same spec: Quote Link to comment Share on other sites More sharing options...
JamesU Posted January 21, 2010 Report Share Posted January 21, 2010 I didnt read the thread tbh...But if Al got 16's on a non gti and pulled it off well. Then theoretically a GTI should be able to pull of 22" spinners.Depends on the wheel though, Bathurts are 15's and they look good, but then i've seen some 16's look very good. Quote Link to comment Share on other sites More sharing options...
ley Posted January 21, 2010 Report Share Posted January 21, 2010 I have a set of 16x7" ET40 Rota gt3's on mine with 195 40s fitted though ther is the odd rub at the arches so i will replace the tyres with a 35 profilethis should solve any problems. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 21, 2010 Report Share Posted January 21, 2010 I have a set of 16x7" ET40 Rota gt3's on mine with 195 40s fitted though ther is the odd rub at the arches so i will replace the tyres with a 35 profilethis should solve any problems.That must be really low to do that?? Quote Link to comment Share on other sites More sharing options...
Mike_M Posted January 22, 2010 Report Share Posted January 22, 2010 The ET40 is the issue I think. If it was ET35 (add a 5mm spacer) you would have no probs as my spare 16x7 ET35 with the same tyre is fine and gives even more clearance that the 7.5 Quote Link to comment Share on other sites More sharing options...
Philplop Posted January 22, 2010 Report Share Posted January 22, 2010 I have a set of 16x7" ET40 Rota gt3's on mine with 195 40s fitted though ther is the odd rub at the arches so i will replace the tyres with a 35 profilethis should solve any problems.You can't get 195/35's. As far as I know, the narrowest width 16" tyre that comes in 35 profile is a 215/35/16.Is it rubbing the arches or the arch liners? Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted January 22, 2010 Report Share Posted January 22, 2010 The ET40 is the issue I think. If it was ET35 (add a 5mm spacer) you would have no probs as my spare 16x7 ET35 with the same tyre is fine and gives even more clearance that the 7.5surely if he rubbing the arch at e40 then et35 will rub more? Quote Link to comment Share on other sites More sharing options...
Mike_M Posted January 23, 2010 Report Share Posted January 23, 2010 He would be rubbing the inside arch liner on ET40 and almost full lock. Et 35 would give that extra clearance and clear perpectly with a couple of mm spare Quote Link to comment Share on other sites More sharing options...
vworks41 Posted January 23, 2010 Report Share Posted January 23, 2010 I've always liked Mo's. Very strong and good caliper clearance as well.I'd go for 7x15's for best cornering, but 16's are a good compromise between looks and handling Quote Link to comment Share on other sites More sharing options...
lupolouie Posted January 23, 2010 Author Report Share Posted January 23, 2010 I've always liked Mo's. Very strong and good caliper clearance as well.I'd go for 7x15's for best cornering, but 16's are a good compromise between looks and handlinglove it looks mint! you still got your mo,s? fancy selling them? Quote Link to comment Share on other sites More sharing options...
