99hjhm Posted January 30, 2010 Author Report Share Posted January 30, 2010 (edited) Well that's what I was trying to say when I posted the above! The clutch and brake pedal switches show '1' when pressed, so if since they were showing 0 when you read the measuring block I wouldn't have thought they would be holding you out Oh I see.Looking at this..http://www.ross-tech...ks/060-069.htmlIt's in a different part of the measuring block though, the digits I have are in the 4 column across, looks like the pedal opperation is in the second box.I'm not going to admit driving whilst pushing 3 different buttons and reading off a laptop screen at the same time, weather I was or not. Guess the car doesn't have to be moving to try the values though.Because the TDI used a well known engine, it has a complete label file, the GTI has no label file for the AVY engine on VAG-COM. So I'm totally guessing, or I was untill I found the above link. Edited January 30, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
jon_273 Posted January 30, 2010 Report Share Posted January 30, 2010 Right now I understand. It's kind of hard to check the switch is working properly when you don't know which measuring block to look at!I tested mine while sat on the drive. I even managed to get a row of 1's by pressing all the switches at the same time (little things, little minds )Also, you know you have to be doing over 20mph for the cruise to work? Maybe the part of the ECU that operates the cruise control is not seeing the cars speed? Just a thought Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 30, 2010 Author Report Share Posted January 30, 2010 Right now I understand. It's kind of hard to check the switch is working properly when you don't know which measuring block to look at!I tested mine while sat on the drive. I even managed to get a row of 1's by pressing all the switches at the same time (little things, little minds )Also, you know you have to be doing over 20mph for the cruise to work? Maybe the part of the ECU that operates the cruise control is not seeing the cars speed? Just a thoughtlol.. Yes, I thought it might be 30mph, Al said 25mph, display was in kph, but I tried all speeds and gears. Think the measuring block says 25kphI tested it on the drive too, but that was when I was just flicking through the channels.Getting a row of 1's did cross my mind too , didn't tempt it though.The measuring block is seeing speed too, can't see whats wrong other than the pedal switch or throttle body issue, maybe lack of wiring to the TB at a guess, will see tomorrow.Thanks Jon. Quote Link to comment Share on other sites More sharing options...
ry203 Posted January 31, 2010 Report Share Posted January 31, 2010 Car looks amazing. I also have a black GTi and have been wanting to change the steering wheel for a while. Ive seen this on ebay and was going to go for it but am worried about the airbag side of things. How easy / dangerous would it be to change it over? Seen as this one doesn't have the stereo controls on, is it likely to be a straight swap? Thanks for the help... Ryan Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 31, 2010 Author Report Share Posted January 31, 2010 Car looks amazing. I also have a black GTi and have been wanting to change the steering wheel for a while. Ive seen this on ebay and was going to go for it but am worried about the airbag side of things. How easy / dangerous would it be to change it over? Seen as this one doesn't have the stereo controls on, is it likely to be a straight swap? Thanks for the help... RyanThe steering wheel controls make no difference, as the Lupo has no need, wires for them.That one will fit, same seller as Casper GTI had his from.Airbag should be fine, but you need some knowledge of wiring/soldering to connect up the new one. Quote Link to comment Share on other sites More sharing options...
nfbr Posted January 31, 2010 Report Share Posted January 31, 2010 Car looks amazing. I also have a black GTi and have been wanting to change the steering wheel for a while. Ive seen this on ebay and was going to go for it but am worried about the airbag side of things. How easy / dangerous would it be to change it over? Seen as this one doesn't have the stereo controls on, is it likely to be a straight swap? Thanks for the help... RyanIt won't fit straight off... Casper had to machine down the rear face of the steering wheel other wise it would crush the lupo slip ring when you tighten it up!It's not an easy fit at all the Mk6 wheel. Quote Link to comment Share on other sites More sharing options...
ry203 Posted February 2, 2010 Report Share Posted February 2, 2010 hmm..i can solder and have a basic knowledge of electronics.. A* at GCSE lol..I don't like the idea of machining it down though...what is a slip ring? (I've only ever had an austin mini wheel off and I'm guessing this is slightly different Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 2, 2010 Author Report Share Posted February 2, 2010 hmm..i can solder and have a basic knowledge of electronics.. A* at GCSE lol..I don't like the idea of machining it down though...what is a slip ring? (I've only ever had an austin mini wheel off and I'm guessing this is slightly different I dont think it would need much, probably could be done with a file.You would also need to be able to turn the airbag light off afterwards. Quote Link to comment Share on other sites More sharing options...
nfbr Posted February 2, 2010 Report Share Posted February 2, 2010 I dont think it would need much, probably could be done with a file.Not according to John? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 2, 2010 Author Report Share Posted February 2, 2010 Not according to John?oh.. Have to ask him.Thought it was just the radius on the back on the Golf wheel was to big for the bore of the Lupo slip ring.See somebody else on here now has a Mk6 wheel. Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted February 3, 2010 Report Share Posted February 3, 2010 The mk6 wheel sits further back on the spindle and squashes the slip ring, I had to adjust the slip ring to stop the horn going off and the slip ring jamming. Quote Link to comment Share on other sites More sharing options...
ry203 Posted February 4, 2010 Report Share Posted February 4, 2010 so it's doable without too much hastle then Quote Link to comment Share on other sites More sharing options...
nfbr Posted February 4, 2010 Report Share Posted February 4, 2010 The mk6 wheel sits further back on the spindle and squashes the slip ring, I had to adjust the slip ring to stop the horn going off and the slip ring jamming.I thought you ended up machineing down the rear face of the wheel? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 4, 2010 Author Report Share Posted February 4, 2010 (edited) This is MY car thread. Edited February 4, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
nfbr Posted February 4, 2010 Report Share Posted February 4, 2010 (edited) LOL James. Edited February 4, 2010 by nfbr Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 4, 2010 Author Report Share Posted February 4, 2010 LOL James.FFS.Like I could ever find a comeback for that. Quote Link to comment Share on other sites More sharing options...
nfbr Posted February 5, 2010 Report Share Posted February 5, 2010 LOL! I'm good at what I do... Quote Link to comment Share on other sites More sharing options...
CopeyCupra Posted February 5, 2010 Report Share Posted February 5, 2010 priceless Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 6, 2010 Author Report Share Posted February 6, 2010 Is the missing letter 'O'? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 7, 2010 Author Report Share Posted February 7, 2010 (edited) Little boring update, just so I don't need to remember what I've done/not done.Fitted a new drivers door lock, now all the central locking works right, interior light works and the ararm doesn't go off when you get in the car... Refitted the de-locking barrels now I know it's all OK.. And took some pics for a guide.Then I fitted a new LED in one of the door lights I fitted ages ago, been flashing on and off for ages. Got the light fitting better in the panel too, must be one of the best mods i have done, just looks perfectly OEM.Today I washed and vacuum'd the car, went over it for hours, jet washed all the wheel arches too, not cleaned the interior since way before Christmas.I cut down the rear head rests to they sit just above flush on the rears seats, look much better and you can see more out of the rear screen.Might order some coilovers this week, if I have time. Changed the main beam light bulbs for H3 'Ultra' bulbs that nfbr recommended, they are really really good, and cost all of about £10 on ebay.Another LED has blown in the W8 interior light, so need to change that, got some brighter LED's for the side light bulbs coming too.Got a new scuttle panel to fit after I bust mine when taking it off when playing with the ECU for cruise control. 14th February 2010Did a few things that needed finishing.....Changed the sidelight bulbs to 9 LED SMD bulbs for extra brightness.Changed the wire cover on the RS4 mirror to a new one, after I found the old one didn't need modifying. Changed a blown LED in the interior light.Washed and half polished the car.Sealed the windscreen with Jetseal 109. Edited February 14, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
Little Green Giant Posted February 7, 2010 Report Share Posted February 7, 2010 that does look really sweet!! nice work Quote Link to comment Share on other sites More sharing options...
Jen Posted February 7, 2010 Report Share Posted February 7, 2010 very tastefully done i like it xx Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 21, 2010 Author Report Share Posted February 21, 2010 (edited) Just to say....I ORDERED COILOVERS!! :) Edited February 21, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
Matty. Posted February 21, 2010 Report Share Posted February 21, 2010 At last What setup you get? Quote Link to comment Share on other sites More sharing options...
Plug Posted February 21, 2010 Report Share Posted February 21, 2010 Just to say....I ORDERED COILOVERS!! :) About time dude ! Quote Link to comment Share on other sites More sharing options...
