Lupo
99hjhm
My Black 2002 Lupo GTI... Bought as standard. Has been looking on and off for a while for one, idealy a silver one. never saved for long enough to buy one. Then this came along, and the guy needed a quick sale. :)So I have myself a Lupo. Kept it standard for quite a while, but couldn't resist a few mods. Didn't want to spoil it, so decided on an OEM+ theme, small mods that only a few will notice.
The car previously belonged to Club Lupo members... Presty and pistolpete69.
Mods so far
Interior
  • VW 3-button flip keys
  • Auto lock/unlocking.. via VAG-COM
  • Passat W8 interior light... In custom satin black, SMD 'Xenon' bulbs
  • Golf Mk4 LED boot light
  • Golf Mk4 boot 12v aux plug
  • Golf Mk4 LED door courtesy lights
  • Golf Mk5 R32 gearknob
  • Golf Mk5 GTI Steering wheel with DSG padels and buttons
  • Skoda Fabia VRS chrome door pins
  • Polo 6n2 glovebox, center console and underdash
  • Touareg torch.. Black
  • Golf Mk4 GTI Anniversary sunglasses holder
  • Comfort flashers
  • Audi RS4 US-spec auto-dimming mirror with digital compass
  • Audi TT knee rests
  • Audi TT Mk1 footrest
  • Polo 9N3 GTI handbrake cover
  • Golf Mk5/6 GTI handbook cover
  • Golf Mk4 R32 style satin silver door plastics
  • Audi A8? 12v aux blanking plug
  • Golf Mk4 GTI 25th Anniversary sill covers
  • Golf Mk6? chrome headlight switch w/fogs
  • Golf Mk6 chrome mirror switch
  • Mk5 Golf GTI front seats, custom sub-frames
  • VW Programable intermittant wipers
Audio
  • VW MFD version G sat-nav head unit
  • VW aerial booster
  • Dension 100 iPod link with CD retention kit
  • Coin tray in place of cup holder, with genuine iPod dock, remote control
  • iPod Nano with 5v charging adaptor
  • VW boot mounted CD changer
  • Golf Mk6 3.5mm Aux input plug in center console
Exterior
  • De-Lupo badged rear
  • Golf Mk5 GTI style red grill piping
  • SMD 'xenon' style sidelight bulbs
  • 'Xenon' 5000K main beam bulbs
  • Sharan stubby aerial.... Now removed
  • Polo Mk7/Passat estate hybrid rear wiper
  • Golf Mk5/6 GTI Badges
  • Sharan rear VW emblem
  • Golf Mk5 Shark fin aerial
  • 'Cambridge' Lupo SE rear lights
  • Diatem indicator bulbs
  • Latest dealer number plates and VW UK surrounds
  • LED number plate lights
  • Custom rear exhaust hanger
  • Golf Mk5 style gloss black mirror finish aluminium B-pillar trim
  • 'Pop-out' rear quarter windows
  • German style show plates and surrounds.
  • Euro spec stubby drivers mirror.
Engine
  • Audi R8 oil filler cap
  • Modified Audi R8 coolant bottle cap
  • Carbon coolant bottle cover
  • K&N panel filter
  • NGK Iridum plugs
  • ECS Tuning aluminium magnetic sump plug
  • Std airbox.
  • 3M Carbon fibre engine cover infills, satin silver painted engine cover middle, Mk5 GTI emblem.
  • Aluminium breather catch tank with silicone hoses.K&N breather filter.
  • Cabon cainster and N80 delete.. With resistor.
  • As Std ,131bhp 119ft/lbs torque. On Awesome GTi rollers 2010.
Brakes
  • DOT 5.1 brake fluid.
  • Black Diamond Predator rear pads, OEM discs.
  • Custom copper-nickel hard lines on rear beam.
  • Golf Mk2-4 'conversion' stainless steel rear hoses with stainless unions and banjo bolts.
  • Brembo max 280mm G60/IbizaCupra discs
  • EBC Greenstuff Ibiza Cupra pads
  • G60/Cupra polymer coated red carriers.
  • Goodridge stainless steel flexi hose kit with stainless unions and banjo bolts.
  • Switchable ABS controller.
Suspension
  • Whiteline/Awesome 20mm 24mm Rear Anti-Roll bar, fully adjustable.
  • Custom rose jointed adjustable RARB drop links.
  • KW V1 "Inox Line" coilovers, lowered 60mm on rear 50mm on front.
  • Camber increased on front to 1.75°, Toe -1mm to increase Ackerman steering.
  • Powerflex custom ARB link bushes.
  • Powerflex custom front ARB mounting bushes
  • Powerflex track control arm bushes, front and rear
  • Powerflex modified rear beam bushes
  • OMP Polo 6N front lower tie bar
  • Tie rod flip to reduce bumpsteer
  • AST fully adjustable solid top mounts, set for max castor
Transmission
  • Custom short shifter
  • Custom short gear lever
  • Fuchs Titan Race Syn 5 transmission oil
Wheels/Tyres
  • 16" BBS's 7.5J 4x100mm ET35. Spaced 5mm(ET30) on front, and 30mm(ET5) rear.
  • Golf Mk4 GTI Anniversary centre caps, custom dishes.
  • BBS stainless steel valve caps.
  • 195/40/16 Toyo T1-R's
  • Longer tapered wheel bolts, custom locking bolts.
or...
  • Chrome powdercoated 15" VW 'Bathursts' 6.5J 4x100mm ET43. Spaced 5mm(ET38) on front and 30mm(ET13) rear.
  • Audi RS4 centre caps.
  • BBS valves and stainless steel caps
  • Extended (30mm) wheel bolts.
  • 195/45/15 Toyo Proxes4 Tyres
Before Ultimate Dubs...
OMP front strut brace.
Custom induction install.
Mk5 Golf GTI 3-door interior.
Porsche Boxster S' rear brake calipers, custom ali brackets, custom HEL hoses.
Coming Soon...
16" BBS RX-II's (RS764's) Polished rim bolts, BBS valves and stainless steel caps, OEM BBS silver/carbon centres, VW wheel nut covers... Two sets of these!!!
Rear camber shims and toe correction..
Golf Mk5 boot handle in Arosa bootlid?
Porsche 996/Boxster S calipers, 305mm!! Seat Ibiza Cupra R front discs.
Rear stub axle spacers/beam extenders.
H&R Front anti-roll bar kit.
Pics from before I bought it...
First bit of work......
Cleaned and serviced over the April bank hols.
My car collection, Lupo, MGB, Ka.. That I'd had since I started to drive.
Parts used...
Oil and filter change... Mobil 1 0w/40
K&N panel air filter
Fuel filter
Brake and clutch fluid change... Dot 5.1
Pollen filter
Spark plugs... NGK Iridum
Rear wiper blade
Front wiper blades
Gearbox oil change
Aux drive belt
Fault codes checked
Throttle body cleaned, air box cleaned, breather box checked.
Edited by 99hjhm
  • 2 months later...
MFD Now fitted... Thanks Flying Custard who delivered it to my door!
It's a MFD G, latest version, has a 2007 maps disc.
Removing the Gamma and CD changer
The little helper, my cat Felix.
In, and sort of working, still no sat-nav, as the aerial need fitting correctly.
I have now found out that I need a plug and play lead to make the Gala function work, this is needed to carry a speed sensor to the satvav function. The MFD is a direct fit, the DIN cage is apparently smaller on a Lupo, I had no issues.
Edited by 99hjhm
Rear spoiler repainted and fitted with new brake light.
I stripped this back to remove all the paint, then had it painted at work.
Bought a new light from VW, with a new connector block.. As the old one had broken pins stuck inside it. I also replaced the spacers for the spoiler, and fitted new bolts.
It passed the MOT, but needs a new OS head lamp, as the unit has a crack and wont adjust correctly.
Other parts fitted and work done.....
New screws for the under tray so it could be fitted correctly.
New NS wing repeater.. Old one was cracked.
Door check strap pins changed, to take out the wear, which caused the OS one to fail in the past.
Full interior vallet.
Edited by 99hjhm
iPod in coin tray mod....
Hopefully, one day my Dension will come, and i can use my iPod again.... No UK stock at the moment!!
I had the Apple logo made in white vinyl, IF YOU WANT ONE, I HAVE COUPLE LEFT!
The holes in the front are for the dock remote.
Edited by 99hjhm
luving the splitter, want to do one on mine my but its gonna be trashed as mine sit way too low ;) the gtis always look good in black
that a mini you got the spoiler resting on, can see paddy hopkirks name on it??
Chris
Chris
Na... It's my MGC factory replica.
I like the cat pic lol
You want to see the video i have of the cat chasing the rear wiper whilst sitting on the parcel shelf.
wish mine looked that shiny ! what products do you use mate? ;)
Menzerna Intensive Polish (Power Finish) - P0 85 RD.. And another Menzerna Polish(110 RD?), both by machine. Then 3m Rosa wax, and Autoglym extra protection glaze. Clayed and washed before
where can i find an mfd? r they expensive?
By chance, one came up on here, the day I decided I wanted one.
eBay is your best bet.. I paid £290 for it, but it came with GPS antena, maps disc and loads of instruction manuals. By the way, they don't play CD's.
Edited by 99hjhm
Is it just satnav and cd changer controller then? Does it do anything else?
Yep.. It's sat nav and cd changer control, radio..... I'm adding a Dension iPod link also. You can also add tv tuner and dvd player B)B)
love the head unit! whats it from? Very OEM!
I think they were fitted in high end Bora's, Passat's and Sharrans... Upto 2004/5.
Todays mod... Audi R8 oil filler cap.
Cheapist from eBay... (Sorry Al).
Just need to clean the rest of the engine bay to match now.
Undecided on the R8 coolant bottle cap?? Edit: Doesn't fit a Lupo anyway
Edited by 99hjhm
