Lee Chaplin
VW fox over heating
Hello guys I am newbie I am after some advice my  fox 1.4 is pressurising  and throwing water out  you can smell.it runs quite hot . I have checked no white smoke no water in oil do they have any common faults regarding this topic
Hi, does it only pressurise when its hot? have you tried running it with the cap off from cold, if there are bubbles coming out constantly this would suggest a headgasket issue.
Does the temperature gauge show it over heating?
Does the fan come on?
Im no fox expert but would just be a few things to check
Same 1.4 engine as a polo 9n.
Not the head gasket.
That's my opinion.
Stuck thermostat if not HG.
oh, and welcome to club lupo... :)
Edited by mk2
On 11/14/2019 at 11:17 PM, Lee Chaplin said:
Thanks for the info guys easiest and cheapest option first thermostat I think
keep the post up to date. Have you sorted it yet?
I found the overheating problem thermostat was in bits I ordered another one and  the housing strange thing the car shop said it was discontinued  but they are getting me one from Gates. The housing was strange the thermostat pin extrudes  through the back of the housing it is defo correct as the hole is fluted  any of u guys seen this before.
