James_VW Posted July 21, 2019 Report Share Posted July 21, 2019 (edited) Does anyone know how to further disassamble the fuel cap? I need to spray it so would ideally like to remove the flap to avoid overspray etc. Edited July 21, 2019 by James_VW Quote Link to comment Share on other sites More sharing options...
Rich Posted July 21, 2019 Report Share Posted July 21, 2019 Quit being gay and mask it up. No chance of overspray and less chance of ****ing the cap. Quote Link to comment Share on other sites More sharing options...
mk2 Posted July 21, 2019 Report Share Posted July 21, 2019 He wants to do it properly does that pin push out? I want to repair the little rubber strap securing the fuel cap that clips onto the fuel door, but can't figure out how the fuel cap dismantles... anyone? oh, by the way, you can still get genuine replacement fuel door stickers, if you're trying to make it concours. 👍🏻 Quote Link to comment Share on other sites More sharing options...
LR5V Posted July 21, 2019 Report Share Posted July 21, 2019 I picked up a spare for mine, unfortunately its not to hand, not looked at it in detail -but I believe the flap is one piece, no separate pin. looking at the picture the black plastic sides slope in suggesting that during assembly the flap expands the sides before locating in the holes I would try working out a way to wedge both sides out and slide the flap in the direction and slide the flap out in the direction of the arrow Quote Link to comment Share on other sites More sharing options...
kt_lou_gti Posted July 22, 2019 Report Share Posted July 22, 2019 Fuel cap strap is straight forward, the strap is attached to the cap by a large flat donut which fits in a groove on the cap, insert a small flat head screwdriver between grrove and donut and ease donut out of groove working your way around cap. Pouring some hot water over the cap makes things a bit easier. Other end of strap is held to fuel box with a push fit peg. VW don't sell the straps seperately so you have to source a cap and good strap off ebay, with several sources in the VAG range, Lupo, Fabia etc. Quote Link to comment Share on other sites More sharing options...
yeha Posted July 22, 2019 Report Share Posted July 22, 2019 or do it the easy way... If you look closely where the rubber strap (fnar fnar) connects to the cap, there's a couple of small, 1mm dia., plastic pins. Simply push them through the rotating donut enough to release the strap. Attach new strap and push them back. Quote Link to comment Share on other sites More sharing options...
James_VW Posted July 22, 2019 Author Report Share Posted July 22, 2019 Hmm I'm sure I've got an old one kicking about somewhere. Might have to rip it apart to figure out how it works. I had thought it would be a pin but applying some force doesn't budge it. Quote Link to comment Share on other sites More sharing options...
kt_lou_gti Posted July 22, 2019 Report Share Posted July 22, 2019 (edited) Ah, learn something new every day, thought it seemed badly engineered at the time, faith restored By comparsion disassembling the lock barrel is easy. Edited July 22, 2019 by kt_lou_gti Quote Link to comment Share on other sites More sharing options...
mk2 Posted July 22, 2019 Report Share Posted July 22, 2019 48 minutes ago, kt_lou_gti said: Ah, learn something new every day, thought it seemed badly engineered at the time, faith restored By comparsion disassembling the lock barrel is easy. I'll second that. Thanks for the info people. This Lupo forum is great! 👍🏻 Quote Link to comment Share on other sites More sharing options...
