HELP! Oil leak
Puchateek
Hi guys,
A few days ago I found a small leak under the front of the car, I looked under to see what's going on, I saw the engine block was wet (dry conditions) and took some pictures...
I checked the engine oil, it's at the same level as before I saw the leak, coolant is there so it's not that... I'm clueless to be honest so I thought I'd ask?
Gearbox oil? It's a 1.0 petrol.
Thanks in advance!!
Well looking at the last close up, it seem's it's coming from the top of the beige cap (btw, there is a plastic cap attached to it, should it be placed over the beige hole entry, or leave it exposed?) The roads are dry at the moment, and there is a clear leak mark everywhere I go! Now thinking it could be head gasket seal if it's coming from the top?
36 minutes ago, Skezza said:
Isn't that the inspection hole?
Yes it is.
No oil should ever be in there. I would say this cap is a red herring and it's far more likely the leak or fluid is originating from somewhere higher up. Try again.
  • 8 years later...
Gearbox main seal to one of the axles... can be changed by disconnecting axle from flange, pulling out flange and "carefully" prising out the old seal and inserting a new one. About £7 for the seal. Drain old gear oil and fill with 3L fresh. 👍🏻 About an hours job.
