RichNor 1 Posted November 17, 2014 Report Share Posted November 17, 2014 So.. one of the PO's have pulled a fused wire from the battery directly into the original loom.Would someone here happen to know what the contact it enters is for? Quote Link to post Share on other sites
Pete 308 Posted November 17, 2014 Report Share Posted November 17, 2014 Ain't that like an amp cable?? So a non oem cable. Quote Link to post Share on other sites
Pete 308 Posted November 17, 2014 Report Share Posted November 17, 2014 Also just look in the general area of where the plug will reach and see if there is another matching plug, it may just be a spare plug to fit a component that your spec isn't fitted with. Quote Link to post Share on other sites
Kermit Girl 2 Posted November 17, 2014 Report Share Posted November 17, 2014 Looks like the type of fuse that is used for a sub-woofer Quote Link to post Share on other sites
RichNor 1 Posted November 17, 2014 Author Report Share Posted November 17, 2014 The red one is an amp cable, yes.But i don't get why he would run one into the loom.. The thicker red one has been pulled to the back, for amp power. Quote Link to post Share on other sites
Pete 308 Posted November 17, 2014 Report Share Posted November 17, 2014 Me neither, unless he didn't use the cable to power an amp and just used it to give a power supply to whatever that plug is supposed to be plugged into, have you tried disconnecting it and seeing what happens? Quote Link to post Share on other sites
RichNor 1 Posted November 17, 2014 Author Report Share Posted November 17, 2014 Me neither, unless he didn't use the cable to power an amp and just used it to give a power supply to whatever that plug is supposed to be plugged into, have you tried disconnecting it and seeing what happens?Yep. Everything seems to keep working. First thought was Headunit power, but it's not that. all lights and accesories seems to work wether it's unplugged or not. Idle also is the same with wire dced. Quote Link to post Share on other sites
Pete 308 Posted November 17, 2014 Report Share Posted November 17, 2014 I'd disconnect it fully then from the plug and the battery, just to be safe. Quote Link to post Share on other sites
mk2 326 Posted November 18, 2014 Report Share Posted November 18, 2014 looks like an audio amp feed, but in that position- it does look like an OEM feed. Could it be a washer jet heater circuit feed?How many contacts are there in the OEM plug (socket)? Can you trace where the other end of the cable ducting leads to? Quote Link to post Share on other sites
Skezza 327 Posted November 18, 2014 Report Share Posted November 18, 2014 I would just disconnect it. See if you lose anything. If nothing evidently dies, you don't want a live cable hanging around somewhere. Quote Link to post Share on other sites
mk2 326 Posted November 18, 2014 Report Share Posted November 18, 2014 I would just disconnect it. See if you lose anything. If nothing evidently dies, you don't want a live cable hanging around somewhere.Skezza's right. Quote Link to post Share on other sites
RichNor 1 Posted November 18, 2014 Author Report Share Posted November 18, 2014 Well. the wire goes into this bundle I will try to pull the fuse after work tomorrow, and see if anything stops working after a while. Quote Link to post Share on other sites
mk2 326 Posted November 19, 2014 Report Share Posted November 19, 2014 I think i found it... On my car (if its the same), it's red with a yellow trace. It comes from the battery fuse block- well it plugs into the end of the fuse block. No idea what its for though.... Looks like it is connected to the plus battery terminal. Quote Link to post Share on other sites
Silver! 0 Posted November 19, 2014 Report Share Posted November 19, 2014 Is there anything under your bonnet which looks like this? Quote Link to post Share on other sites
mk2 326 Posted November 20, 2014 Report Share Posted November 20, 2014 Is there anything under your bonnet which looks like this?You've also got one of them?!?! Just can't figure out why it's there.... Makes an annoying ticking sound too. Quote Link to post Share on other sites
danoid 58 Posted November 20, 2014 Report Share Posted November 20, 2014 And we always blame the tappets for the ticking.... 1 Quote Link to post Share on other sites
mk2 326 Posted November 20, 2014 Report Share Posted November 20, 2014 And we always blame the tappets for the ticking.... Quote Link to post Share on other sites
RichNor 1 Posted November 20, 2014 Author Report Share Posted November 20, 2014 I think i found it... On my car (if its the same), it's red with a yellow trace. It comes from the battery fuse block- well it plugs into the end of the fuse block. No idea what its for though.... Looks like it is connected to the plus battery terminal.Thats the one! Stil havent found out what its for though... Unplugged now, and hopefully something will stop working.. Like the Stereo headunit.. Quote Link to post Share on other sites
