Benjamin Posted June 2, 2014 Report Share Posted June 2, 2014 Not sure what it's actually spraying out, but it's quite a lot, covering my boot and rear bumper in little black bits of something? Any ideas? Also, the exhaust seems to sit a little low, I can see a bracket with bolt hole about a foot down the exhaust from the tips, should that be attached to something? Quote Link to comment Share on other sites More sharing options...
patroddy Posted June 2, 2014 Report Share Posted June 2, 2014 Not sure what it's actually spraying out, but it's quite a lot, covering my boot and rear bumper in little black bits of something? Any ideas? Also, the exhaust seems to sit a little low, I can see a bracket with bolt hole about a foot down the exhaust from the tips, should that be attached to something? you can put a long screw through that bracket into the boot and it will hold the exhaust up however that black stuff could be oil! could be something as simple as too much oil in the engine 1 Quote Link to comment Share on other sites More sharing options...
Silver! Posted June 2, 2014 Report Share Posted June 2, 2014 Engine oil. Check your level, if it's too high, get it out! If your levels are correct or low, then common fault is the valve stem seals. Quote Link to comment Share on other sites More sharing options...
danoid Posted June 2, 2014 Report Share Posted June 2, 2014 Bad spark plugs can always cause this Quote Link to comment Share on other sites More sharing options...
shearermax Posted June 2, 2014 Report Share Posted June 2, 2014 piston rings can too Quote Link to comment Share on other sites More sharing options...
jon_273 Posted June 2, 2014 Report Share Posted June 2, 2014 (edited) Not necessarily oil, touch the spots with your finger and see if it rubs away, could be unburnt hydrocarbons of the engine is running too rich. Edited June 2, 2014 by jon_273 1 Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 2, 2014 Author Report Share Posted June 2, 2014 They rub off easily, doesn't feel 'oily' as such. Engine oil level is ok. How would I check piston rings and spark plugs? Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 2, 2014 Author Report Share Posted June 2, 2014 you can put a long screw through that bracket into the boot and it will hold the exhaust up however that black stuff could be oil! could be something as simple as too much oil in the engine Thanks, will get the drill out later! Quote Link to comment Share on other sites More sharing options...
Mitchell Posted June 2, 2014 Report Share Posted June 2, 2014 compression test it Quote Link to comment Share on other sites More sharing options...
patroddy Posted June 2, 2014 Report Share Posted June 2, 2014 Thanks, will get the drill out later! i believe Piers did a how to somewhere if you give it a search Quote Link to comment Share on other sites More sharing options...
Silver! Posted June 2, 2014 Report Share Posted June 2, 2014 Take your plugs out and check them for carbon fouling; dark black\sooty Rings, best to get a compression test, though you will most likely be burning some oil, so top up to the level and check after a good run. Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 2, 2014 Author Report Share Posted June 2, 2014 Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted June 2, 2014 Report Share Posted June 2, 2014 Mine was doing that, had a piston ring on cylinder 3 that was letting oil past it, had the engine rebuilt, bore re-honed and she's good as new! 1 Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 2, 2014 Author Report Share Posted June 2, 2014 Mine was doing that, had a piston ring on cylinder 3 that was letting oil past it, had the engine rebuilt, bore re-honed and she's good as new!Oh good. Sounds like an easy fix :-/ Quote Link to comment Share on other sites More sharing options...
danoid Posted June 2, 2014 Report Share Posted June 2, 2014 check plugs, easier! Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 2, 2014 Author Report Share Posted June 2, 2014 check plugs, easier!I will do first, any recommendations on new spark if it needs them? Quote Link to comment Share on other sites More sharing options...
arosaSDI Posted June 2, 2014 Report Share Posted June 2, 2014 my r33 gtr did the same, a few weeks later it went boom but then it was Jap scrap Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 2, 2014 Author Report Share Posted June 2, 2014 That's an encouraging story let's hope mine doesn't do that Quote Link to comment Share on other sites More sharing options...
danoid Posted June 2, 2014 Report Share Posted June 2, 2014 (edited) For plugs go for NGK.When was the last time they were changed? If it was yonks ago then no harm if it doesn't resolve the issue as they are not massively expensive anyway Edited June 2, 2014 by danoid 1 Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 2, 2014 Author Report Share Posted June 2, 2014 Thanks, I'll get some tomorrow! No idea when they were last changed, only bought the car 2 weeks ago and having a few teething problems. Quote Link to comment Share on other sites More sharing options...
danoid Posted June 3, 2014 Report Share Posted June 3, 2014 Hmm, if thats the case also check/change the air filter aswell, as this can also make your car run rich Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 20, 2014 Author Report Share Posted June 20, 2014 Now completed a full service myself. Apart from fuel filter (couldn't get it off). Changed spark plugs aswel, the ones that were in the car were Bosch plugs, have I read that they're not great? Replaced with all genuine parts and ngk spark plugs, given the car a clean and will see if it makes a difference when I've given it a good run! Quote Link to comment Share on other sites More sharing options...
Rich Posted June 20, 2014 Report Share Posted June 20, 2014 Is this the silver resprayed one which was for sale on fleabay a few months back ? Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 22, 2014 Author Report Share Posted June 22, 2014 It was on eBay, but I wasn't aware it had had been resprayed :-/ Quote Link to comment Share on other sites More sharing options...
Rich Posted June 22, 2014 Report Share Posted June 22, 2014 You're burning oil.Stick some 15/40 in as it's thicker when cold.If it gets really bad bang it full of hypoid gearbox oil and stick it back on the bay. Quote Link to comment Share on other sites More sharing options...
