breamy Posted March 27, 2010 Report Share Posted March 27, 2010 what exactly would be involved in this? what needs changing? can possibly get a box cheap Quote Link to comment Share on other sites More sharing options...
Philplop Posted March 27, 2010 Report Share Posted March 27, 2010 As far as I know, the boxes swap straight over.The only people I know who have done it is Luke (db) and gtidan, and neither of them are on here very much any more. Quote Link to comment Share on other sites More sharing options...
nfbr Posted March 28, 2010 Report Share Posted March 28, 2010 Luke didn't actually do it himself. Midland VW did it on his behalf. As far as I know you need the box, the cables, the shifter off the top of the box and the gearstick/linkage mechanism itself from the 6 speed.Not just the box! Quote Link to comment Share on other sites More sharing options...
penry Posted March 28, 2010 Report Share Posted March 28, 2010 As far as im aware, as long as you have the gearbox with the selector arm on (should have this usually still on there) then its a straight swap. You dont need the shift tower, you can just swap the gearknob top bit over to the 6spd one! Ive got a 5spd box in my garage from when i broke a gti, along with shifter etc if you want to compare part numbers. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted March 28, 2010 Report Share Posted March 28, 2010 The selector arm/shifter is the same.The gear lever unit changed somewhere throught production of the 5 speed model as far as I can tell, so might be the same or atleast compatable. Checking some of the cables, they seem to have the same part numbers, not checked all the parts though. Quote Link to comment Share on other sites More sharing options...
Nadeemaashraf Posted April 9, 2013 Report Share Posted April 9, 2013 Any further info on this? Quote Link to comment Share on other sites More sharing options...
treblet Posted April 9, 2013 Report Share Posted April 9, 2013 You realise this post is about 3 years old? Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 9, 2013 Report Share Posted April 9, 2013 You realise this post is about 3 years old?If he didn't reply on this I bet someone would have told him to use the search Quote Link to comment Share on other sites More sharing options...
Rich Posted April 9, 2013 Report Share Posted April 9, 2013 To finalise, it's just a simple box change.All you need is a gearbox. Quote Link to comment Share on other sites More sharing options...
Thissy Posted April 10, 2013 Report Share Posted April 10, 2013 ^ He speaks sense, only a couple of hours job!Mike Quote Link to comment Share on other sites More sharing options...
Rich Posted April 10, 2013 Report Share Posted April 10, 2013 Mike, have you got a spare full car GTI wiring loom kicking about along with the ecu ? 1 Quote Link to comment Share on other sites More sharing options...
Nadeemaashraf Posted April 10, 2013 Report Share Posted April 10, 2013 So all you need is a 6 speed box? Herd they don't fit as the bell housing of a 5 speed is a different size to the 6 speed? Quote Link to comment Share on other sites More sharing options...
Thissy Posted April 10, 2013 Report Share Posted April 10, 2013 I do rich, but the one I have which is 100% complete I'm hoping to use in the mk1.. Have a couple of ecu's knocking about and an engine loom though if that's any use to you, interior loom isn't there though.. Mike Quote Link to comment Share on other sites More sharing options...
Rich Posted April 11, 2013 Report Share Posted April 11, 2013 I reckon I could probably adapt a standard interior loom to fit Quote Link to comment Share on other sites More sharing options...
Nadeemaashraf Posted April 12, 2013 Report Share Posted April 12, 2013 I have a 6 speed Gti ecu for sale. And other bits. Quote Link to comment Share on other sites More sharing options...
Thissy Posted April 12, 2013 Report Share Posted April 12, 2013 Right I will dig it out and see what there is too work with.. Have a feeling it was a pikey removal hours before the shell got weighed in, sure it will be fine though.. Il drop you a pm in a few days..Mike Quote Link to comment Share on other sites More sharing options...
