My Lupo: too much to repair?
Duncan Beaumont
If it's the power steering hydraulic hoses (common problem), there is a company on here that makes to order for us. About £200 a complete set. Unusual for the seals in the rack to fail, as they typically last about 200k miles. Else it'll have to be a reclaimed steering rack. New no longer available. It is the same as 6N polo.
The welding is the big one. Depends what they'll charge you. And they'll have to make up some sheet metalwork. And seal it/rustproof it and spray it once done.
But if the car is in overall good shape, it's probably worth doing as you already know the car well. And if lowish milage, the car is probably worth about £2k in good order?
  • 4 weeks later...
  • 1 month later...
I'd be tempted to take it to a different garage. Those assembly jig mounting points (they're not jacking points), which were used on the production line serve no purpose to the car now. Any MOT inspector should realise that. The rule is - if there is any structural rust within 300mm of a suspension component, it's a serious fault = fail. But those are NOT structural.
So the only thing are the power steering pipes, which is a relativeky quick fix. And not expensive either. And the car is ULEZ compliant! None of mine are...
4 hours ago, Duncan Beaumont said:
My daughter’s Lupo is still at the garage and I’ve been offered £100 to scrap it. Does anyone want to buy it for spares or project car as engine and body are in great order - recently had the timing belt changed 😔. It’s near York.
I would have been interested if i didn’t find the parts i needed for my ‘Hot Rod’ which I set on fire and to which I’ve just about resolved. TBH you should take about 20 pics from all around the bodywork inc sills, arches (close ups) under spare wheel well, sill @ A post to chassis area and rear axle so we can assess it for you. These cars are not like any Corsa or poxy shite fiestas, they have a following because they are robust and the Doc martins of the small car world. They also probably produce plenty of  fun as for  any small micro car ( using a classic Fiat 500 as example).
Your question should be do I put it right now or do I bag it and bring it out in another ten to twenty years?
I stand by my 150 and it's gone offer
 It's 50% above the scrap value, I have to take time to collect and then you can have knowledge it will live again.
  • 3 weeks later...
