crashtestdummy Posted March 3, 2023 Report Share Posted March 3, 2023 I need some help with my non starting Lupo 3L 😟 It's been stood a while with the battery disconnected and on charge. It's a new battery showing decent voltage. When I went to start it absolutely nothing happens. The starter does not turn at all. I've tapped the starter solenoid to see if it's sticky and no change I adjusted the clutch to 1.90v in basic settings as it was showing 0.72v Then I went on to do a gear actuator adaptation and it failed showing RTFM and fault 12... Are there any good guides on what I need to check and adjust for fault 12? I'm extremely new to all this and to using VCDS so please go easy! Thanks in advance 🙂 Quote Link to comment Share on other sites More sharing options...
mk2 Posted March 3, 2023 Report Share Posted March 3, 2023 @RAB is the expert... Quote Link to comment Share on other sites More sharing options...
crashtestdummy Posted March 4, 2023 Author Report Share Posted March 4, 2023 14 hours ago, mk2 said: @RAB is the expert... Thanks, I hope he can help! Quote Link to comment Share on other sites More sharing options...
crashtestdummy Posted March 14, 2023 Author Report Share Posted March 14, 2023 I guess this forum is dead these days. I've solved the issue now via the 3L page on Facebook Quote Link to comment Share on other sites More sharing options...
mk2 Posted March 15, 2023 Report Share Posted March 15, 2023 Loads of people on here, but no-one has a 3L in the uk, so not much knowledge. Look after it, as they're super rare over here! Maybe only 5 cars still going? Quote Link to comment Share on other sites More sharing options...
RAB Posted April 17, 2023 Report Share Posted April 17, 2023 RTFM 12 is usually caused by not adjusting the actuator as advised, during the basic setting. Perhaps that's what you found? RAB Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 17, 2023 Report Share Posted April 17, 2023 Yay! @RAB is back. Welcome home Quote Link to comment Share on other sites More sharing options...
Rich Posted April 17, 2023 Report Share Posted April 17, 2023 Back but too late! Quote Link to comment Share on other sites More sharing options...
RAB Posted June 18, 2023 Report Share Posted June 18, 2023 On better forums you get an email when your attention is required! RAB Quote Link to comment Share on other sites More sharing options...
decvalts Posted June 19, 2023 Report Share Posted June 19, 2023 One day I'll get a 3L and then we can suffer together on the forum 😁. (The 3L facebook page is pretty good to be fair) Quote Link to comment Share on other sites More sharing options...
