6 hours ago, mk2 said:
Where did you find it?
Compilation: Autodata and ElsaWin
2 hours ago, Sarahs Lupo said:
The pdf doesn't work.
Sorry, I do not know what does not work for you, but I made some screen shoots
Also check this for EGR error
Check wiring between test box and connector for open circuit using current flow diagram.
Contact 1+ socket 1 + 2
Contact 2+ socket 61
Wire resistance: max. 1.5 ω
Additionally check wires for short to one another, to vehicle earth and to battery positive. Specification: ∞ω
For this check (and the following) you must have access to the ECU socket. Remove the cover marked with the red arrow and then pull the plug by pulling in the direction of the arrows
Screenshot_20191013_162228_com.android.gallery3d.jpg.261b068f6101b9c04f15a89644a69782.jpg.ec2fe6c93dfe0244da94de2b73cfce12.jpg
EGR can be visually checked if it works: when you accelerate strongly you can see how the rod moves
With the blue arrow I marked the flap on the intake that is not related to the error on the EGR, but works with it and may be to blame for the lack of power.
Remove the inlet pipe and observe the flap:
  • engine stopped: the flap must be wide open
  • engine start/idle: the flap must be closed and after about 10 minutes idling without touching the acceleration will open ( to close again you have to drive at higher speeds )
  • engine accelerated at over 3000 rpm: the flap must be wide open
This is the correct behavior of this flap
The egr control solenoid is below the left blue thing in your pic. The pipe from it goes to the egr valve to the left of the dip stick.
Where are you in the uk? One of us here maybe nearby... otherwise, might be a quick fix for an autoelectrician.
You need to check the feed from K46 in that diagram. The power goes through the k46 switch contact which powers everything.
I'm in trowbridge so not far from the M4
Just some more background.
The parts numbered in my pic have been replaced with new ones. Nice and shiney so that gives me some confidence in the hardware.
Edited by Sarahs Lupo
Ok sorry for the idocy but how can I test this???
I use my red probe on the contact 1 of the egr connection, and then stick my black probe into the ECU area on socket 1+2?
Am I being dumb here ??? How can I do 1 + 2 at the same time in the ECU ha
I must be missing a few brain cells
Sorry, it is the expression of manual.  Not at the same time but one at a time
you have to be careful, it's irreversible :D
Ok so I will try contact 1 and socket 1
Then I try contact 1 and socket 2..
That I can do.
I will test tomorrow then.
Lastly, do I need ignition on or off for this
Definitely not ignition on, before removing the plug from the ECU remove the minus terminal from the battery .
Basically you measure the continuity of some wires not the functioning of a component
Edited by lupo 1.7sdi
Ok so ECU out, negative off.
Stick my red probe into the 1 socket and then the black into the ecu part 1 and 2 and I'm getting 0.04 ohms. Pic attached to make sure I'm doing this right.
18 hours ago, Sarahs Lupo said:
Ok I am trying to stick my multi meter into the ECU but the prongs are too thick.
Any suggestions??
Thanks
This is what is stopping me checking the rest of the connections on the ECU - my probes are too thick...  i need some needle like ones
Tape a needle to them
There's not enough voltage in the car to kill you.
Stop being a pussy.
Also I generally probe the back of the pins.
Stop being a pussy.
Thanks for that I'll bear that in mind but just incase you didn't understand me,
1) You didn't answer my question. Which tape?
2) I have never touched electrics before so unsure of the dangers of touching the battery for example
3) I'm testing the ECU socket so not idea about the "back of the pins"??????
Appreciate the help. I will get to the bottom of this
As long as there is a physical connection it doesn't matter.
I'd say zip ties but it wouldn't hold.
Thanks. I will see what happens tomorrow.
I'll tape some needles on my probe. But I have very small cable ties too.
just an idea, since i have multiple codes that suggest open or short to ground..
is there any common earth points i can check to see if they are the problem.
concentrating on each fault code and chasing the wire doesn't seem a good idea if they all are saying short to ground????
i took the battery off last night, and the battery tray. all looks good under it, so damp or rust. checkled the large earth cable that goes on the battery and at the metal work all looks good. so it cant be that.
just an idea is there any other common earth/ground points?
That wiring diagram shows you the places you could check... you can see how if a relay were faulty, large swathes of the loom are without power.
I'm having a hard time decifiering that pdf.
I was going to check a common earth point between the error codes I have got.
Can anyone read that diagram?
Thanks as always
