Almonds 0 Posted July 20, 2018 Report Share Posted July 20, 2018 Hi guys, Been on here for a while. Just wanted someone to explain how to do a egr delete on 1.7sdi. In simple steps. I brought this already on image attached. Quote Link to post Share on other sites
Sausage 147 Posted July 20, 2018 Report Share Posted July 20, 2018 (edited) Should be self explanatory given the shape there, but some stick it on the end of the egr pipe or in both places if they are same size / shape. (they do actually look different in that pic but might just be the angle). The blanking plate is sandwiched between the egr and the inlet manifold, and / or the pipe and the exhaust. Doesnt matter too much as long as it stops exhaust gas getting back into engine. Edited July 20, 2018 by Sausage Quote Link to post Share on other sites
Almonds 0 Posted July 20, 2018 Author Report Share Posted July 20, 2018 Bottom pic looks like the metal gasket I brought (£4) is for the bottom exhaust section. How about blocking the air tubes from the egr valve top section? Thanks dude. Quote Link to post Share on other sites
mk2 328 Posted July 20, 2018 Report Share Posted July 20, 2018 Nah... don't do it. Wont get you any more power. The only way is to gas flow the ram tubes. I've posted pics somewhere on here how to do it. Otherwise, just disconnect the vacuum pipe to the egr control solenoid (and block it). Quote Link to post Share on other sites
JamieV 0 Posted December 6, 2020 Report Share Posted December 6, 2020 On 7/20/2018 at 11:29 PM, mk2 said: Nah... don't do it. Wont get you any more power. The only way is to gas flow the ram tubes. I've posted pics somewhere on here how to do it. Otherwise, just disconnect the vacuum pipe to the egr control solenoid (and block it). Hi I've just bought a lupo 1.7 sdi do you know what the best thing to do to make it faster and perform better? Quote Link to post Share on other sites
C3peteo 8 Posted December 6, 2020 Report Share Posted December 6, 2020 Clean all the soot out of the inlet. Mine had a huge amount of soot which I cleaned out. Quote Link to post Share on other sites
ObjectiveAway 3 Posted December 11, 2020 Report Share Posted December 11, 2020 On 12/6/2020 at 3:16 PM, JamieV said: Hi I've just bought a lupo 1.7 sdi do you know what the best thing to do to make it faster and perform better? Remapping. EGR valve don't affect fuel consumtion and output power, same like remapping, EGR just affects emissions qualitty. Quote Link to post Share on other sites
mk2 328 Posted December 11, 2020 Report Share Posted December 11, 2020 Here's the link: https://forums.clublupo.co.uk/index.php?/topic/106416-sdi-egr-delete-and-gas-flowing-for-more-power/ But i also experimented with different injectors and the quantity adjuster inside the injection pump. The conclusion was that without egr, an active choke flap and plugged gas feeds, the only way to get a lot more power was by changing injectors- throwing in way more fuel than normal. Lots of black smoke, but wow, the increase in torque...! However, would not pass MOT with them in. Someone else on here mentioned "rolling coal" after I did the experiments If you're severely down on power, worth checking injector timing and fuel filter. A stock SDI is reasonably quick, never slow. Or clogged injectors... VCDS will give you all the numbers and injector balance. Quote Link to post Share on other sites
