myles983 Posted July 14, 2016 Author Report Share Posted July 14, 2016 14 hours ago, mattarosa said: Failed on what? A substantial amount: Exhaust emissions at idle excessive Exhaust emissions at 2nd fast idle excessive Lambda readings out of specified limit Headlight aim too low nearside Suspension arm rubber bush perished resulting in excessive movement Brakes imbalanced across rear axle Rear brake recording little or no effort offside Rear parking brake recording little or no effort offside The lambda problem has been fixed: a new lambda has been fitted. The brake issue was caused by the brake cylinder bursting and leaking brake fluid onto the drum, effectively lubricating the shoes and resulting in a lack of friction. This has been fixed now. The headlamp has been adjusted, and the rubber bush has been replaced, and those are now fine. All Im waiting to hear about now is that the CAT has been replaced and it passed preliminary emissions testing. Once thats done, she will go in for her retest the garage I have taken it to have been really helpful throughout this, and all in its cost just shy of £500, MOT and retest included. Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 14, 2016 Author Report Share Posted July 14, 2016 Update: The cat has been fitted, but its still not low enough on the emissions. They're fitting the secondary cat, although i dont know where that is...? Quote Link to comment Share on other sites More sharing options...
Lewiss_Lupo Posted July 14, 2016 Report Share Posted July 14, 2016 Mine failed last week on a broken rear spring! I didnt even notice it! On 13 July 2016 at 4:34 PM, myles983 said: Potentially. She just failed the MOT so it might be a while, but they need refurbing too, so i might have it done all in one go. Was thinking Anthracite Grey, or something similar. Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 15, 2016 Author Report Share Posted July 15, 2016 19 hours ago, Lewiss_Lupo said: Mine failed last week on a broken rear spring! I didnt even notice it! its annoying when you don't notice things like that. :/ Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 16, 2016 Author Report Share Posted July 16, 2016 1 Quote Link to comment Share on other sites More sharing options...
mattarosa Posted July 16, 2016 Report Share Posted July 16, 2016 Woo 1 Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 17, 2016 Author Report Share Posted July 17, 2016 I'm getting a weird clicking noise when I accelerate now .... Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 17, 2016 Author Report Share Posted July 17, 2016 On the plus side, she's nice and clean now: Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 20, 2016 Author Report Share Posted July 20, 2016 Tonight I very nearly died. I lost power turning into an estate, with a bus coming in my direction. I lost the power steering, which oddly then restored and allowed me to narrowly miss hitting a wall as I'd swung out wide. Pulling up outside my Nans, Loopy came to a chugging stop, before not wanting to turn over again. Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 22, 2016 Author Report Share Posted July 22, 2016 So Loopy is dead. Suspected head gasket failure. Been quoted 763 pounds for replacement of the gasket, but I don't think it is viable. Any suggestions ? Quote Link to comment Share on other sites More sharing options...
Silver! Posted July 22, 2016 Report Share Posted July 22, 2016 Engine replacement? Do it yourself? Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 22, 2016 Author Report Share Posted July 22, 2016 6 minutes ago, Silver! said: Engine replacement? Do it yourself? How difficult is an engine replacement ? I have some technical experience, but not a lot. Quote Link to comment Share on other sites More sharing options...
Silver! Posted July 22, 2016 Report Share Posted July 22, 2016 Problem is with an engine replacement is that you could end up the same in a couple of months. Done other cars, but never done a Lupo, but how hard can it be? label and mark everything you take off and return it to the same place. If you have some skills is it not worth trying to change the head gasket yourself? Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 22, 2016 Author Report Share Posted July 22, 2016 10 minutes ago, Silver! said: Problem is with an engine replacement is that you could end up the same in a couple of months. Done other cars, but never done a Lupo, but how hard can it be? label and mark everything you take off and return it to the same place. If you have some skills is it not worth trying to change the head gasket yourself? Thats what has been one of the main points when thinking about pros and cons to having it replaced. And I could try, but I dont know how to set the timing on the belts or anything after replacing it, as thats what I've heard will need to be done. Quote Link to comment Share on other sites More sharing options...
Silver! Posted July 22, 2016 Report Share Posted July 22, 2016 You could always do the gasket change and then get a mobile mech. in to do the timing belts. If you get hold of a MK4 VW Polo Haynes manual it should explain it and give you an idea if you can do it. Quote Link to comment Share on other sites More sharing options...
mattarosa Posted July 23, 2016 Report Share Posted July 23, 2016 mark the timing gears to the block and the belt with some engineers blue or tipex and you'll be laughing 2 Quote Link to comment Share on other sites More sharing options...
cj1 Posted July 23, 2016 Report Share Posted July 23, 2016 Easy enough for anyone really, especially if it's same engine going back in. Have it done in a weekend! Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 25, 2016 Author Report Share Posted July 25, 2016 Thanks for all the support guys. I have enlisted the help of a friend who will do it and talk me through it as he goes! Quote Link to comment Share on other sites More sharing options...
myles983 Posted July 28, 2016 Author Report Share Posted July 28, 2016 Come across a couple of weird things having stripped everything down: Silicone in the oil Bits of silicone in the air box Oil in the inlet manifold, air intake and the throttle body Things aren't looking too good... Quote Link to comment Share on other sites More sharing options...
myles983 Posted August 1, 2016 Author Report Share Posted August 1, 2016 Quote Link to comment Share on other sites More sharing options...
jparkes43 Posted August 1, 2016 Report Share Posted August 1, 2016 how old was the oil!! James Quote Link to comment Share on other sites More sharing options...
myles983 Posted August 1, 2016 Author Report Share Posted August 1, 2016 (edited) I've been told its a build up of carbon and my exhaust valves need lapping.... Edited August 1, 2016 by myles983 Phone wanted to re-post the video. Quote Link to comment Share on other sites More sharing options...
myles983 Posted August 8, 2016 Author Report Share Posted August 8, 2016 So, after a full vacuum test, Loopy needs 8 new exhaust valves. Once this is done, hopefully the head can be skimmed, refitted to Loopy, and then she will be running again! Quote Link to comment Share on other sites More sharing options...
myles983 Posted August 23, 2016 Author Report Share Posted August 23, 2016 1 Quote Link to comment Share on other sites More sharing options...
mattarosa Posted August 23, 2016 Report Share Posted August 23, 2016 Put a newspaper down then your mother won't moan!! 2 Quote Link to comment Share on other sites More sharing options...
