mk2 Posted August 7, 2022 Report Share Posted August 7, 2022 Too much torque... the 6th gear would be too far away from the main casting. Even with a magnesium cap (like with gti), it'd fail. Even the gti 6th gear fails. Thats why everyone changes the ratios. Easier. Cheaper. Simpler. Quote Link to comment Share on other sites More sharing options...
tchouki85 Posted August 7, 2022 Report Share Posted August 7, 2022 so what ratio would be ideal Quote Link to comment Share on other sites More sharing options...
ObjectiveAway Posted August 23, 2022 Report Share Posted August 23, 2022 On 8/7/2022 at 10:45 PM, mk2 said: Too much torque... the 6th gear would be too far away from the main casting. Even with a magnesium cap (like with gti), it'd fail. Even the gti 6th gear fails. Thats why everyone changes the ratios. Easier. Cheaper. Simpler. Would it even be possible to really add 6th gear to 085gearbox? I think it would take at least custom made shafts and cap, 6th gear sprockets, and transformed selector shaft, and in the end it would coast more than Lupo itself. On 8/8/2022 at 12:08 AM, tchouki85 said: so what ratio would be ideal It depends on what RPM’s you have on highway and what you want to get. Also it is important to know your gearbox code, because there are several differential ratios on these gearboxes, which you cant change as easy as 5th speed gears. Quote Link to comment Share on other sites More sharing options...
Lore333 Posted January 22 Report Share Posted January 22 On 8/26/2014 at 9:47 PM, Midlands95 said: Thanks, I am getting mine done in around 3 weeks time - getting the current 0.756 changed for 0.658. Bad luck with the turbo, hope it doesn't cost you too much! hi do you still have the 0.75 gears (36/50 i think)? in which gearbox were they fitted? Quote Link to comment Share on other sites More sharing options...
yeha Posted February 12 Report Share Posted February 12 Do you need them for the 02J TDi box? I think I've still got mine somewhere. Quote Link to comment Share on other sites More sharing options...
