Mattz341 Posted February 13, 2014 Report Share Posted February 13, 2014 Right guys. I've made up a spreadsheet within Excel that'll allow you to see the speed output in MPH at a given rev amount in any gear.I'd upload it to this but I honestly haven't a clue how!All I need is the ratios for the GTi 5 speed Box then it'll have both of the GTi boxes on it. I'm also inputting the lower down gear boxes in, so the 1.0,1.4, 1.4Sport, 1.4 tdi, 1.7SDi.If anyone has a copy of the gear and final drive ratios then that would be super if you could send them over! Many thanks!Matt Quote Link to comment Share on other sites More sharing options...
Mattz341 Posted February 13, 2014 Author Report Share Posted February 13, 2014 Also, does anyone know if its possible to get different diff's for the 6 speed? I'm looking for one with a lower ratio. Quote Link to comment Share on other sites More sharing options...
LupinGTI Posted May 31, 2016 Report Share Posted May 31, 2016 Hi Matt, did you ever find out the ratios for the 5spd GTI box? I can't find them anywhere. Thanks Quote Link to comment Share on other sites More sharing options...
vpolo Posted May 31, 2016 Report Share Posted May 31, 2016 if any one knows the codes ? I've got all the gear ratios on a pdf Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted May 31, 2016 Report Share Posted May 31, 2016 Quote Link to comment Share on other sites More sharing options...
cj1 Posted May 31, 2016 Report Share Posted May 31, 2016 47 minutes ago, vpolo said: if any one knows the codes ? I've got all the gear ratios on a pdf Any chance you could send this over? Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted May 31, 2016 Report Share Posted May 31, 2016 Right, think I've worked this out, please correct me if I'm wrong (more than likely!) 5 Speed is as follows: Gearbox code is FHE (June 2000 - April 2002) 1st - 38 teeth on driven gear, 11 on drive gear, ratio 3.45 2nd - 44 teeth on driven gear, 21 on drive gear, ratio 2.09 3rd - 43 teeth on driven gear, 30 on drive gear, ratio 1.43 4th - 41 teeth on driven gear, 38 on drive gear, ratio 1.07 5th - 41 teeth on driven gear, 46 on drive gear, ratio 0.89 Final drive is 65/18, ratio 3.61 6 Speed is as follows: Gearbox codes are: FUT (April 2001 - May 2003), GVX (August 2003 - June 2004) , GPF (January 2001 - March 2003), GSN (March 2003 - May 2003) Gearbox code GEZ has a magnesium housing, only used on GTIS from May 2002 - May 2003 1st - 38 teeth on driven gear, 12 on drive gear, ratio 3.16 2nd - 43 teeth on driven gear, 22 on drive gear, ratio 1.95 3rd - 43 teeth on driven gear, 31 on drive gear, ratio 1.38 4th - 42 teeth on driven gear, 37 on drive gear, ratio 1.13 5th - 42 teeth on driven gear, 45 on drive gear, ratio 0.933 6th - 38 teeth on driven gear, 49 on drive gear, ratio 0.776 Final drive is 67/16, ratio is 4.188 Quote Link to comment Share on other sites More sharing options...
Blue Loop Posted May 31, 2016 Report Share Posted May 31, 2016 57 minutes ago, lupogtiboy said: 6 Speed is as follows: Gearbox codes are: FUT (April 2001 - May 2003), GVX (August 2003 - June 2004) , GPF (January 2001 - March 2003), GSN (March 2003 - May 2003) Gearbox code GEZ has a magnesium housing, only used on GTIS from May 2002 - May 2003 Does that mean FUT gearboxes were only fitted to cars up to May 2002? Also, the GEZ with magnesium housing... Are they supposed to be good, bad or worse? My car is from 10.2002 Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted June 1, 2016 Report Share Posted June 1, 2016 No that means the FUT code (which is on my 03 GTI) was fitted upto May 2003 No idea about the GEZ gearbox, I've never seen one with that code fitted, may be a German market only gearbox? Quote Link to comment Share on other sites More sharing options...
Blue Loop Posted June 1, 2016 Report Share Posted June 1, 2016 (edited) Right, maybe it's something for one special market... My car was originally sold in Germany, I'll let you know what kind of gearbox it has when I find out Edited June 1, 2016 by Blue Loop Quote Link to comment Share on other sites More sharing options...
gacsger Posted February 27, 2024 Report Share Posted February 27, 2024 Can anyone post the excel file of gearbox ratios? Thanks!! Quote Link to comment Share on other sites More sharing options...
