Trx 33 Posted January 30, 2013 Report Share Posted January 30, 2013 I'm going to be running a 1500w rms - 3000w peak amp, I've already upgraded the battery and done 'the big 3' but I'm lacking power on my current system which is only about 2000w peak. Which alternators would fit a 1.4 8v arosa, I believe it has an akk engine but I can't check right now as I'm at work. I've heard the 180A passat alternator fits, but id rather someone confirmed it before I go blasting my money Quote Link to comment Share on other sites More sharing options...
mad-modz Posted May 21, 2013 Report Share Posted May 21, 2013 (edited) Apparently the 180a fits.. I was running 1600W RMS @ 1 ohm of bass, and around 400w rms audio in my walled lupo... On a stock alternator, just with a second leisure battery in the boot to take the strain off the original electrical system.. I never got headlight fade or any other issues, ran like this for 12 months before selling the car and audioOne thing to remember with a larger alternator, it will effect the cars performance driving wise as its a big load on the engine. Edited May 21, 2013 by mad-modz Quote Link to comment Share on other sites More sharing options...
davidelliott294 Posted May 21, 2013 Report Share Posted May 21, 2013 (edited) passat alternator fits i'm sure, like you said but i'm not 100%Edit: speak to little rich, he had an issue with his. his speakers kept cutting out when car was idling because they alternator wasn't providing enough power. http://forums.clublupo.co.uk/index.php?/user/5405-little-rich/ Edited May 21, 2013 by davidelliott294 Quote Link to comment Share on other sites More sharing options...
Trx 33 Posted May 21, 2013 Author Report Share Posted May 21, 2013 http://forums.clublupo.co.uk/index.php?/topic/94682-180a-alternator-fitted/Definitely fits - found one going cheap on eBay and couldn't resist. Quote Link to comment Share on other sites More sharing options...
ObjectiveAway Posted May 2, 2022 Report Share Posted May 2, 2022 Do anyone know if 44kw 1.4 petrol engine will be able to pull 120A alternator or not? I have 80A alternator without damper pulley, maintaince coasts more than this upgrade. 120A alternators have damper pulleys, which will remove some load from engine. Quote Link to comment Share on other sites More sharing options...
