craig_allman Posted January 29, 2013 Report Share Posted January 29, 2013 Hi, anyone know why there is always a constant live feed to my head unit? ive tried the obvious swapping the red and the yellow but the is still constant power. anyone know anything else it could be or i could do/try? thanks Quote Link to comment Share on other sites More sharing options...
GTIChris Posted January 29, 2013 Report Share Posted January 29, 2013 Has it got a clock that needs a constant feed ? (just guessing here) Quote Link to comment Share on other sites More sharing options...
Pete Posted January 29, 2013 Report Share Posted January 29, 2013 You've obviously wired it up wrong, but you know this already. I take it you mean the h/u is always turned on even with the key out? Quote Link to comment Share on other sites More sharing options...
craig_allman Posted January 29, 2013 Author Report Share Posted January 29, 2013 yeah its always on even with the key out Quote Link to comment Share on other sites More sharing options...
craig_allman Posted January 29, 2013 Author Report Share Posted January 29, 2013 Has it got a clock that needs a constant feed ? (just guessing here)no it doesn't, the whole stereo is just always on and because it doesn't have an off button on the head unit i have no way of turning it off Quote Link to comment Share on other sites More sharing options...
jpsh120 Posted January 29, 2013 Report Share Posted January 29, 2013 Get a multimeter and check the feed from the main loom, one of them (either red or yellow) should be a switched live. If for some strange reason there isn't one it is very easy to take one off the ignition barrel. Quote Link to comment Share on other sites More sharing options...
aziz360 Posted January 29, 2013 Report Share Posted January 29, 2013 I'm probably completely wrong but my golf used to do it sometimes and it was because when I pulled the key out the two connect in the barrel kept getting stuck and didn't come together Sorry meant to say 2 contacts in the barrel Quote Link to comment Share on other sites More sharing options...
Pete Posted January 29, 2013 Report Share Posted January 29, 2013 Shouldn't it always have a constant live to keep its memory of settings and stations tho? Sounds like you've wired your switched live from the h/u into the permanent live on the cars loom. Quote Link to comment Share on other sites More sharing options...
craig_allman Posted January 29, 2013 Author Report Share Posted January 29, 2013 Shouldn't it always have a constant live to keep its memory of settings and stations tho? Sounds like you've wired your switched live from the h/u into the permanent live on the cars loom.any idea what colour that is? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 29, 2013 Report Share Posted January 29, 2013 Usually red and yellow, most h/u come with a diagram or the loom itself labelled. Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 30, 2013 Report Share Posted January 30, 2013 Did you fit a wiring harness? Quote Link to comment Share on other sites More sharing options...
Jared-One Posted January 30, 2013 Report Share Posted January 30, 2013 Failing everything else you could always use a fuse tap to create a switch live... Quote Link to comment Share on other sites More sharing options...
craig_allman Posted January 30, 2013 Author Report Share Posted January 30, 2013 Did you fit a wiring harness?yeah i did fit a wiring harness Quote Link to comment Share on other sites More sharing options...
jpsh120 Posted January 30, 2013 Report Share Posted January 30, 2013 It does sound like the red/yellow permanent/switched lives are not connected correctly and it should be an easy fix. Quote Link to comment Share on other sites More sharing options...
craig_allman Posted January 30, 2013 Author Report Share Posted January 30, 2013 ive tested the red and yellow and they are both permanent lives any idea what to do next to solve this? thanks. Quote Link to comment Share on other sites More sharing options...
Pete Posted January 30, 2013 Report Share Posted January 30, 2013 They can't both be permanent lives, were you testing them with the key in the ignition? Quote Link to comment Share on other sites More sharing options...
craig_allman Posted January 30, 2013 Author Report Share Posted January 30, 2013 no i tested them without the key in the ignition. anyone know if it would work if i connected it to somewhere like the rear window heater switch? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 30, 2013 Report Share Posted January 30, 2013 Can you get a pic of your connections, really looking for that big block connection that put the car loom to the h/u loom. Quote Link to comment Share on other sites More sharing options...
craig_allman Posted January 30, 2013 Author Report Share Posted January 30, 2013 the guy that had it before bodged it all to **** but i think ive worked out whats wrong now just need to know if it will work if i connect it too the rear window heater? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 30, 2013 Report Share Posted January 30, 2013 Only if you have that turned on the whole time, you're better off biting the bullet and figuring it out and doing it properly. Quote Link to comment Share on other sites More sharing options...
craig_allman Posted January 30, 2013 Author Report Share Posted January 30, 2013 so if i connected it to the heater switch would i not be able to use the heater no more? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 30, 2013 Report Share Posted January 30, 2013 You'd need to splice the wiring so that you don't break the circuit fully as the switch is obviously needing a live feed in order for it to work. I urge you not to do this tho. Quote Link to comment Share on other sites More sharing options...
craig_allman Posted January 30, 2013 Author Report Share Posted January 30, 2013 okay, any reason why you dont recommend doing this? Quote Link to comment Share on other sites More sharing options...
Pete Posted January 30, 2013 Report Share Posted January 30, 2013 You're just adding to the problem, instead of solving it, plus when it comes to selling it you don't wanna be the guy that says 'yeah, don't turn off the rear demister, the radio will turn off.' It's a billion times better to get to the root cause of a problem and sort it instead of carry on cutting corners and bodging it, itl just lead to more issues. Quote Link to comment Share on other sites More sharing options...
Jared-One Posted January 30, 2013 Report Share Posted January 30, 2013 https://www.google.co.uk/search?hl=en&safe=off&client=safari&tbo=d&biw=320&bih=416&tbm=isch&sa=1&q=fuse+tap&oq=fuse+tap&gs_l=mobile-gws-serp.3..0j0i5l3j0i24.4524.8088.0.9607.8.8.0.0.0.0.159.1029.0j8.8.0...0.0...1ac.1.gQxl5UZpUMw#i=2The easiest fix Quote Link to comment Share on other sites More sharing options...
