hectashouse Posted November 12, 2011 Report Share Posted November 12, 2011 hi everyone,i got an arosa mk 1 1 litre petrol and its got 73,000 miles on the clock but its using alot of petrol which makes me think somethings wrong ?out of approx £10 i get roughly 57 miles. is there something wrong or do these cars usually do that ? i haven't got a lead foot by the way ( i got a tracker due to the insurance being too high lol )and the pipe which goes into the air box is spitting out white gunk and a little bit of oil anyone know how to fix it ? thanks,hecta Quote Link to comment Share on other sites More sharing options...
Rich Posted November 12, 2011 Report Share Posted November 12, 2011 Give it a service, clean out the breather box on the back of the block and then see what it's like.cars always use more fuel in cold weather. Quote Link to comment Share on other sites More sharing options...
lupo_jack Posted November 13, 2011 Report Share Posted November 13, 2011 Plus if you do motorway miles you will use more fuel aswell since you have a 1L Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted November 13, 2011 Report Share Posted November 13, 2011 i used to get roughly 100miles to 10litres Quote Link to comment Share on other sites More sharing options...
Rich Posted November 13, 2011 Report Share Posted November 13, 2011 Ten litres isn't a tenner anymore. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted November 13, 2011 Report Share Posted November 13, 2011 Does your temperature guage work properly?As Rich said, give it a good service (inc plugs) and go from there Quote Link to comment Share on other sites More sharing options...
hectashouse Posted November 20, 2011 Author Report Share Posted November 20, 2011 yeah i think so lolyeah i'll give it a service once i fix my pedal box lol and let everyone know thanks everyone Quote Link to comment Share on other sites More sharing options...
old skool Posted November 25, 2011 Report Share Posted November 25, 2011 my lupo drinks petrol that bad aswell Quote Link to comment Share on other sites More sharing options...
JoeA Posted November 26, 2011 Report Share Posted November 26, 2011 I get between 45 and 60 miles for £10 Quote Link to comment Share on other sites More sharing options...
fatty Posted November 29, 2011 Report Share Posted November 29, 2011 Any problems with it not starting when warm? My temp sensor was faulty. It told the ECU that the engine was cold when it wasn't and it meant I used a lot of fuel and it wouldn't start when it was warm. Quote Link to comment Share on other sites More sharing options...
beska133 Posted December 4, 2011 Report Share Posted December 4, 2011 at the moment i've been getting under 300 litres a tank in my 1 litre, but thats using Shell V-Power, and i can't understand why? i took the plugs out a few hundred miles ago to just have a look and they were pretty black, even though it was serviced by myself when i bought it on 30k miles (Now on 33K) Also, temp sensor? you mean the coolant expansion tank sensor in the bottle? Quote Link to comment Share on other sites More sharing options...
JamesTdi Posted December 4, 2011 Report Share Posted December 4, 2011 Hit it your face Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 4, 2011 Report Share Posted December 4, 2011 at the moment i've been getting under 300 litres a tank in my 1 litre, but thats using Shell V-Power, and i can't understand why? i took the plugs out a few hundred miles ago to just have a look and they were pretty black, even though it was serviced by myself when i bought it on 30k miles (Now on 33K)Also, temp sensor? you mean the coolant expansion tank sensor in the bottle?If they are black after 3k its over fuelling. The temp sensor is normally where the top rad hose leaves the engine block Quote Link to comment Share on other sites More sharing options...
fatty Posted December 4, 2011 Report Share Posted December 4, 2011 Yup that was the one I was talking about Defcon5. Quote Link to comment Share on other sites More sharing options...
beska133 Posted December 4, 2011 Report Share Posted December 4, 2011 Well my temp reading is fine, and when it heats up the idle drops as normal,Running rich? How do I go about sorting that? Quote Link to comment Share on other sites More sharing options...
beska133 Posted December 5, 2011 Report Share Posted December 5, 2011 but also, when its at running temp the exhaust is clear, where you;d think it would be black with so much of a mpg drop? how to i check weather the temp sensor is working? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 5, 2011 Report Share Posted December 5, 2011 how to i check weather the temp sensor is working?You dont, you change the sensor. Make sure its a genuine oneAssuming it is that, it will solve your over fuelling instantly. Basically the temp sensor is knackered, and its telling the ECU its -50, so it pours in fuel like its going out of fashion Quote Link to comment Share on other sites More sharing options...
beska133 Posted December 5, 2011 Report Share Posted December 5, 2011 haha brilliant, hwo easy is it to change?but, i went to VW today, and they seem to think my throttle body and various piping is crapped up to hell because of my plugs being carbon'd up, so im going to wack a bottle of carb cleaner through it tomorrow and see where that takes me, also another think they think it could be is that me using v power, 99 octane may be too rich for the engine to cope, there for confusing the ecu and over fuelingalso i need to check weather my oil separator isnt clogged upim hoping the carb cleaner and going back to 97 octane excellium will sort it! i dont want a £500 big for new throttle body or £160 for new oil separator! Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted December 5, 2011 Report Share Posted December 5, 2011 (edited) also another think they think it could be is that me using v power, 99 octane may be too rich for the engine to cope, there for confusing the ecu and over fuelingVW told you that? They actually said that to you? Edited December 5, 2011 by Defcon5 Quote Link to comment Share on other sites More sharing options...
fatty Posted December 6, 2011 Report Share Posted December 6, 2011 99 octave burns cleaner, if anything it should help. When was the last time you serviced it? You won't need to replace the throttle body with a new one. You can clean it out with good old carb cleaner. Clean the egr valve if your car has one at the same time. (This advice is a bit rich coming from me as I still need to do it Haha, been saying I'm going to for about 3 months Haha.) Quote Link to comment Share on other sites More sharing options...
beska133 Posted December 7, 2011 Report Share Posted December 7, 2011 i serviced it myself at 30500k when i bought it, new plugs, filters, coolant, break fluid, the lot, i stripped the throttle body down and cleaned it, and in intake manifold, it was nice and kaked up with crap! the pipes and PCV valve were oiled up to hell so im hoping thats problem half solved, i also took it for a good belting after soaking the throttle bosy and manifold in carb cleaner and it was like driving a new car! had abit more power!apparently its a common things for these to kack up, the only other thing i was told it could be is the oil separator is gunged up and needs replacing but we will bewith the shell v power 99 octane thing, this is what i thought, but in my experience, v power i always use more with it than any other premium fuel, just with it burning slightly more with it being higher octaneGet it serviced! specially before the weather turns properly awful! otherwise it will be un serviced until spring unless you want to freeze! haha Quote Link to comment Share on other sites More sharing options...
beska133 Posted December 7, 2011 Report Share Posted December 7, 2011 Also, EGR Valve? anyone got a pic? Quote Link to comment Share on other sites More sharing options...
