jamiea7x Posted September 1, 2011 Report Share Posted September 1, 2011 right ok my passenger door speaker is completely foobard, form ring is torn 80% of the way round the cone, after a hunt ive managed to my old pioneer TS-A171C, but i dont really want the hassle of fitting the tweets from them, after looking at the OE speakers theres some sort of crossover loom type thing in the spacer and im not sure how to wire the new speakers up as theres four pins on the speaker and only two wires into the plug for the Oe speaker?any help guys? Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted September 2, 2011 Author Report Share Posted September 2, 2011 anyone? Quote Link to comment Share on other sites More sharing options...
RobG Posted September 4, 2011 Report Share Posted September 4, 2011 From what i saw doing the passat's speakers, the feed for the tweeter was the same as the feed for the woofer, but the tweeter has a resister soldered across the terminals, presumably to cut out some of the frequencies? Not sure if the lupo is the same though. The passat is slightly easier, given that both speakers are contained within the door itself, not split between the door and dash. Quote Link to comment Share on other sites More sharing options...
HalfOfZero Posted September 4, 2011 Report Share Posted September 4, 2011 I'll be upgrading my door speakers soon, as Im currently building a new parcel shelf with speakers. so I'll let you know how I get on.. Quote Link to comment Share on other sites More sharing options...
treblet Posted September 4, 2011 Report Share Posted September 4, 2011 From what i saw doing the passat's speakers, the feed for the tweeter was the same as the feed for the woofer, but the tweeter has a resister soldered across the terminals, presumably to cut out some of the frequencies? Not sure if the lupo is the same though. The passat is slightly easier, given that both speakers are contained within the door itself, not split between the door and dash.Yes the Lupo tweeters are the same. Quote Link to comment Share on other sites More sharing options...
Thooooom Posted September 15, 2011 Report Share Posted September 15, 2011 right ok my passenger door speaker is completely foobard, form ring is torn 80% of the way round the cone, after a hunt ive managed to my old pioneer TS-A171C, but i dont really want the hassle of fitting the tweets from them,after looking at the OE speakers theres some sort of crossover loom type thing in the spacer and im not sure how to wire the new speakers up as theres four pins on the speaker and only two wires into the plug for the Oe speaker?any help guys? it could be that the crossover is mounted on the speaker, and therefore you put the sound feed into the mid speaker, and then run the tweeters out the back of that, so maybe just try both and see how you get on ? Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted September 15, 2011 Author Report Share Posted September 15, 2011 tbh it wasnt worth the hassle i just fitted the tweeters that came with the speakers into the oe grills, the crossover is mounted in the oe speker spacer an wouldve reqyuired far to much feckin about about with, got them all in and fitted sounds much better. Quote Link to comment Share on other sites More sharing options...
puggled Posted October 10, 2011 Report Share Posted October 10, 2011 I know it is too late for you, but maybe if someone used the search facility it'll help them.Audio leads PC2-807 should help?http://www.ebay.co.uk/itm/PC2-807-Volkswagen-Golf-MK4-Polo-Speaker-Adaptor-Lead-/160419142673It leaves you two wires to wire the woofer into and pass through to the tweeter. Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted October 13, 2011 Author Report Share Posted October 13, 2011 a set of those came with my speaker rings, well tbh they came afterwards when i had already spliced one door, so i just used it on the other side for quickness lol Quote Link to comment Share on other sites More sharing options...
JoeA Posted October 13, 2011 Report Share Posted October 13, 2011 My oem blaupunkt tweeters have built in crossovers on the unit, if they're all like that then i can only assume the crossover in the door is to killl the tweeter frequencies from the door speakers. Quote Link to comment Share on other sites More sharing options...
Mike_M Posted October 13, 2011 Report Share Posted October 13, 2011 I use focal components in my GTI..........I made an MDF ring to connect to the door and the focal woofer to that.........and then used the original tweeter in the car.Works well for me. Quote Link to comment Share on other sites More sharing options...
