Tricky88 Posted February 2, 2011 Report Share Posted February 2, 2011 Done coolant temp sensor, plugs which were Bosch now ngk, new (standard) leads all within last month or 2. Not long serviced - car has done about 76k with full Vw history. When I got it I was always getting 170 exactly to a tank now 140 and a slight misfire has developed which hopefully a new coilpack will solve on Friday. Vag com says nothing, May have to look into the possibility of a leak???As you know it's just frustrating.Patrick Quote Link to comment Share on other sites More sharing options...
Big Jase Posted February 2, 2011 Author Report Share Posted February 2, 2011 try the coilpack and see how it goes, slight misfire can't be too good!running on the correct oil? Quote Link to comment Share on other sites More sharing options...
saq85 Posted February 6, 2011 Report Share Posted February 6, 2011 Done coolant temp sensor, plugs which were Bosch now ngk, new (standard) leads all within last month or 2. Not long serviced - car has done about 76k with full Vw history. When I got it I was always getting 170 exactly to a tank now 140 and a slight misfire has developed which hopefully a new coilpack will solve on Friday. Vag com says nothing, May have to look into the possibility of a leak???As you know it's just frustrating.PatrickI have the exact same promblem as you, I get 40 miles for £10 and 140 on a full tank. something is seriously wrong :/ I have a very slight misfire so i might just change the leads/coilpack. Ive done a full service minus them a few months ago..*shrugs* let me know if u get rid of your fuel & misfire problem. Quote Link to comment Share on other sites More sharing options...
Tricky88 Posted February 6, 2011 Report Share Posted February 6, 2011 Im actually glad I'm not the only one - got another thread going about mine. I've changed the lot now and the coilpack had one corroded terminal and plugs were bosch which were spitting a lead off. The misfire is only noticable when idling but has got a lot better after changing coilpack without a doubt although it's not gone. I've just filled her up so will let you know if it effects economy. Vag com again showed no faults yesterday. Does your misfire get worse when sitting at lights etc. Patrick Quote Link to comment Share on other sites More sharing options...
Brammo Posted February 7, 2011 Report Share Posted February 7, 2011 I can get 32 litres in my lupo sport don't the GTi's have a bigger tank? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted February 7, 2011 Report Share Posted February 7, 2011 I can get 32 litres in my lupo sport don't the GTi's have a bigger tank?Not that I know of, however for some reason I always manage to fit more in my GTI than in the Sport Quote Link to comment Share on other sites More sharing options...
Brammo Posted February 9, 2011 Report Share Posted February 9, 2011 It all depends what pumps I go to some are more sensitive than others if that makes sense and they will click before you have got it proper brimming. I am surprised no one has mentioned the magic button yet. Quote Link to comment Share on other sites More sharing options...
