Jowey Posted January 16, 2011 Report Share Posted January 16, 2011 Do you own an angle grinder ? Or know someone that does ? If you grind the nut off and reconstruct the top mount assembly you'll be fine I'm sure.Seems scary but it honestly isn't too bad.Once you've ground the nut off, take the shock to an iron monger's/ hardware shop / automotive accessory shop.And tell them you want a new (nylon thread lock) nut that fits and then get a few washers that will fit over the thread but not over the little ridge just below the thread. When u put it back together.Bolt the shock to the beam at the bottom.Then but on the washer, then the plastic shock cover then the lower side of the top mount.raise the rear beam/ shock up so that the thread comes up through the top mount hole and becomes visible in the boot.Then put the top half off the top mount onto the the threaded bit showing through in the boot.Then the large topmount washer. Then the nut and tighten up.Then with the car off the jack and on flat ground. Tighten the top nut up some more.Check it agai in a few days.HTH Quote Link to comment Share on other sites More sharing options...
Ben™ Posted January 16, 2011 Author Report Share Posted January 16, 2011 Grinded nut off, got a new one and it threads fine but still no closer to solving the problem, although I have little knowledge on this subject I'm pretty sure I'm missing something, There's nothing on the underside of the car that is preventing the shock from freely coming through the chassis everytime I take it back down off the jack. This is doing my ****ing head in Quote Link to comment Share on other sites More sharing options...
bobbo Posted January 16, 2011 Report Share Posted January 16, 2011 Can you take some photos of the chassis showing where the shock just comes through? Quote Link to comment Share on other sites More sharing options...
Ben™ Posted January 16, 2011 Author Report Share Posted January 16, 2011 I've just jacked it down for the second time.On the underside I have two rubber bits (sorry idk what they're called) and a washer type thing. On the top side I have the gold plate, rubber bit and a nut obviously.Even if the nut is done up as much as you like you could just freely push the shock upwards or in this case when I take it off the jack it just protrudes as in the first picture.Sorry I can't give a better description. Quote Link to comment Share on other sites More sharing options...
treblet Posted January 16, 2011 Report Share Posted January 16, 2011 You are definitely missing a part, or you've damaged the top of the strut tower. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 16, 2011 Report Share Posted January 16, 2011 It's missing the locking collar that sits on top of the circlip I think.I think you can use the one off the factory shocks in most cases. Quote Link to comment Share on other sites More sharing options...
Ben™ Posted January 16, 2011 Author Report Share Posted January 16, 2011 Turns out I'm missing the circlip altogether!Getting the lower mount welded tomorrow, problem solved I hope, thanks again everyone. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 16, 2011 Report Share Posted January 16, 2011 Turns out I'm missing the circlip altogether!Getting the lower mount welded tomorrow, problem solved I hope, thanks again everyone.Why does the lower mount need welding? Quote Link to comment Share on other sites More sharing options...
Ben™ Posted January 16, 2011 Author Report Share Posted January 16, 2011 Don't want to put the whole weight of the car onto another circlip, and it's easier. :/ Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 16, 2011 Report Share Posted January 16, 2011 You can't weld the damper shaft, it's hardened steel. Quote Link to comment Share on other sites More sharing options...
Ben™ Posted January 16, 2011 Author Report Share Posted January 16, 2011 Ahh I don't know...I just want my car working Quote Link to comment Share on other sites More sharing options...
Ben™ Posted January 16, 2011 Author Report Share Posted January 16, 2011 And we did try replacing the circlip, but as soon as we put the weight of the car back on it, it pushed through again. Quote Link to comment Share on other sites More sharing options...
Jowey Posted January 16, 2011 Report Share Posted January 16, 2011 (edited) That is all the stuff that goes in the wheel arch and onto the damper. Edited January 16, 2011 by Jowey Quote Link to comment Share on other sites More sharing options...
Ben™ Posted January 16, 2011 Author Report Share Posted January 16, 2011 Got all of that jowey, there's just nothing there to hold the top rubber mount in place.There's evidence that a circip was there. Quote Link to comment Share on other sites More sharing options...
Mitchell Posted January 16, 2011 Report Share Posted January 16, 2011 eh? there should be circlip ,large washer like the one above rubber with sleeve in. this lot underside, then rubber large washer,nut inside Quote Link to comment Share on other sites More sharing options...
Mitchell Posted January 16, 2011 Report Share Posted January 16, 2011 ps nice drawing on a virgin money letter Quote Link to comment Share on other sites More sharing options...
Jowey Posted January 16, 2011 Report Share Posted January 16, 2011 (edited) ps nice drawing on a virgin money letter Even added some colour to it now.-The long 'pipe' bit at the top sits inside the large black rubber bit. Creating the lower part of the top mount.-That then sits a top the black plastic damper cover (which has a massive washer in the top)-In turn sits on the circlip (I have a washer on mine)-Which then finally sits on the little shoulder of the strut shaft where the thread ends and the actually polished hardened shaft () starts. Edited January 16, 2011 by Jowey Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 16, 2011 Report Share Posted January 16, 2011 Do you have the little bit shown on the right damper? Or do the budget ones not have that? Quote Link to comment Share on other sites More sharing options...
Mitchell Posted January 16, 2011 Report Share Posted January 16, 2011 lol damn it lets all have a draw off Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 16, 2011 Report Share Posted January 16, 2011 (edited) Your drawings are all missing the bumpstop holding cup off. Edited January 16, 2011 by 99hjhm Quote Link to comment Share on other sites More sharing options...
Jowey Posted January 16, 2011 Report Share Posted January 16, 2011 I'd say that is pretty comprehensive. Quote Link to comment Share on other sites More sharing options...
max West-York Posted February 2, 2011 Report Share Posted February 2, 2011 are you not supposed to re-use the big ribbed, foamy bumpstop things from the standard suspension?Ive got mine in but it doesnt have much travel, im guessing thats why its not the smoothest of rides? Quote Link to comment Share on other sites More sharing options...
Jowey Posted February 4, 2011 Report Share Posted February 4, 2011 Yes me and Mitch both forgot about the bumstops in the drawings.I have rock hard rubber stops on mine so dont run the foam one's. Quote Link to comment Share on other sites More sharing options...
