craigg!! Posted January 4, 2011 Report Share Posted January 4, 2011 so my poor arosa is in the need of some tlc. its losing coolant and smoking from the exhaust and the smell of coolant is strong from the exhaust so suggests the head gasket. the clutch is also very heavy and difficult to engage gears sometimes so guessing at a clutch and cable?i priced genuine seat parts up today and everything seemed fairly decent priced apart from the damn head bolts! i was quoted £69.80. apart from the timing belt kit they are the most expensive part. is it just me or is that overpriced for a set of bolts? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 4, 2011 Report Share Posted January 4, 2011 so my poor arosa is in the need of some tlc. its losing coolant and smoking from the exhaust and the smell of coolant is strong from the exhaust so suggests the head gasket. the clutch is also very heavy and difficult to engage gears sometimes so guessing at a clutch and cable?i priced genuine seat parts up today and everything seemed fairly decent priced apart from the damn head bolts! i was quoted £69.80. apart from the timing belt kit they are the most expensive part. is it just me or is that overpriced for a set of bolts?Sounds expensive to me. Dealer? Quote Link to comment Share on other sites More sharing options...
craigg!! Posted January 4, 2011 Author Report Share Posted January 4, 2011 Yeh was a main dealer. B&H motors in whitehaven. would factors parts be so bad? im just a bit iffy when it comes to factors as when i had my zetec-s i put an alternator on and lasted no more than 5mins until it was overcharging so ended up with a ford one that was only £3 more expensive in the end. Quote Link to comment Share on other sites More sharing options...
truCido Posted January 4, 2011 Report Share Posted January 4, 2011 (edited) I paid £40 for mine from a factor Edited January 4, 2011 by truCido Quote Link to comment Share on other sites More sharing options...
NOCK Posted January 5, 2011 Report Share Posted January 5, 2011 Lupoboz might be able to get them cheaper? Quote Link to comment Share on other sites More sharing options...
Rich Posted January 5, 2011 Report Share Posted January 5, 2011 Lupoboz might be able to get them cheaper?That's what I was going to say. Quote Link to comment Share on other sites More sharing options...
Bickerton Posted January 5, 2011 Report Share Posted January 5, 2011 (edited) £20.70 online from eurocarparts and that drops to £16.56 delivered if you pop "box20" in the discount voucher boxAnd about £40 for timing belt kit Edited January 5, 2011 by Bickerton Quote Link to comment Share on other sites More sharing options...
craigg!! Posted January 5, 2011 Author Report Share Posted January 5, 2011 I got prices from tms today. 12.20 for head bolts + vat. It came to £277 for a head gasket kit, timing belt kit, head bolts, water pump, clutch cable and cluchh. That seems more reasonable? Quote Link to comment Share on other sites More sharing options...
Bickerton Posted January 5, 2011 Report Share Posted January 5, 2011 (edited) Looking about £100 for cable and clutch most places..Definate it's the clutch/cable and not the pedal box ja? Edited January 5, 2011 by Bickerton Quote Link to comment Share on other sites More sharing options...
craigg!! Posted January 5, 2011 Author Report Share Posted January 5, 2011 I tink so. If I look at the pedal box will it be obvious if its that or not? Quote Link to comment Share on other sites More sharing options...
Bickerton Posted January 5, 2011 Report Share Posted January 5, 2011 There's a massive thread on here, top of this section i believe.Basically, if you crunch into gears, especially into reverse and your clutch pedal isn't level with your brake pedal it stands a good chance it's broke Quote Link to comment Share on other sites More sharing options...
craigg!! Posted January 5, 2011 Author Report Share Posted January 5, 2011 I'll have a read later, its a bit hard on my blackberry ha. Its level with te brake just hhard to select gears at times. Quote Link to comment Share on other sites More sharing options...
