nfbr Posted December 27, 2004 Report Share Posted December 27, 2004 Firstly... Sorry admin i've posted this in two locations...Here you see a standard vw head unit. Looks ok, sounds ok... but we dont want "OK" do we? border="0" class="linked-image" /> border="0" class="linked-image" />Step OneUsing a set of release keys (i used some old kenwood ones pushed in at a downward angle) slot them into the holes either side of the head unit border="0" class="linked-image" /> border="0" class="linked-image" />Step TwoStick a finger into the cassette flap, the unit should come out with a gentle tug, if not, try adjusting the position of your keys border="0" class="linked-image" /> border="0" class="linked-image" />Step ThreeSlide the unit out (watch the corners dont scrape your dashboard) and release the two plugs on the back of the unit border="0" class="linked-image" /> border="0" class="linked-image" />Step FourIf your head unit has a trailing lead clip this into the VW ISO radio plugs you see below, border="0" class="linked-image" /> border="0" class="linked-image" />Step FiveTry and tuck away as much of the wiring as possible now, this will help when you come to slide the head unit in to position. border="0" class="linked-image" /> border="0" class="linked-image" />Step SixSlip your ISO / Or trailing lead through the cage along with the aerial leadand slide the cage into position. On most cages you'll need to bend a few tabs using a screwdriver, to secure the cage. (alpine kindly provide a self securing cage which makes the job a doddle) border="0" class="linked-image" /> border="0" class="linked-image" />Step SevenConnect the ISO / Trailing lead to the head unit, and connect the aerial lead, Now slide the unit into the cage, but before you slide it all the way in, turn it on and test everything is working ok. border="0" class="linked-image" /> border="0" class="linked-image" />Step EightOnce you know the unit is working properly, Slide it all the way in and you should hear it click into position(Unfortunately my camera battery ran out so i cant show you a picture of what it looks like fully fitted. but you get the idea)FAQ - QuestionDo VW use a different wiring method to usual ISO looms?AnswerYes, In order to get my head unit working i found i had to join the red and yellow wires together (making both circuits permanent live) to get the unit to work.PM Me for a more detailed approch to doing this, or seek advice from your local Car Audio shop (not halfords cos they'll sell you an adaptor)QuestionMy aerial doesnt fit to my head unit?AnswerVW use the European Standard aerial plug, Many aftermarket head units dont use this type, To solve this problem you can buy an aerial adaptor (£4.29 @ Halfords) (£3 to £4 from local car audio shops) or you can PM me with your name and home address and i will mail you an aerial adaptor if you dont mind waiting a couple of days to get radio functions working properly (Dont worry i wont charge for these, providing you live in the Brittish Isles) Quote Link to comment Share on other sites More sharing options...
paulbin Posted December 27, 2004 Report Share Posted December 27, 2004 modding already and u havent had it 5 minutes lol, nice 1 Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 27, 2004 Author Report Share Posted December 27, 2004 i nearly cried when i had to listen to the RADIO on the way home from VW lol.that Justin morehouse put me off driving it lol.Tomorrow = How to run your phono leads from your head unit to the boot style="vertical-align:middle" emoid=":D" border="0" alt="biggrin.gif" /> (if i've got new batteries for cam. lol) Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 27, 2004 Report Share Posted December 27, 2004 another good one to do would be how to run the power leads for an amp! and how to find the damn hole in the bulkhead to get them through! Quote Link to comment Share on other sites More sharing options...
nippyarosa Posted December 27, 2004 Report Share Posted December 27, 2004 oh man is that a bitch! you're in for some scraped knuckles and a bad back Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 27, 2004 Author Report Share Posted December 27, 2004 i might just have to do a "HOW TO REPLACE YOUR REVERSE LIGHT SWITCH" since VW couldn't be ringed to check the car over properly before i picked it up.As for the power lead i'll just make my own hole and slip a gromet in their. Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 27, 2004 Report Share Posted December 27, 2004 just a note * FOR PEOPLE FITTING PIONEER!* what u need to do is look at the yellow and red wires , half way down it there is a connector on each , disconnect the yellow to yellow wire and the the same for the red to red , then reconect one half of the red to the other half of the yellow . this will make ur wires look like :standard set up back of head unit * ] yellow to yellow ****************]---------[]-----------------[ big block thing to wirin loom****************]---------[]-----------------[****************] red to red****************]changed to back of head unit * ] yellow to red****************]---------[]-----------------[ big block thing to wirin loom****************]---------[]-----------------[****************] red to yellow ****************]the connectors are just a push fit so pull to separate then a push till u hear a light click and thats them back in place Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted December 28, 2004 Report Share Posted December 28, 2004 Theres a gropmmet in the bulk head behind the battory area.Brings the cable out in the passenger footwell. Quote Link to comment Share on other sites More sharing options...
Altern8 Posted December 28, 2004 Report Share Posted December 28, 2004 style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />+-->QUOTE(one litre wonder style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />)just a note * FOR PEOPLE FITTING PIONEER!* what u need to do is look at the yellow and red wires , half way down it there is a connector on each , disconnect the yellow to yellow wire and the the same for the red to red , then reconect one half of the red to the other half of the yellow . this will make ur wires look like :standard set up the connectors are just a push fit so pull to separate then a push till u hear a light click and thats them back in placei was gona say that style="vertical-align:middle" emoid=":D" border="0" alt="biggrin.gif" /> dont we need a amplified bit for the radio Quote Link to comment Share on other sites More sharing options...
M1 Lupo Posted December 28, 2004 Report Share Posted December 28, 2004 The aerial adaptor is a cheap little thing, code MZ79. £1.99. http://www.maplin.co.uk/Module.aspx?Module...ldID=&doy=28m12 Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 28, 2004 Author Report Share Posted December 28, 2004 The aerial adaptor is available at no cost to all club lupo members. (no this doesnt mean for anyone searching aerial adaptor on google can have one if they sign up) If your a member of Club Lupo PM me and i'll mail one to you through the post style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 28, 2004 Author Report Share Posted December 28, 2004 style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />+-->QUOTE(one litre wonder style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />)disconnect the yellow to yellow wire and the the same for the red to red , then reconect one half of the red to the other half of the yellow .I tried this on mine n it dont work style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" /> the only way i could get it to work was wiring both red n yellow to permanent feed. Quote Link to comment Share on other sites More sharing options...
AndyW Posted December 28, 2004 Report Share Posted December 28, 2004 Thanks for the guide,im going to order my headunit finally tomorrow and have no clue how to fit it.Someone mention pioneer, do I need some special stuff if fitting a pioneer in the lupo? Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 28, 2004 Report Share Posted December 28, 2004 oh right cause ma pioneer h/u had push fit connectors on it so u could change them round , not unless they are the only company that do that , or that alpine dont do it@ andy , pioneer are fitted the same way just that when u get it u will see what i mean about the red and yellow wires , just follow that simple guid and u cant go wrong mate Quote Link to comment Share on other sites More sharing options...
M1 Lupo Posted December 28, 2004 Report Share Posted December 28, 2004 The aerial adaptor is available at no cost to all club lupo members. (no this doesnt mean for anyone searching aerial adaptor on google can have one if they sign up) If your a member of Club Lupo PM me and i'll mail one to you through the post style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />Fair play! Good man. style="vertical-align:middle" emoid=":D" border="0" alt="biggrin.gif" /> Quote Link to comment Share on other sites More sharing options...
Fyggy Posted December 28, 2004 Report Share Posted December 28, 2004 Good thread!! I shall search for it when it comes time to replace my Dubby one with an aftermarket one. Cheers and happy listening style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 28, 2004 Author Report Share Posted December 28, 2004 Its in the Archives section aswel kat style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 28, 2004 Author Report Share Posted December 28, 2004 style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />+-->QUOTE(one litre wonder style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />)oh right cause ma pioneer h/u had push fit connectors on it so u could change them round , not unless they are the only company that do that , or that alpine dont do it@ andy , pioneer are fitted the same way just that when u get it u will see what i mean about the red and yellow wires , just follow that simple guid and u cant go wrong mateYou can do this with the alpines, only it doesnt work in lupos older than 2002 (from experience) I know what you said is DEFINATELY right for all the lupos with Remote Central locking, but from experience the ones you have to stick the key in the door need a slightly different method. (how rare) Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 28, 2004 Report Share Posted December 28, 2004 cool cool so ur way is for central locking with a key and my way is for remote central locking Quote Link to comment Share on other sites More sharing options...
nfbr Posted December 28, 2004 Author Report Share Posted December 28, 2004 i'm not 100% sure but thats how i think it works.Basically my way, You join the yellow wire going to the head unit to the red wire coming from the ISO block, but insted of doing the oposite with the red wire from the head unit, you leave it connected to the red wire.I havent tried it your way with mine, but i tried it on a Y reg' one the other day and it didnt work. so i concluded by doing the above ^ Quote Link to comment Share on other sites More sharing options...
