19jonny91 Posted August 19, 2009 Report Share Posted August 19, 2009 Does anyone now what would happen if I put a 1.9 paast turbo on ma lupo tdi or what I would need to uprate for it Thanks jonny Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 19, 2009 Report Share Posted August 19, 2009 Been done, have a search Quote Link to comment Share on other sites More sharing options...
cobblers Posted August 19, 2009 Report Share Posted August 19, 2009 You'd scratch your roof. Quote Link to comment Share on other sites More sharing options...
electricpanda Posted August 19, 2009 Report Share Posted August 19, 2009 You'd scratch your roof. Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted August 19, 2009 Report Share Posted August 19, 2009 Its going to need bubble wrap Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted August 19, 2009 Report Share Posted August 19, 2009 Been done, have a searchNo it hasn't. Do a search The turbo from a 1.9TDI wont fit as far as I know.. your engine has three cylinders, the 1.9 has 4.You would have to fit a 1.9 engine if you wanted to use the Turbo without making a custom maniold. Quote Link to comment Share on other sites More sharing options...
bossjohnc Posted August 19, 2009 Report Share Posted August 19, 2009 Youtube Video ->Original Video Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted August 19, 2009 Report Share Posted August 19, 2009 No it hasn't. Do a search The turbo from a 1.9TDI wont fit as far as I know.. your engine has three cylinders, the 1.9 has 4.You would have to fit a 1.9 engine if you wanted to use the Turbo without making a custom maniold.Would it be a case of cutting the mounting face from both manifolds and welding it on to the three cylinder one, assuming the orientation is correct and there is enough space ? Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted August 19, 2009 Report Share Posted August 19, 2009 TBH, Im not convinced its worth it.Your not going to get much benifit for the cash.1.9 conversion would be Soooo much easier. Quote Link to comment Share on other sites More sharing options...
Tom_B Posted August 19, 2009 Report Share Posted August 19, 2009 Youtube Video ->Original VideoThat driver looks like he's wearing a skid lid TBH you'd be easier putting the 1.9tdi lump in. More tuning potential. Quote Link to comment Share on other sites More sharing options...
electricpanda Posted August 19, 2009 Report Share Posted August 19, 2009 Didn't that lad put 1 in an arosa? 1.9TDi? Quote Link to comment Share on other sites More sharing options...
nfbr Posted August 19, 2009 Report Share Posted August 19, 2009 Would it be a case of cutting the mounting face from both manifolds and welding it on to the three cylinder one, assuming the orientation is correct and there is enough space ?Exhaust manifold ports are spaced differently on the three cylinder.The 4cylinder engine is 1,2,3,4, the 3 cylinder is 1,2,small gap,3. Really odd configuration. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted August 20, 2009 Report Share Posted August 20, 2009 No it hasn't. Do a search Apologies, I thought he meant the engine as a whole Quote Link to comment Share on other sites More sharing options...
bossjohnc Posted August 20, 2009 Report Share Posted August 20, 2009 Apologies, I thought he meant the engine as a wholeTbh, I thought he meant the car as a whole Quote Link to comment Share on other sites More sharing options...
Niche Posted August 20, 2009 Report Share Posted August 20, 2009 (edited) Hmm...didn't know the Lupo TDI was a 3 pot...wonder if I can use the manifold and turbo from a Lupo TDI on my 12V. Edited August 20, 2009 by Niche Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted August 20, 2009 Report Share Posted August 20, 2009 Exhaust manifold ports are spaced differently on the three cylinder.The 4cylinder engine is 1,2,3,4, the 3 cylinder is 1,2,small gap,3. Really odd configuration.I realised that, reading back i dont think i made myself clear really and different interpretations could be took, my fault.i neant cut the turbo mounting faces from both manifolds and swap them, then the three branch is kept.Is that possible or are the bolt dimensions and the centre bore the same on both turbos anyway, as i dont thow much about both turbo housing sizes? Quote Link to comment Share on other sites More sharing options...
nfbr Posted August 22, 2009 Report Share Posted August 22, 2009 I realised that, reading back i dont think i made myself clear really and different interpretations could be took, my fault.i neant cut the turbo mounting faces from both manifolds and swap them, then the three branch is kept.Is that possible or are the bolt dimensions and the centre bore the same on both turbos anyway, as i dont thow much about both turbo housing sizes?It's a big no. The original GT1544s is an all in one unit complete with manifold and the passat compressor housing will not fit without a lot of modification.Besides the passat is a longtitudinally mounted engine.Hmm...didn't know the Lupo TDI was a 3 pot...wonder if I can use the manifold and turbo from a Lupo TDI on my 12V.No because petrol turbos are liquid cooled and work in a slightly different way. Quote Link to comment Share on other sites More sharing options...
richardn Posted August 23, 2009 Report Share Posted August 23, 2009 would the 1.4tdi flow enough air for the 1.9turbo,as im sure its a lot bigger Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted August 24, 2009 Report Share Posted August 24, 2009 Its not important really, as you'd just adjust the fueling to suit if you were to fit a larger turbo. Quote Link to comment Share on other sites More sharing options...
