cobblers Posted August 20, 2008 Report Share Posted August 20, 2008 Righto, I've seen the perfect set of wheels, but they are a staggered fit and the rears are 8.5 inch wide. I plan on stretching some 195/45/15s on and getting the arch lip rolled and pushed, but I think its going to be pretty bloody close!My lupo is pretty low, and I'd rather not raise it!If I have half a chance of it working, I'm going to just buy the buggers. Quote Link to comment Share on other sites More sharing options...
DUB JIMBOB Posted August 20, 2008 Report Share Posted August 20, 2008 Would of thought they'd be ok m8. will have a bit of rubbing.I say go 4 them.Ive got 8x14 et 5 on the rear with 10mm spacers as the split rim bolts hit my rear calipers, they do rub but nothing major.The rear arches on loops are smooth so they don't cut into the tyres, they just leave a rub mark. Quote Link to comment Share on other sites More sharing options...
cobblers Posted August 20, 2008 Author Report Share Posted August 20, 2008 Cheers for that. I'll just buy them and see! Providing I've half a chance of them going on, I'll risk it, might even raise the back a spot if I must.Before I refurb them I'll get a tyre mounted on one and try it on (I've got a 195/45/15 lying about the garage) so I don't waste my time polishing them for them not to fit! Quote Link to comment Share on other sites More sharing options...
vworks41 Posted August 20, 2008 Report Share Posted August 20, 2008 If your getting your arches rolled and pulled then i reckon you'd be ok aswell. Quote Link to comment Share on other sites More sharing options...
chris260 Posted August 20, 2008 Report Share Posted August 20, 2008 Mine rubbed the smallest amount with ET25 8x15's on the back and no rear adjusters in but i've got no archwork done. I'd have thought you'll be fine with the arches rolled. Quote Link to comment Share on other sites More sharing options...
musto Posted August 20, 2008 Report Share Posted August 20, 2008 Y would you change the wheels there imence! use to rep hemel! Quote Link to comment Share on other sites More sharing options...
cobblers Posted August 20, 2008 Author Report Share Posted August 20, 2008 I do love these wheels, but I bought the car like this and I want to put a bit of my own stamp on it, so I don't feel like I'm driving someone elses creation. The new wheels will be even better Quote Link to comment Share on other sites More sharing options...
Bikerz Posted August 21, 2008 Report Share Posted August 21, 2008 They fit on a GTI with 195/45/15 tyres slammed as ow as she will go on FK coilovers Quote Link to comment Share on other sites More sharing options...
Philplop Posted August 21, 2008 Report Share Posted August 21, 2008 (edited) Why do my 15x7's et30 with 195/45's scrub like a bitch on the back then? And his isn't a GTI anway. Edited August 21, 2008 by Philplop Quote Link to comment Share on other sites More sharing options...
scoobydoo Posted August 21, 2008 Report Share Posted August 21, 2008 mine r 8 et14 on the rear. u'll defo need them rolled and pulled, but u should b fine if u dont mind abit of rubbing. Quote Link to comment Share on other sites More sharing options...
musto Posted August 21, 2008 Report Share Posted August 21, 2008 Why do my 15x7's et30 with 195/45's scrub like a bitch on the back then? And his isn't a GTI anway.15x7.5 et 32 on my rears, to the bottom is fine o actully i got 165/50s Quote Link to comment Share on other sites More sharing options...
cobblers Posted August 21, 2008 Author Report Share Posted August 21, 2008 Well, half a chance is enough chance for me! I've measured them up and it looks like et15 will line the wheels up just right to be nice and close on the inside, to give me enough space on the back, and from what I can see, the angle of the tyres when 195s are stretched on will be about the same as the angle of the arch, so if I roll the lips and perhaps pull them out a little I should just get away with it. Might have to crack the back up 10mm or so (The tops of my 165/50/15s are about 2mm inside the arch right now, but I don't mind sacrificing lowness to have nice wide wheels. Quote Link to comment Share on other sites More sharing options...
vworks41 Posted August 21, 2008 Report Share Posted August 21, 2008 Why do my 15x7's et30 with 195/45's scrub like a bitch on the back then? And his isn't a GTI anway.Gti's have wider arches but they've also got wider track remember, you sure they're et30 though Quote Link to comment Share on other sites More sharing options...
heartagram Posted August 22, 2008 Report Share Posted August 22, 2008 15x8 ET10 with 165/50I had to roll the lips back, but even then it rubs unless you potter around in it. No chance of passengers in the back either. Quote Link to comment Share on other sites More sharing options...
cobblers Posted August 22, 2008 Author Report Share Posted August 22, 2008 ouch. hmmm. You're about the same height as me at the back, and my wheels will be wider and have wider tyres. I really don't want to run as much stretch as you have, it looks scary!What are you like for clearance on the inside? Quote Link to comment Share on other sites More sharing options...
Philplop Posted August 22, 2008 Report Share Posted August 22, 2008 There'll be acres of room on the inside with et10, and with your et15 too.Use this fancy tool here to work it out.Wheel Offset Calculator Quote Link to comment Share on other sites More sharing options...
heartagram Posted August 22, 2008 Report Share Posted August 22, 2008 Bags of room, on the inside they just fit like stock G60s. Quote Link to comment Share on other sites More sharing options...
cobblers Posted August 22, 2008 Author Report Share Posted August 22, 2008 (edited) Bags of room, on the inside they just fit like stock G60s.Thats what I like to hear, I'll get a bit machined off the hub faces if I get desperate, although by my measurements, 8.5 inch et15 will put the inner lip 4mm away from inner arch - I'm used to having a 106 and having to get the offset millimeter perfect to fit any rear wheels worth having (et14 or youve no chance!) Edited August 22, 2008 by cobblers Quote Link to comment Share on other sites More sharing options...
cobblers Posted September 6, 2008 Author Report Share Posted September 6, 2008 (edited) Well bugger me, these finally turned up! Advertised as "freshly refurbished, minor marks on one" and It seems that David Blunkett has sprayed them, and one of them is chipped to hell. nevermind though, because I got a tyre on one of them and they actually fit just as I calculated!Picture makes it look like there is plenty of room - really there is about 2mm.I'm going to refurb them on monday, and I'm going up to get the arches rolled on monday night Not sure on how to do them, was thinking chocolate brown spokes and face, with polished lip and centre cap? Edited September 6, 2008 by cobblers Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted September 7, 2008 Report Share Posted September 7, 2008 Stamps feet incredibly hard......renault v6 2.5 turbo alpine wheels i think , ive got a pic of a set on an alpine on my phone, ive been searching for a set cheap for a while.If they arent them , then they look dam close Quote Link to comment Share on other sites More sharing options...
cobblers Posted September 7, 2008 Author Report Share Posted September 7, 2008 Thems the ones I paid more than I should have for them, especially considering what a poor job of a repaint they have had, but I'm damn happy with the look of them, and the back one seems to fit OK.The fronts are just 6j et 35 so will fly on, maybe I'll add some spacers to shove them out a bit. Quote Link to comment Share on other sites More sharing options...
scoobydoo Posted September 7, 2008 Report Share Posted September 7, 2008 they dont sit out as much as i thought they would. they look sweet. i reckon i could easily squeeze some bigger dishes on mine lol. Quote Link to comment Share on other sites More sharing options...
cobblers Posted September 9, 2008 Author Report Share Posted September 9, 2008 Bolted these on today after getting the tyres on them and the arches rolled last night - I'm happy to say they haven't rubbed at all, and I've given the car a lot of stick over some bumpy and undulating roads. I'm quite surprised to be honest!The rears stick out and the fronts have a mega tuck situation, which is growing on me but I do think I need some 15/20mm spacers. Quote Link to comment Share on other sites More sharing options...
