Beaniebug Posted December 23, 2007 Report Share Posted December 23, 2007 Help My 1.4 16v(75) 99 v loop died on me today...She turns over fine, everything seems to work but the following...Turn the key and no dash lights or fuel guage movement? We - me and the green flag guy - checked all the fuses, bonnet and in car and we ain't got a clue???She has an additional alarm, but that seems to be working fine?Has anyone got any ideas? - she's been 100% until today Thanks Daz Quote Link to comment Share on other sites More sharing options...
EaRNi! Posted December 23, 2007 Report Share Posted December 23, 2007 chip in the key maybe? Quote Link to comment Share on other sites More sharing options...
Beaniebug Posted December 23, 2007 Author Report Share Posted December 23, 2007 chip in the key maybe?Cheers dude,Tried the spare - but same thing happens??I'm stumped - got a feelin it's gonna cost me! Quote Link to comment Share on other sites More sharing options...
Rich Posted December 24, 2007 Report Share Posted December 24, 2007 dude, the normal answer applies. vagcom exists for a reason. Quote Link to comment Share on other sites More sharing options...
Beaniebug Posted December 24, 2007 Author Report Share Posted December 24, 2007 dude, the normal answer applies. vagcom exists for a reason.Sorry Rich - I'm thick - what's vagcom?? Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 24, 2007 Report Share Posted December 24, 2007 VAGCom is the program that the dealers use to diagnose problems , some people have it on a laptop and could do it for you if you find somebody willing to do it Quote Link to comment Share on other sites More sharing options...
Beaniebug Posted December 24, 2007 Author Report Share Posted December 24, 2007 VAGCom is the program that the dealers use to diagnose problems , some people have it on a laptop and could do it for you if you find somebody willing to do itAh ha! - Just need to find someone in Corby! - cheers chapI think the issue may my to do with one of the relays... Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted December 24, 2007 Report Share Posted December 24, 2007 fuel pump could be away , the engine would turn over from the starter but if no fuel is getting to it then it wouldnt start . or it could be that as somebody has said that the imobiliser chip could be away Quote Link to comment Share on other sites More sharing options...
BridLupo Posted December 24, 2007 Report Share Posted December 24, 2007 No dash lights or fuel gauge movement makes me think ignition switch is faulty. When you turn ignition on can you hear the fuel pump prime? If so then then the only thing preventing the car starting is NO SPARK. Quote Link to comment Share on other sites More sharing options...
Mitchell Posted December 24, 2007 Report Share Posted December 24, 2007 as brid says, allthough i aint heard of the ignition switch problem in years, it used to be common in mk2's and mk 1'sit is feasable though. Quote Link to comment Share on other sites More sharing options...
Beaniebug Posted December 24, 2007 Author Report Share Posted December 24, 2007 as brid says, allthough i aint heard of the ignition switch problem in years, it used to be common in mk2's and mk 1'sit is feasable though.No the fuel pump doesn't prime, no lights or movement on the dash and horn doesn't work?? - HOWEVER the heated rear screen works and the lights main and full beam work when you switch to the first position??Does anyone know how to get at the Relays? - someone has mentioned that one of the replays controls a lot of ignition related fuses/functions??? Thanks for the help so for guys!Daz Quote Link to comment Share on other sites More sharing options...
Beaniebug Posted December 24, 2007 Author Report Share Posted December 24, 2007 fuel pump could be away , the engine would turn over from the starter but if no fuel is getting to it then it wouldnt start . or it could be that as somebody has said that the imobiliser chip could be awayI've heard the pump when the green flag chap was checking the fuses so I think thats OK - I've tried both my keys in case it was the chip but it's the same -- it's as if I've just lost the ignition related circuits?Does anyone have a wiring diagram???Thanks OLW Quote Link to comment Share on other sites More sharing options...
Mitchell Posted December 26, 2007 Report Share Posted December 26, 2007 could be a long shot but if you remove the undertray drivers side dash you will see the fuse box behind this is the relays,but i'm wondring if the transponder has a fault not the key but the reciever.remove the steering coloum plastics look at the ignition housing there will be a small black wire with a black plastic bit on the end(next to the barrel end) this is the recieving end of transponder the cable run's back to a unit, on mine this is abovethe fuse box and has 2 connectors.i'd start here. Quote Link to comment Share on other sites More sharing options...
Rich Posted December 26, 2007 Report Share Posted December 26, 2007 I'd go look at the fuel rail, pop off the in line and put it in a coke bottle, try and start it and see if it pumps.If not, check the fuse and then check the fuel pump. Quote Link to comment Share on other sites More sharing options...
Beaniebug Posted December 30, 2007 Author Report Share Posted December 30, 2007 Thanks for all help guys - appreciated! I've now finally traced the fault to the electrical side of the ignition barrel / switch - anyone got any ideas what the part number would be for this? She's a '99 1.4s V plateWe've hot wired the circuit to bypass where we thought the fault was and she starts first time every time, so I just need the new switch??Any one know where I can get the part numbers from??Thanks again you loverly people! Daz Quote Link to comment Share on other sites More sharing options...
Beaniebug Posted December 30, 2007 Author Report Share Posted December 30, 2007 No dash lights or fuel gauge movement makes me think ignition switch is faulty. When you turn ignition on can you hear the fuel pump prime? If so then then the only thing preventing the car starting is NO SPARK.Thanks for this dude - I have a problem with the switch! Since you said I've come across this happening to Loops more often! Quote Link to comment Share on other sites More sharing options...
Mitchell Posted January 2, 2008 Report Share Posted January 2, 2008 most veedubs use the same switch try a salvage yard Quote Link to comment Share on other sites More sharing options...
spin0304 Posted January 2, 2008 Report Share Posted January 2, 2008 Possible fuel pump problem. My husband had a Ford Focus until 6 mths ago. It did exactly the same thing. The pump inside the fuel tank had to be replaced.Help My 1.4 16v(75) 99 v loop died on me today...She turns over fine, everything seems to work but the following...Turn the key and no dash lights or fuel guage movement? We - me and the green flag guy - checked all the fuses, bonnet and in car and we ain't got a clue???She has an additional alarm, but that seems to be working fine?Has anyone got any ideas? - she's been 100% until today Thanks Daz Quote Link to comment Share on other sites More sharing options...
BridLupo Posted January 3, 2008 Report Share Posted January 3, 2008 Thanks for this dude - I have a problem with the switch! Since you said I've come across this happening to Loops more often!No problems glad to help Quote Link to comment Share on other sites More sharing options...
