EPC light on a GTi
Well it's gone again bloody thing, can they still find out whats causing it if the epc light has gone again ??
Throttle body has been recently cleaned out at vw, had a few problems with dodgy ht leads in the past.
Edited by SiiMo
To be honest im not sure, they were changed on a service at a non VW gargae i thought they were bosch they are odd looking ones lol, will have to get them out and have a look :)
The HT leads managed to devleop a hole in the one causing a missfire on cyclinder 2, that one was replaced but not the others as they looked ok, might change them as i don't want to be breaking down in this weather lol
Bosch plugs will cause the light to come on mate and also the leads will keep lifting. Go to your vw stealers and get some ngk ones. If your after a new set of leads as well then they are about 50 quid.
Thanks for your help mate, reckon its worth trying aftermarket leads or just stick with the vw ones ?
Last question, can they find what caused the epc light to come on even tho it has now gone again ?
Edited by SiiMo
The standard leads are meant to be pretty good, so its probably not worth it.
Should log a fault code, so yes :)
