HappyPie Posted January 30, 2007 Report Share Posted January 30, 2007 For quite a while my GTi drivers door has had an "Addam's family" type creak to it. Apparently its the check strap that needs replacing. The bush at the end of it has disintegrated. However I can't work out how to remove the old strap. Access through the door appears to be blocked by the rivetted in speaker. Any clues as to how I can get at it?Thanks, 80spie Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted January 30, 2007 Report Share Posted January 30, 2007 not to sure of the answer to this one , but the door straps going is a common fault ( mine are away as well so i will be needing to do this as well ) Quote Link to comment Share on other sites More sharing options...
mikeforceone Posted January 30, 2007 Report Share Posted January 30, 2007 My driver one too! By strap do you mean the metal piece that should either hold the door out or make it pull back in? Access is a toughie. Quote Link to comment Share on other sites More sharing options...
HappyPie Posted January 30, 2007 Author Report Share Posted January 30, 2007 Yes it is the metal strap. I rather hoped since this appears to be a recurring fault somebody would have already replaced one. If you can get access it looked pretty straight forward to fit and I was going to have a go myself. However it looks like I will have to leave it to my friendly local mechanic, I'll report back as to how he did it. 80spie Quote Link to comment Share on other sites More sharing options...
Max69vk Posted January 30, 2007 Report Share Posted January 30, 2007 Try sending Swoxy a PM, Im fairly certain he's done it. Quote Link to comment Share on other sites More sharing options...
Swoxy Posted January 30, 2007 Report Share Posted January 30, 2007 (edited) He hasn't but he needs to, the clicking noise is getting really bad now. My bodyshop guy owes me a favour so I think I'm going to get him to fit it. Edited January 30, 2007 by Swoxy Quote Link to comment Share on other sites More sharing options...
Mitchell Posted February 1, 2007 Report Share Posted February 1, 2007 you will need to remove the membrane or slash cut it as high as possible, slide your arm in and remove from the rear. 10 mm bolts in the door recess, one in the pin style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
D_eano Posted February 8, 2007 Report Share Posted February 8, 2007 damn mitch beat me 2 it! yea my dad did mine the other day, exactly what mitch said to do! Quote Link to comment Share on other sites More sharing options...
Mike_M Posted February 8, 2007 Report Share Posted February 8, 2007 As above.Did mine last year and is a common fault Quote Link to comment Share on other sites More sharing options...
NOCK Posted February 8, 2007 Report Share Posted February 8, 2007 My car's started to have a bit of 'an "Addam's family" type creak to it' recently too, and I've read this thread but am afraid to say I don't have a clue what you all mean when you say the 'Driver's Door Check Strap'. What is it? And how would I know if this is the problem? Because at present i've been putting it down to work suspension bushes.NOCK Quote Link to comment Share on other sites More sharing options...
Gibbeth! Posted February 8, 2007 Report Share Posted February 8, 2007 This 'NOCK'ing (see what I did there), is when opening and closing the door. There is a metal bar attaching the door to the car, stops the door opening too far.Its attached at the door where there is a bush that perrishes quickly, allowing the strap to move around, and clack around. It is easy enough to change though, once youve got at the bolts in behind the speaker, just takes a bit of feeling around.I got a replacement of mitch who just so happend to have one in his glove box at the time!! Quote Link to comment Share on other sites More sharing options...
